2005 Center Stand Problem? - BMW Luxury Touring Community
post #1 of 7 Old Apr 10th, 2008, 10:29 am Thread Starter
Today I stopped and tried to use the center stand. Nothing. The light blinked on the dash but it didnt engage. Then I drive to work and it works fine. Could this have been caused by a weak battery since the bike had been sitting a week? I replaced my OEM seat yesterday and had to remove the heating cable from under the left upper panel. Is the CS control wire located in there as I might of pulled something loose? Thanks in advance.
hifiman is offline
post #2 of 7 Old Apr 10th, 2008, 2:31 pm
joegottberg's Avatar
Re: 2005 Center Stand Problem?
I don't remember the wire path, but, I doubt you hurt it.
The plug at the stand is fairly robust (PITA to remove).
Mine will occasionally not work (even though light flashes) and every time its my fault If you touch the brake lever, happens to be slightly in gear, side stand down, moving, not hold your mouth right, whatever, it will flash but not lift.
For me if I let go of the switch and get everything "ready" I hear the whir and up she goes
Try that and see if the problem goes away.
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
joegottberg is offline
post #3 of 7 Old Apr 10th, 2008, 5:22 pm Thread Starter
It was the brake pedel. Didnt know I could not do that. Thanks for bringing it to my attention.
hifiman is offline
post #4 of 7 Old Apr 28th, 2008, 8:50 pm
BushWacker's Avatar
Mine did this for a while and it stopped working completely today. 2005 LT w/22k miles
BushWacker
"Let's ride we're burnin' daylight!"
BushWacker is offline
post #5 of 7 Old Apr 28th, 2008, 11:52 pm
WildBil's Avatar
Has it happened again since the first time? There are a couple of interlocks, like the sidestand being out or the transmission in gear or even a smidge out of N. - Bill
WildBil is offline
post #6 of 7 Old Apr 28th, 2008, 11:58 pm
Could also be the brake lights... yup... seems folks have changed the lights to LED's... seemed to work fine... then the HCS quit working properly.. I dunno, maybe check the lights to be sure they are working properly...?
J.M.J...
Dcn Channing
post #7 of 7 Old Apr 29th, 2008, 11:02 am
If it just flashes and no lift, think interlock.
If it makes the "whirr" but no uppy, think oil leak.
If no light at all, there has to be a fuse, wire, or other disconnect.
Joe
2005 KLT "Old Blue"
Bruno the "Bugg"
2002 k1200ltc center stand retrofit? rogerK K1200LT 14 Nov 26th, 2008 12:07 am
2002 Model Center Stand Broke MattKas K1200LT 7 Nov 6th, 2006 1:37 pm
Center Stand Lubrication for Pre 2005 MattKas K1200LT 9 Oct 19th, 2006 1:16 pm
2005 ElectroHydrolic Center Stand Fails leckhart K1200LT 5 Aug 21st, 2006 10:07 pm
2005 Center Stand Lubrication rebentman K1200LT 0 Apr 20th, 2006 9:56 pm
