Flag Mount - BMW Luxury Touring Community
post #1 of 6 Old Apr 13th, 2008, 12:18 pm Thread Starter
yeoman_kp's Avatar
Flag Mount
Anyone have a good idea for mounting a flag on an LT? I'm planning on going to Rolling Thunder and I thought it would be nice to wave Old Glory on the demonstration route.
yeoman_kp is offline
post #2 of 6 Old Apr 13th, 2008, 12:27 pm
Re: Flag Mount
The third and fourth threads listed under your post, in the 'Similar Thread' block, contain discussions from May of 2007 about the flag mounts. HTH.
post #3 of 6 Old Jul 26th, 2008, 3:45 pm
rkirker's Avatar
Re: Flag Mount
I struggled with this for a while and this is what I came up with.
I decided to mount mine on the plastic luggage rack on the trunk.
I am worried about the plastic cracking, but I have not over torqued it and being right in the center of the rack the flag does not wip in the air flow like some others flags I have had on some bikes.
I took a Honda flat rack 8 " folding mount kit (678-010 Add on Inc. $40 at Honda Home coming) took off the square mounting bracket from the bottom and tossed it in the can, but kept the bolt.
Took off the rack flipped it over with a towel over the trunk and removed the top plastic chrome part (about a dozen screws and bolts on the bottom side of the chrome plastic)(When you put it back together you need to place it up right to get the bolts to mate with the nuts again as they are loosely fit into the chrome plastic and will not engage the bolt without gravity holding them down).
Then I put some masking tape on the chrome side and started with a 1/8 then 1/4, 3/8 drill bit from the chrome side down progressively making the hole large enough for the bolt to fit up through the bottom into the base of the pole.
The pole can be folded down when the cover is put on. Those Honda Guys thing of everything !!
Here is what it looks like.
ID:	18849   Click image for larger version
ID:	18850   Click image for larger version
Rich Kirker
2002 LTC Pacific Blue
Caliper Moto Lights, Hyper light brake lights, Spiegler brake lines, Ride West side markers, Grip puppies, HyperPro Springs and CA HID Kit.
BMWMOA #124306
2009 Honda Shadow (Wife's)
Blue & Pearl
"Well Itís not rocket science but absolutely a nightmare. At the end of the day you had a fairly unique situation that I personally at this moment in time could see me having as well 24/7. With all due respect, it shouldnít of happened."
rkirker is offline
post #4 of 6 Old Jul 26th, 2008, 5:01 pm
Re: Flag Mount
The typical automobile window flag will fit under the top case lid. May require minor trimming of the flag mount, but the case will close and not damage anything.
Steve
04 LT
xenia is offline
post #5 of 6 Old Jul 27th, 2008, 8:41 am
rkirker's Avatar
Re: Flag Mount
Steve
04 LT
Steve I have done that but I don't like the looks of the setup.
Rich Kirker
BMWMOA #124306
Blue & Pearl
rkirker is offline
post #6 of 6 Old Jul 27th, 2008, 10:10 am
LAF
LAF's Avatar
Re: Flag Mount
Nicely done. About the first thing I have seen I like. I would be a bit concerned on the plastic but I wonder if a sleeve a bit higher then the plastic would help. At least you would tighten on it, rather then the plastic, even a plastic fish hose tube or bigger would give support. Just a thought as I plot my copy kat install
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
GPS mount photos bruce2000ltc GPS 14 Apr 9th, 2015 2:40 am
Flag Pole for the LT unleashd Other Stuff 16 Jul 21st, 2009 2:34 pm
GPS mount, easy low cost Tourdog GPS 3 Jun 23rd, 2007 1:43 pm
Flag Pole Trunk Mount type bibleman Other Stuff 8 May 9th, 2007 8:50 am
376C, 276C Marine Mount on LT jpalamaro GPS 0 Oct 9th, 2005 12:14 pm
