05 Shift Linkage Help - BMW Luxury Touring Community
post #1 of 8 Old Mar 20th, 2008, 3:38 pm Thread Starter
mos
I have a 05 KLT. I am checking the shift linkage and going to clean and grease the ball joints. I am having a hard time taking the pin out of the ball . I have Paul Sayegh's DVD to guide me . The pin just does not want to come out . Help
mos is offline
post #2 of 8 Old Mar 20th, 2008, 4:57 pm
zippy_gg's Avatar
Exclamation Re: 05 Shift Linkage Help
The pin is a bit tricky to remove as you need to pivot it out before pulling out straight.
Of course this becomes obvious... after the pin is removed and it is much easier to put back in when you are done.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 8 Old Mar 20th, 2008, 5:24 pm
Axle's Avatar
yep once you get the first one it will become easy I think you just twist it off the ball then lift straight out and reverse to install good luck
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
post #4 of 8 Old Mar 20th, 2008, 6:16 pm Thread Starter
mos
I did rotate the pin and pulled straight up on it ...it is not moving ....maybe it is bent .... I see what looks like a bolt that holds the linkage to the plate . If I remove that it looks like the shifter and linkage will come off the plate . Is that right?
mos is offline
post #5 of 8 Old Mar 20th, 2008, 7:19 pm
Often this happens with side force on the joint. I had a miserable time on my first go at it. It was seriously bent, the clip that is. There was just not enough room for my meat hooks to get in there.
I have since found the best way is to remove the lower faring so you don't have to pull out ward on the plate. This prevents bending the clip. This will also give you enough room to pull the clip on the other end of the rod. Once you have the plate off the bike it is easier to use a pair of pliers to remove the bent clip.
Also look here for more info:
Linkage Article
post #6 of 8 Old Mar 20th, 2008, 9:38 pm
dglenn1's Avatar
I need to compress the ball joint together in order to slide the pin out. I don't know many who have the same issue as I do so you might be another one with this tight fit problem. Once I take out the pin the joint pops right apart indicating there is some pressure in there putting resistance on the pin. Same procedure for installing it. there is no way that pin is going in without holding the ball and socket tightly together with pliers or a clamp.
Dan
2005 K1200LT - Ocean Blue
; Nolan 103 Helmet w/Bluetooth;
and
(Secures gear/luggage);
; Droid X (Replaces
and factory radio);
(Not installed);
(Currently unistalled),
; Clymer Manual; BMW Service DVD
dglenn1 is offline
post #7 of 8 Old Mar 21st, 2008, 6:53 am Thread Starter
mos
Did any body reuse the dent clip or just replace it with a new one ?
mos is offline
post #8 of 8 Old Mar 21st, 2008, 7:35 am
nascar0699's Avatar
You could buy a new set of linkage powergrid and have maintenance free and be able to adjustment for the shifter,
nascar0699 is offline
Shift linkage lube - it's a sinch! Zotter K1200LT 14 Jun 20th, 2008 1:26 pm
Shift Linkage reassemb. - Did I do it right? BobbyLT K1200LT 4 Aug 16th, 2007 3:58 pm
shift linkage adjusting Reid K1200LT 12 Oct 16th, 2006 2:11 pm
Shift Linkage Broken carl_k1200 Bike Talk 4 Jul 17th, 2006 9:48 am
Broken Shift Linkage zaphod K1200LT 3 Jun 13th, 2006 5:03 pm
