Is it ok to go back to regular oil? - BMW Luxury Touring Community
post #1 of 19 Old Dec 22nd, 2005, 7:23 pm Thread Starter
After reading up on synthetic oil here I went ahead and switched over on my '05 LT. Runs great. Unfortunately, I then found another thread that says don't run synthetic until the bike hits 18k miles. Heh. Now they tell me. I only have 7500.
Is it ok to go back to regular oil or should I just stick with it the way it is?
rtfs is offline
post #2 of 19 Old Dec 22nd, 2005, 7:59 pm
murray's Avatar
Smile
There is a lot of controversy on this subject. The issue is related to new motor Run In. If you aggressively ran the bike with on off full throttle sprints then allowing to cool your rings seat very fast. If you babied the bike you might not develop optimum combustion chamber sealing. If your bike does not use oil chances are you are OK. I know others will chime in on this one.
Good Luck
Pete Murray
murray is offline
post #3 of 19 Old Dec 22nd, 2005, 8:08 pm Thread Starter
I did my fair share of open throttle sprints...
But yes, it did use a small amount of oil even before the changeover to synthetic. Unfortunately, I can't say how much over how many miles but I don't think it was excessive.
rtfs is offline
post #4 of 19 Old Dec 22nd, 2005, 8:29 pm
gunny's Avatar
My opinion..... Probably won't make any difference that you'd be able to detect.
gunny is offline
post #5 of 19 Old Dec 22nd, 2005, 9:41 pm
If you do decide to "go back"...why not first go with a semi-synthetic (dino/synth blend)? Then, at 12K you can go with dino. Then at 18K, go back to the full synth.
Personally...I say, "FORGET ABOUT IT!". But, what do I know?
post #6 of 19 Old Dec 22nd, 2005, 11:37 pm
cuffer101's Avatar
My dealer switched my oil at 6,000 miles. He said dont worry about it, it will be fine.
cuffer101 is offline
post #7 of 19 Old Dec 22nd, 2005, 11:53 pm
bmwrider79's Avatar
If you had a older certain brand of a V-twin you would only have to worry about adding and not changing oil
Seriously regular changing of the oil form synth to dino should not be problem. The synth will by theory alone delay the initial wear of the components. This is due to the inherient increased lubricity of synth oils.
it is better to change dino every 3k than keep synth in there for 12k
Changing oil regularly removes the nasty stuff that is the by product of the internal combustion engine that will degrade the oils lubricating properties.
Just MY opinion.
FWIW I use synth and change oil & filter every 6k.
Synth is better for the following reasons:
better lubricity
higher much higer temperature tolerance
flows much better when cold.
Holds up under pressure better than dino
That is why jet engines use synth.
Changing oil is far cheaper than an engine rebuild even synth.
Mike G
Northen Illinois Packer Fan
K1200lt 2002
LT Trunk Latch Maker
bmwrider79 is offline
post #8 of 19 Old Dec 23rd, 2005, 1:03 am
It's been said here before
Just Ride It!
Duane
Check the obvious first!
73 Z1 Kawi
and 7 long gone
Dman is offline
post #9 of 19 Old Dec 23rd, 2005, 8:49 am Thread Starter
Thanks for the responses. Since no one was vehemently opposed to going back to dyno oil or strongly recommending going back, I'll just leave it as it is - at least until the next change.
The weather is looking good for a ride the next couple days - now if I can just get it out of the garage - any suggestions on eliminating a 1" layer of ice on a gravel driveway?
rtfs is offline
post #10 of 19 Old Dec 23rd, 2005, 8:52 am
Steve_R's Avatar
How about
A blow torch or maybe a flame thrower
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #11 of 19 Old Dec 23rd, 2005, 8:52 am
home
...any suggestions on eliminating a 1" layer of ice on a gravel driveway?
I got nothin'!
post #12 of 19 Old Dec 23rd, 2005, 8:57 am Thread Starter
Funny! Those are the very thoughts I had this morning while I was waiting for my shop light to melt it's little circle.
rtfs is offline
post #13 of 19 Old Dec 23rd, 2005, 9:01 am Thread Starter
Originally Posted by messenger13
home
I got nothin'!
OMG! You're a braver man than I. I wouldn't even attempt that.
rtfs is offline
post #14 of 19 Old Dec 23rd, 2005, 2:36 pm
It's fine, with a little skill, and luck, and the multiple Motolights aimed just right for maximum melt efficiency.
post #15 of 19 Old Dec 23rd, 2005, 4:26 pm
Daman858's Avatar
You will be just fine. Porsche and Corvettes come from the factory with synthetic, for crying out loud.
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #16 of 19 Old Dec 23rd, 2005, 4:28 pm
Angry
Ew!!! You just compared a bike to a cage! You outta be LOCKED UP!!!
post #17 of 19 Old Dec 23rd, 2005, 5:05 pm
True. We all know a Porsche will beat the snot out of an LT.
post #18 of 19 Old Dec 23rd, 2005, 5:16 pm
Smile
changed over to synth at 1k miles... Aggressive break in... have 10k now
Zero oil usage... should be fine....Don't worry...!!!
superd is offline
post #19 of 19 Old Dec 23rd, 2005, 6:03 pm
Senior Member (ret.)
RaffyK's Avatar
RaffyK is offline
Thank Heaven Joe is back!! airborneod Chit Chat 2 Nov 4th, 2005 5:49 pm
Sore Back?? bulletbill K1200LT 15 Nov 3rd, 2005 12:11 pm
I am back Two Wheeling again meinen K1200LT 3 Oct 27th, 2005 5:05 pm
