ABS fault lights diagnostic - BMW Luxury Touring Community
post #1 of 3 Old Dec 24th, 2005, 7:27 am Thread Starter
Does anybody know what the ABS & General warning lights flashing alternately at 4HZ mean. I have looked at the diagnostic sheet and it does not show this perticular sequence. Thanks.
BrendanK is offline
post #2 of 3 Old Dec 24th, 2005, 8:24 am
NOGILLS2's Avatar
Cool
Check rear res for fluid level on brake system. remember there are two res.s, one is hidden under side panel. I removed several screws and pulled panel out enough to access res. The proper way is quite involved, my way takes a few minutes. BMW shop tech. showed me that trick.
I use a baby aspirator to refill res, no mess, about $3.00 amc. A friend uses a syringe for irrigating dental work, others use a drinking straw. maybe you'll come up with a different idea how to refill res.
My son reminded me not to keep brake fluid after opening for long periods of time it will absorb water from humidity. It is not very expensive so easy to replace.
Hope that sends you in the right direction.
NOGILLS2
Booze Brother# 69
2003 K1200LTE "BEERBURNER" RIP 07/21/09
2006 Aluma Trailer "AFTERBURNER" SOLD
2007 ST1300ABS "Quicksilver"
NOGILLS2 is offline
post #3 of 3 Old Dec 24th, 2005, 10:39 am
Ditto to NOGILLS2 response.
I had the same fault last October while riding the Blue Ridge. All seemed well with brakes and no apperant reason for fault. Called dealer while on the road and they told me probably low rear reservoir fluid. Note; dealer had just completed annual service to include break bleed before I left on trip. Dealer asked questions to determine that there was no major issues and then gave me the green light to complete trip and bring bike in when I got home.
Turned out that rear reservoir (hidden one under right side plastic) was a little low. I'm under warranty, so I let dealer take care of it, but if need be you can get fluid to the reservoir and top off with syringe, tubing, straw etc...
Portguyofva is offline
ABS Warning Lights and Radio Indicator JeffB K1200LT 16 Oct 28th, 2011 9:59 am
ABS unit gone again plonk K1200LT 9 Jun 17th, 2011 5:06 am
PIAA 1100X mod - Daytime Running Lights Daza Lighting 7 Jul 10th, 2009 1:11 pm
Help with ABS LT2B K1200LT 15 Jun 16th, 2006 1:22 am
Manual, ABS lights, and power windscreen pwwoolsey K1200LT 8 Oct 10th, 2005 4:45 pm
