Revealing My Ignorance - BMW Luxury Touring Community
post #1 of 22 Old Dec 11th, 2005, 5:51 pm Thread Starter
Gene
pavehawkfe's Avatar
O.K. guys, I'm just ignorant not stupid and not having an owners manual doesn't help. But where is the engine oil filler cap located?
Gene
pavehawkfe is offline
post #2 of 22 Old Dec 11th, 2005, 5:56 pm
CharlieVT's Avatar
Oil fill cap and sight glass
Right side of bike down low looking through an opening in the right side plastic.
You need a funnel to get oil in and a flashlight to see the oil sight glass.
HTH
CharlieVT is offline
post #3 of 22 Old Dec 11th, 2005, 6:03 pm
fill level
Fill to about 1/2 to 2/3 covering the sight glass. 1/2 is fine but I run mine at about 2/3.. it's a 2005.
J.M.J...
Dcn Channing
post #4 of 22 Old Dec 11th, 2005, 6:16 pm
BTW, check the oil on the centerstand, fill the fuel on the sidestand.
Keith is offline
post #5 of 22 Old Dec 11th, 2005, 7:27 pm
BecketMa's Avatar
Have you found the rear trunk mirror yet?
One day I noticed the funny lookin bolt, discovered it was loose, and went to tighten it.
Vuala! A hidden mirror!
It took a while before I learned that the fluid behind the glass in my saddle bake was for the cooling system.
Merry Christmas from sunny Tucson
BecketMa is offline
post #6 of 22 Old Dec 11th, 2005, 7:48 pm Thread Starter
Gene
pavehawkfe's Avatar
Thanks everyone. Found the mirror right away, and the filler for the antifreeze, but I was looking all over the bike today for a traditional oil cap. If I hadn't broke down and revealed my ignorance, I'd still be looking.
Gene
post #7 of 22 Old Dec 11th, 2005, 7:58 pm
mneblett's Avatar
Gene
Don't worry, you've joined a bunch of ignorant folks here! I lead the Central East Coast Ignoramous Chapter Ya can't learn without asking questions. Welcome to the zoo!
Mark Neblett
Fairfax, VA
mneblett is offline
post #8 of 22 Old Dec 11th, 2005, 8:46 pm
Exclamation
!!!!! DO NOT OVER FILL!!!!!!!! ........Regards Pete
petepeterson is offline
post #9 of 22 Old Dec 11th, 2005, 9:04 pm
Miles of Smiles
Hilton's Avatar
Ya just gotta ask
Ask a stupid question, and appear a fool for one minute.
Don't ask and remain one forever. ( Always liked that saying )
The collective wisdom on this site is awesome !!!!
And dispensed by some of the best folks I've met.
Cheers and enjoy the ride.
Hilton is offline
post #10 of 22 Old Dec 12th, 2005, 6:52 am
pkpr1998's Avatar
Smile
That's easy for you to say!
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
2014 CCR-Chattanooga
2015 CCR-Coeur d 'Alene
pkpr1998 is offline
post #11 of 22 Old Dec 12th, 2005, 7:25 am
Steve_R's Avatar
Hey Gene, How much tupperware do you have to remove to find a oil filler cap on a H-60??
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
post #12 of 22 Old Dec 12th, 2005, 10:46 am
My wisdom
Ok guys this thread was started by a newbie. In my soap box.
Wonder how you can measure how much oil goes into your motorcycle via the sight glass? 1/2? 2/3?.
The "manufacturer" of this motorcyle design, built, tested this engine to run with 4 quarts of oil. Done, That's it, I don't care how cooler, hotter, lighter, heavier the bike will run with .71 or .69, or even .00000003 quarts less in the engine. When telling someone new how much oil to put in would it not be safer, easier and a lot less 1/2? 2/3? measuring of a sight glass you can't even reach, if they just put what the "manufacturer" tells them to.
And ride safe.
Out of my soap box.
Darcy Bastos
2007 FJR1300
2007 Ducati GT1000 Sport Classic
Atlanta, GA
ATLDB is offline
post #13 of 22 Old Dec 12th, 2005, 11:13 am
mneblett's Avatar
Ah, if life were always so simple.
BMW didn't design this bike around the concept of 4.0000 qts of oil in the crankcase (and if they did design for a specific oil quantity, wouldn't you expect it to be in liters, as in 4.0000 L)?). Besides, after the initial fill, you'd never know how much is in the crankcase, even if you put 4.0000 qts in, due to the residual left behind when the cranckcase has drained. People attach far too much significance to specific numbers without considering either the objective or the tolerance range surrounding the specified quantity. In fact, "just put in 4 qts" during an oil change will, on many (most?) bikes result in the oil level being out-of-sight high.
A far better indication of what BMW "designed" the engine for is built into the side of the engine -- a sight glass that includes BMW's desired oil level within its indicating range. You won't find much better proof that BMW doesn't want a specific volumetric quantity thrown in without regard to the actual engine needs. Instead, they want you to ensure the oil level is within a specific range, defined by the sight glass, i.e., within a +/- tolerance represented by the top and bottom of the circle in the sight glass.
So, the original suggestion of 1/2-2/3 of the sight glass remains good newbie guidance (particularly for new engines, which will burn off a bit of oil during the first 10-15K miles of break-in -- 2/3 provides a bit more "buffer" in case the newbie doesn't check the level often).
Mark Neblett
Fairfax, VA
mneblett is offline
post #14 of 22 Old Dec 12th, 2005, 11:43 am
Wink
And remember, There is no sense in being dumb if you can't let it show!!
Jon Bush
' 09 RT
"SAPHIRE"
bushj1 is offline
post #15 of 22 Old Dec 12th, 2005, 2:35 pm
Now that's funny!
Jerrod Maguire is offline
post #16 of 22 Old Dec 12th, 2005, 4:51 pm
Ignorance isn't not asking the question ignorance is not even knowing the question exists. Now stupidity, that may be not asking the question and for sure is another whole can of worms!!!!!!!
Earl J. Reber
2005 K1200LT Ocean Metalic Blue
1998 Honda Shadow Aero
1949 Cessna 195
1966 Citabria 7ECA
n3716e is offline
post #17 of 22 Old Dec 12th, 2005, 5:33 pm
grifscoots's Avatar
Holding my breath here as this is coming purdy close to becoming an oil thread. (am I purple yet?)
-=grif=-
Grok
grifscoots is offline
post #18 of 22 Old Dec 12th, 2005, 7:10 pm
Purple is as purple does
Let your breath out. Now count to 10. Now take a deep breath and hold it.
Jon Bush
' 09 RT
"SAPHIRE"
bushj1 is offline
post #19 of 22 Old Dec 12th, 2005, 9:01 pm Thread Starter
Gene
pavehawkfe's Avatar
Oil in an H-60
__________________
Steve - KA5MTE
Steve,
Easy. Open the engine cowling door and there is a big yellow oil filter cap marked 7.6 quarts. Believe it or not there is even a sight guage on each side of the oil tank reservior. If only the LT was as simple as the H-60.
Gene
post #20 of 22 Old Dec 12th, 2005, 9:58 pm
Steve_R's Avatar
Thumbs up Cool
__________________
Steve - KA5MTE
Steve,
Gene
I have to remind myself everytime I go to the LT where the site glass is. Keep on training our trrops. BTW, Pavehawk is the Air Force Air Rescue Unit right?? Or at least that's the only one I remember being called "Pavehawk".
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
post #21 of 22 Old Dec 12th, 2005, 10:08 pm Thread Starter
Gene
pavehawkfe's Avatar
Pavehawk
Steve,
The Pavehawk is the Air Force version of the Army Blackhawk. Primary differences are in-flight refueling, hoist capability and upgraded avionics. Up until about 2 years or so ago you had Rescue Units and Special Ops units. Now all Air Force helicopters come under Special Ops(even though they still perform rescue). I'm an instructor at Kirtland AFB, NM which is the "schoohouse" for the helicopters and the 130 fixed wing. I am strictly an H-60 instructor. Previously have flown on the Huey (H-1), Super Jolly Green (H-53) and the Jolly Green (H-3). H-3 and H-60 being my favorite. Hope I didn't ramble too much in answering your question.
Gene
post #22 of 22 Old Dec 12th, 2005, 10:15 pm
Steve_R's Avatar
Thanks!!
Gene
No Sir! Being an Air Force Retired Dependent and Air Force myself, '71 to '76, I appreciate the extra info. Train them well!
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
Pardon my ignorance johnw Chit Chat 4 Nov 17th, 2005 8:06 pm
