65 watt H7 high beam bulb? - BMW Luxury Touring Community
post #1 of 11 Old Mar 26th, 2008, 1:33 pm Thread Starter
yechave's Avatar
Does anyone have any knowledge about or has used this bulb?
http://cgi.ebay.com/ebaymotors/ws/eB...link:middle:us
yechave is offline
post #2 of 11 Old Mar 26th, 2008, 4:03 pm
PATTERSON's Avatar
Re: 65 watt H7 high beam bulb?
Sorry.....I haven't ever used that bulb....I installed the HID's almost 2 years ago, and won't use anything else now.
Just a word of caution.....you may have wiring problems with the harness if it's not upgraded to handle the extra wattage.....I know it's not much more draw.....but folks have melted their harnesses after putting a bigger bulb in there.
Maybe somebody with a bit more electrical experience will step in here and clarify things for you.
Pat
Patterson/USAF1....'05 LT
and the little guy behind me is the world famous "Marty Hill"
Never look into a lazer with the remaining eye
363K on BMW's
PATTERSON is offline
post #3 of 11 Old Mar 26th, 2008, 4:22 pm
Cat Herder
andy's Avatar
3 words of advise:
Don't do it!
anything more in thermal load (meaning more than 50W) in the small space WILL damage the reflector. Depending on your model between $200 and $350
andy is offline
post #4 of 11 Old Mar 26th, 2008, 5:53 pm Thread Starter
yechave's Avatar
Thanks!
I will have to make do with what we have for now.
yechave is offline
post #5 of 11 Old Mar 26th, 2008, 6:20 pm
zippy_gg's Avatar
Exclamation Re: 65 watt H7 high beam bulb?
The item on eBay is an H7 bulb, which is for the low beam on all years LT, however you quoted "65 watt H7 high beam bulb?"
Also the eBay item costs $45.00. For another $30,00 you can get an HID low beam kit, so why bother with a higher wattage bulb that will only provide a marginal light gain? Go HID, you won't be sorry. Attend a local tech session and install it yourself under the supervision of someone who has done it.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #6 of 11 Old Mar 26th, 2008, 8:20 pm
Originally Posted by andy
3 words of advise:
Don't do it!
Not necessarily so Andy. I ran a 70 watt low beam bulb for nearly two years before I upgraded to low beam HID, and kept an 85 watt high beam in place for over 4 years, never had any problem with the reflector.
85 watt high beam seemed to be OK since high beam is not usually on for long lengths of time, the 70 watt low beam I would consider the upper limit, since I had no problems, but a couple of people who tried 85 to 100 watt low beam bulbs did destroy the reflectors.
I surely do recommend HID though, instead of higher wattage bulbs, which only marginally help. My 85 watt high beam bulb looked like a yellow candle in comparison to the 35 watt HID low beam!
post #7 of 11 Old Mar 26th, 2008, 8:36 pm
Cat Herder
andy's Avatar
You are right. He can roll the dice.
On that account: I have heard some smokers are still healthy.
<steps off the soapbox>
andy is offline
post #8 of 11 Old Mar 27th, 2008, 8:08 am
patroa1's Avatar
I agree with Zippy, for $30 more just go with the HID low beam and be done with it. You'll spend more dinking around with higher wattage bulbs and never be satisfied. So spend the $75 and an hour for the install and get the HID's you won't be sorry.
Here's a pic of mine with HID low beam. BTW the ones under the tip over wings are H-3 halogen's and look yellow by comparison.
Pat Rourke
White Lake,MI.
2002 K1200 LTC, Champange
patroa1 is offline
post #9 of 11 Old Mar 27th, 2008, 8:12 am
378
Where can I buy the kit for $75? How much more for the High Beam?
378 is offline
post #10 of 11 Old Mar 27th, 2008, 9:17 am
zippy_gg's Avatar
Lightbulb Re: 65 watt H7 high beam bulb?
Patroa1 organized a group buy that you can look up on this forum. The price for the high beam will be the same but you need to specify which bulb. If your bike is an 04 and earlier you will need an H3 bulb, if it is an 05 and newer you need an H9 or an H11 if they don't carry the H9.
Stay with 4300K, or at a max 5000K and you will have bright white lights!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #11 of 11 Old Mar 27th, 2008, 9:24 am
patroa1's Avatar
Check this out. http://www.bmwlt.com/forums/showthread.php?t=22443 post #18.
The high beam should be the same price. You might want to give them call as they have a car kit for $119, they may let you mix the bulbs ( H-7 & H-3 etc. )
Pat Rourke
White Lake,MI.
patroa1 is offline
Source for H9 High Beam bulb??? Micky K1200LT 5 Nov 29th, 2007 5:54 pm
High beam bulb bobbobtar Lighting 7 Mar 19th, 2007 9:36 pm
CQ HID High Beam installs.... BillyOmaha Lighting 7 Mar 7th, 2007 12:14 am
HID High Beam on '99 LT dlbushey Lighting 4 Jan 24th, 2007 9:56 pm
change high beam lights bulb H3 jac Lighting 17 Aug 2nd, 2006 7:25 am
