Tire Replacement, wheel removal - BMW Luxury Touring Community
post #1 of 5 Old Apr 8th, 2008, 6:54 am Thread Starter
justlookin's Avatar
I'm sure this has been posted and answered, but I did not find it searching..
I was going to take the wheels of my LT to save a few $$ on the tire swap.
Anything particularly tricky about removing & replacing the wheels.
I've never taken them off the LT, my concern is ABS..
Jeff
08 R1200GSA
04 K12LT (Sold)
97 R1100GS (Sold)
SS1000--IB # 32778
justlookin is offline
post #2 of 5 Old Apr 8th, 2008, 7:11 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
Re: Tire Replacement, wheel removal
Jeff, That's an easy job.
Rear : put bike in gear remove 2 screws on lic plate. Then the 5 lug bolts and roll the rear wheel out. look for the wheel spacer ( looks like a large washer)so not to loose it.
front : put a small jack under the engine to raise frt wheel. remove fender, 4 bolts 2 on top and 1 on each side then there are 2 locking bolts(1 on each fork) to remove. unbolt the 2 calipers (2 bolts each) Remove axle shaft, 1 bolt on 1 side then pull axle out. With a screwdriver spread the brake pads out to give you room to clear rotors and remove wheel.
When you put it back together be sure to pump your front brakes up a few times to push the pads back out before you go for a ride
Stevie Shreeve
katnapinn is offline
post #3 of 5 Old Apr 8th, 2008, 8:27 am
zippy_gg's Avatar
Post Re: Tire Replacement, wheel removal
+1. I would suggest to first remove the rear wheel and then the front. It will be helpful to put the bike in gear before you try to remove the 5 bolts of the rear wheel.
Remember that the ABS ring is on the left side of the front wheel and tell the technician so he can mount the tire in the correct rotational direction. That can avoid the frustration of having to re-mount the tire.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #4 of 5 Old Apr 8th, 2008, 12:55 pm
PMitchell's Avatar
Just did it last week-end.
Piece of cake except the rear lugs are really tight. The tighten up torque is 76 ft. lbs/
There are also values for the front brake calipers, pinch screws and the left axle hub.
I'd follow the values (pdf file in files menu on this site) so them round things don't come off go'in down the byways!
Took my rims one at a time to a local multi-brand dealer near work recommended by Messenger 13. $25 plus tax ($1.50 disposal fee also)
pm
Ride till you can't!
"Der Weg ist das Ziel"
2006 Tuscany
2008
2011 South Africa
'18 R1200RTW
Sold in '67
PMitchell is offline
post #5 of 5 Old Apr 8th, 2008, 1:13 pm
dmatson's Avatar
One of the easiest bikes i have ever done. One little trick for the front calipers is after you unbolt them rock them back and forth slowly to compress the pads, as they compress you will be able to just lift the calipers off. Make sure no body touches the brake lever or pedal.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
Front wheel removal eibacher K1200LT 20 Dec 13th, 2012 10:56 pm
Tire changing my way CharlieVT Bike Talk 7 Apr 11th, 2007 12:25 pm
Tire Repair warning from Dunlop cfell Tires 3 Dec 3rd, 2006 7:35 pm
Tread Depth on Front Tire Prior to Replacement tarheel_rider Tires 6 Sep 11th, 2006 10:42 pm
Bridgestone BT020R 160/70R-17 tire failure. mudman Tires 23 Aug 28th, 2006 3:36 am
