Center Stand Wiring Diagram Help?? - BMW Luxury Touring Community
 1Likes
  • 1 Post By Idofasn8u
post #1 of 13 Old Jun 13th, 2008, 6:34 pm Thread Starter
Red face Center Stand Wiring Diagram Help??
Can any of you fellow riders supply me with a copy of the center stand wiring diagram?
Seems electrical in nature, as the motor will not even make a sound. I found a blown fuse that powered the lites, etc and replaced it. The center stand worked, but now it does not and the fuse is still good.
The center stand dash lite will blink rapidly, and there is also a square box with a tall and short bar that shows up when pushing the button.
SeaMarshal is offline
post #2 of 13 Old Jun 13th, 2008, 7:14 pm
Re: Center Stand Wiring Diagram Help??
Tim,
I have the wiring diagram but it is on the BMW SLP2 CD and all I can get to you is the diagram without the legend. There are several items that come into play. Side stand switch, center stand limit switch, reverser control unit, brake relay, Fuses F14 and F15. the output is the center stand relay that drive the motor. And of course the push button. If one of the inputs is not correct the stand light will flash rapidly. Not sure what this other box is you described - is it in the LCD display?
post #3 of 13 Old Mar 12th, 2009, 11:47 am
Does the center stand motor or electrical circuit have a fuse, and if so, which one is it ?.
simoncharles is offline
post #4 of 13 Old Mar 12th, 2009, 2:10 pm
The circuit for the motor is direct from the battery to the relay and then motor. No fuse.
Fuses F14 and F15 feed the EHCS controller that, in turn, feeds the relay.
post #5 of 13 Old Mar 12th, 2009, 7:39 pm
Thanks for that.
post #6 of 13 Old Mar 20th, 2009, 5:01 pm
Any chance of a diagram to show where the relay is ?.
post #7 of 13 Old Mar 20th, 2009, 6:14 pm
See the other post. The relay is right behind the battery and not (thank goodness) in the relay box under the tank.
post #8 of 13 Old Mar 21st, 2009, 2:05 am
pozo_izquierdo's Avatar
Tim,
although your problem might be electrical related and John already gave good instructions, here is a strory that you might find helpful in case you decide to overhaul the EHCS unit itself. I think the unit should be cleaned and oil changed at least every four to five years.
http://picasaweb.google.fi/pozoizqui...RSTANDOVERHAUL#
I also took a looka at the control unit, but there is very little one can do about that as far as fixing is concerned...
http://picasaweb.google.fi/pozoizqui...ANDCONTROLUNIT#
Regards
Hyvinkää, Finland[
2004 ('05) LT, Dark Graphite
pozo_izquierdo is offline
post #9 of 13 Old Mar 29th, 2020, 9:53 am
Idofasn8u's Avatar
I just rebuilt my centerstand, bench tested it before install and it worked. Once in bike it does not, I can hear relay clicking but no movement. Is the relay the final leg of the circuit?
Idofasn8u is offline
post #10 of 13 Old Mar 29th, 2020, 10:55 am
Yes it is. Use what ever you tested it on the bench to power it through the connector to see if the motor will run. If it does not run then there may be corrosion on the internal brush ground screw in the motor. Also on the bike there are interlocks, must be in neutral, brakes off, upright (uses an alarm sensor).
post #11 of 13 Old Mar 29th, 2020, 11:46 am
Idofasn8u's Avatar
Also ran power to it while on bike and it ran fine.
post #12 of 13 Old Mar 29th, 2020, 9:25 pm
Sounds like a relay change is in order. BMW gets $18 for it but it looks to be a standard auto relay like they sell for horns or lighting addons. It is located directly behind the battery
post #13 of 13 Old Mar 31st, 2020, 8:00 pm
Idofasn8u's Avatar
I wired the motor direct and got nothing again, checked for power at the motor and had 12 volts when I tried to deploy the stand. I pulled the motor apart and cleaned the ground screw contact point. Reassembled the unit and it works better than new. Thanks for your help.
jzeiler likes this.
REPORT: Retrofit '01 with a Power Center Stand midwilshire K1200LT 55 May 10th, 2016 10:51 am
2002 k1200ltc center stand retrofit? rogerK K1200LT 14 Nov 25th, 2008 11:07 pm
An easier way to get the GT off the center stand Bobnoxous K1200/1300GT (The Next Generation) 16 Nov 5th, 2007 3:31 pm
2002 Model Center Stand Broke MattKas K1200LT 7 Nov 6th, 2006 12:37 pm
Center Stand Lubrication for Pre 2005 MattKas K1200LT 9 Oct 19th, 2006 12:16 pm
