Handle Bar Extension Success - BMW Luxury Touring Community
post #1 of 17 Old Dec 22nd, 2005, 6:01 pm Thread Starter
Thumbs up Handle Bar Extension Success
As posted earlier I have now successfully extended my handlebars 1.5 inches using the following method.
Remove handlebar covers and you will note that the bars reduce from 1.125 OD to 0.875 OD. From this reduction point to the bend in the bars (where the grips are) there is 1.6 inches of straight 0.875 OD tubing. Cut this tubing at the center point which is .80 inch from the reduction point. (before you do this remove the heated grips as the wiring for these runs through the bars -{ please don't ask how I found this out ...LOL } Referrence all points with a marking pen so that you can re-align everything.
Purchase six inches of steel tubing with an ID of 0.875 inches and cut this into two 3 inch pieces. Slide the 3 inch tube onto the stub on the bars and then slide the other stub that is holding the controls into it. I used this opportunity to angle the handgrips up slightly as I find this more comfortable. I used JB Weld and then ran a rolled spring pin through each joint (this is not a location that I want to have come apart at any speed).
It was necessary to "tweak" the plastic bar covers but this allows for space for Ram Mounts for more farkles.
It's amazing what a difference an inch and a half makes (that ought to get a few reactions !!)
I hope that the attached photo's make my dis-jointed instructions clear.
jorawro is offline
post #2 of 17 Old Dec 22nd, 2005, 6:08 pm Thread Starter
Unhappy Photo's this time?
Lets try this again with a smaller file size.
Name:	Site photo 1.jpg
ID:	1248   Click image for larger version
Name:	Site photo 2.jpg
ID:	1249   Click image for larger version
Name:	Site photo 3.jpg
ID:	1250   Click image for larger version
Name:	Site photo 4.jpg
ID:	1251   Click image for larger version
Name:	Site photo 5.jpg
jorawro is offline
post #3 of 17 Old Dec 22nd, 2005, 9:07 pm
grifscoots's Avatar
You're the man! Good job!
-=grif=-
Grok
grifscoots is offline
post #4 of 17 Old Dec 22nd, 2005, 9:18 pm
RVB1019's Avatar
Nice Job Roy!!!!!!!!!!!!!!!!1
Can you please take a pic that shows both handle bars with the covers? Maybe from the drivers seat? I might attempt this mod this winter!
Rob V.B.
2015 Triumph Explorer 1200
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #5 of 17 Old Dec 23rd, 2005, 2:26 am Thread Starter
Rob - The bike will not be back together until February as all the pieces are at the painters. I will post a completed photo as soon as possible.
jorawro is offline
post #6 of 17 Old Dec 23rd, 2005, 5:47 am
You're a brave man - nice job. Does your twist grip still rotate freely and snap shut when released? The acid test will be seeing if your cruise control still works in February!
beemerlt is offline
post #7 of 17 Old Dec 23rd, 2005, 6:03 am
murray's Avatar
Smile
Nice job, You may have to re route the cables to get proper free play at the grip. The cruse control cable itself(bowden cable) is not effected. But as David said the twist grip has to be right, If not CC problems
Pete Murray
murray is offline
post #8 of 17 Old Dec 23rd, 2005, 7:36 am
Top work!!
a gallon of JB weld hold damn near anything in place.
I swear by the stuff
Dezrae is offline
post #9 of 17 Old Dec 23rd, 2005, 7:45 am
grifscoots's Avatar
Originally Posted by Dezrae
Top work!!
I'm gonna make a bike out of it!
-=grif=-
Grok
post #10 of 17 Old Dec 23rd, 2005, 1:14 pm Thread Starter
Thanks David & Pete. I should have mentioned this in my first post. I have ordered new throttle cables (mine are and always have been stiff) and I will be re-routing them slightly to accomodate for the increased length.
jorawro is offline
post #11 of 17 Old Dec 23rd, 2005, 1:39 pm
Top work!!
Maybe so, but on things like handlebars, I'd feel a lot more secure with a good old fashioned WELD.
Tat_n_Telle is offline
post #12 of 17 Old Dec 23rd, 2005, 2:10 pm
JPSpen's Avatar
That's what I was going to say
I wouldn't trust my life to JB weld....I'd take the bars to a welder and have the mod made permanent.....but the theory looks good...
Spence
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #13 of 17 Old Dec 23rd, 2005, 2:20 pm Thread Starter
Lightbulb
Looks like you missed the point in the original post --- in addition to the JB Weld I also used rolled spring pins.
jorawro is offline
post #14 of 17 Old Dec 23rd, 2005, 3:59 pm
Thumbs up
Roy, Before you install the new throttle cable's. Are the cables the 05 version? I installed the 05 cables huge improvement.
Pete Murray
PeteM is offline
post #15 of 17 Old Dec 23rd, 2005, 4:10 pm
Pete Murray
Agreed. The metal guides in the '05 throttle cables swivel, which should allow you more reach with less binding than the older, hard-plastic guides.
post #16 of 17 Old Dec 23rd, 2005, 8:10 pm
JPSpen's Avatar
Nope didn't miss it
Don't get me wrong... <g>
It's a great solution to the problem with the exception of the jb weld....the pins probably won't shear off in a collision but I just wouldn't trust it......
Any engineer here is gonna tell you that your mod is unsafe the way it is...
No manufacturer would put a set of bars together with pins and epoxy.....
Now Maybe your arms will break before the bars snap off and you impale yourself on the remains but 20 bucks at the welder and it'll be fer sure fer sure..........
I just think something as important as the handle bars should be welded that's all... Your idea is great and I certainly admire your ingenuity.
Just worried about your life bro...
Spence
JPSpen is offline
post #17 of 17 Old Dec 23rd, 2005, 8:37 pm
murray's Avatar
Smile
Axial Tilt is the real reason for the season.
23.5 degrees is the truth
I am not in favor of Axial tilt ,I guess we have to wait until April for Axial realignment.
Pete
murray is offline
Side Stand Extension tyroneteeth Other Stuff 10 Aug 3rd, 2007 7:52 am
Rider Pegs Extension rlv Ergonomics & Rider Comfort 8 Nov 30th, 2005 6:31 am
Spare chrome handle for the trunk buffalo K1200LT 6 Oct 18th, 2005 8:17 am
My LT handle now in good hands lagodue Chit Chat 0 Oct 8th, 2005 8:38 pm
Chrome handle on Top box beemer666 K1200LT 4 Oct 1st, 2005 7:56 pm
