cracked engine cover - BMW Luxury Touring Community
post #1 of 11 Old Mar 18th, 2008, 8:17 am Thread Starter
any one got suggestion for welding damaged rocker cover
one inch crack from protection bars following slow off --embaressed yes
gary4photos is offline
post #2 of 11 Old Mar 18th, 2008, 9:18 am
gunny's Avatar
Re: cracked engine cover
I don't believe I'd try to weld that. A 2 part epoxy like J B Weld would be what I'd use.
B D R
gunny is offline
post #3 of 11 Old Mar 18th, 2008, 9:52 am
lucky26's Avatar
J. B. Weld is good and should be available in Sydney.
There is another product called Insta-Fix you might want to consider. It is new from Canada and becoming available in the US through HD Supply, I do not know if it is available in Australia yet however I will find out and let you know.
This is the web page http://www.insta-fix.com/
Click on the video and it gives some ideas including fixing a head on a small engine, so you should be able to use it to fix a cracked cover, or anything else.
lucky26 is offline
post #4 of 11 Old Mar 18th, 2008, 10:02 am
JPSpen's Avatar
A propane torch and this stuff right here will fix you up.
91 R100GS "It'sNotAMoneyPit"
JPSpen is offline
post #5 of 11 Old Mar 18th, 2008, 10:14 am
should work.. but, please, take the cover OFF the bike...
J.M.J...
Dcn Channing
post #6 of 11 Old Mar 18th, 2008, 10:17 am
JPSpen's Avatar
Posted by Channing...
Forgot to include the obvious. The lawyers will be calling soon.
I've used this stuff or some other form of it several times over the years and it is the permanent repair you are looking for.
JPSpen is offline
post #7 of 11 Old Mar 18th, 2008, 10:40 am
ArthurKnowles's Avatar
Personally, I would not weld the cover when replacements are availble from used sources (ebay, ltparts.com, etc.) at reasonable prices.
ArthurKnowles is offline
post #8 of 11 Old Mar 18th, 2008, 4:32 pm
Moonshine's Avatar
Thumbs up Re: cracked engine cover
Not a problem welding motorcycle aluminum side covers, I have done it several times using a TIG welder. I am under the impression that the engine covers on the LT are magnesium which to can be welded easily using a TIG welder. But you may be able to repair it without removing it by using JB Weld if the crack is not located near a bolt hole.
--Thats OK I don't care--
Moonshine is offline
post #9 of 11 Old Mar 19th, 2008, 12:43 am
Eric_R's Avatar
Doesn't magnesium burn???
2002 K1200LTC Ocean Blue
Eric_R is offline
post #10 of 11 Old Mar 19th, 2008, 7:51 am
grifscoots's Avatar
Yep, but it TIGs just fine. I don't think I'd take my oxy-cetylene to it.
Come to think of it, just about everything burns at the right temp.
-=grif=-
Grok
grifscoots is offline
post #11 of 11 Old Mar 19th, 2008, 10:28 am
Eric_R's Avatar
Doh!
Inert Gas, now I remember.
No wonder my HS shop teacher always told "get away from the wheelbarrow boy, you don't know nuthin' about machinery"
Eric_R is offline
Trike cover modifications Triker Trailers, Sidecars, & Trikes 2 Jun 1st, 2008 1:26 pm
Shaking on the handle bar at 65km/h (around 43miles/h) jusufbw K1200LT 1 Nov 26th, 2007 4:37 am
Missing bits... cfell BMWLT Site Support Forum 3 Oct 9th, 2007 10:51 pm
Running Engine Speeds rglassma K1200LT 3 Jul 15th, 2007 8:57 am
