motorcycle turntable mat - BMW Luxury Touring Community
 4Likes
  • 1 Post By CharlieVT
  • 3 Post By CharlieVT
post #1 of 19 Old Dec 10th, 2005, 8:32 pm Thread Starter
Hey Folks,
I found this kicking round the web, might be usefull for some
http://www.driveawaymat.co.uk/7.html
Dezrae is offline
post #2 of 19 Old Dec 10th, 2005, 8:36 pm Thread Starter
this might be better as the lt is heavier then 300 kilogram
http://www.cyoma.com/
Dezrae is offline
post #3 of 19 Old Dec 10th, 2005, 8:40 pm
Regarding the "mat" (turntable): What a great idea -- would save backing out of a garage, for example.
One problem, though: at a max. capacity of 350kg, our LTs are too heavy for it. 350kg = 774# (approximately).
The Tail Swinger seems the better way to go.
post #4 of 19 Old Dec 11th, 2005, 9:00 am
charlieg's Avatar
No turntable needed
Last week I had my LT at the local dealer for an autocom issue. After a quick fix the service manager (not a big guy) grabbed the luggage rack and much to my amazement spun the LT 180 degrees on the centerstand with little effort. I guess it just takes confidence and rearward pressure to keep the centerstand locked down.
charlieg is offline
post #5 of 19 Old Dec 11th, 2005, 10:01 am
And also knowing you can get parts at cost if it falls over !
I don't think I would like to try and turn my bike using the rear wheel system, looks too unstable to me.
I have e-mailed the turntable people to enquire whether they have sold to other LT owners.
This is also a possibility. I like the Teflon idea.
http://motorcycleinfo.calsci.com/ search "turntable"
simoncharles is offline
post #6 of 19 Old Dec 11th, 2005, 10:52 am
Hmmmmmmm..... Convert to US Dollars from British Pounds, and you find it's $85 for the small mat, and $125 for the larger one (Plus shipping from Europe). How about going to your friendly local woodworking supply store and buying a lazy susan bearing for less than $7.00 and putting a piece of sheet steel on top of it. Same effect, for a whole lot less money...
A good mail order source for the lazy susan bearing is:
http://www.woodcraft.com/Family.aspx..._susan_bearing
Note Part #02Z51 is metal, 12" around and has a 1000 lb capacity for $6.50.
JetDoc is offline
post #7 of 19 Old Dec 11th, 2005, 10:56 am
The motorcycle turntable mat that Dezrae refers to needs to be used on an absolutely smooth surface, so if your garage floor aint as smooth as a babies bum, then forget it. I bought one when I had a CBR1000F and it just did the job and no more on the first use. After that the rubber matting on the top just twisted in protest and peeled off, so it now lies in the corner of the garage unused. Waste of money IMHO, unless you have a glass smooth floor. No way I'd even think about using it with an LT.
The Tail Swinger is exactly the same, got to be a smooooth surface or it does not work, your more likely to tip the bike than move it.
I like the idea of the Lazy Susan, but built into the garage floor, got me thinking now
Malki is offline
post #8 of 19 Old Dec 11th, 2005, 12:08 pm
Reid's Avatar
I was considering a basic automobile wheel dolly from Harbor Freight. Drop the front/rear wheel into the dolly and have lots of movement.
Reido
K1600GTL...Blue Metallic
USMC 1971-1975
Ham Radio Call: W0FVR
"The right to be heard does not automatically include the right to be taken seriously."
--H.H. Humphrey
Reid is offline
post #9 of 19 Old Dec 11th, 2005, 3:46 pm
CharlieVT's Avatar
Homebrew turn table
I can pivot my bikes on the center stand although the LT is a bit of a heft.
A turntable can be fashioned from a couple of pieces of sheet metal or a couple of pieces of floor tile. Put a bit of grease between the sheets and there is the turntable. A thin piece of plywood on top of the "turntable" will keep the centerstand "feet" from digging in too much and will raise the bike a little to provide a little more clearance when rotatiing.
From the low cost leader in the deep south of Vermont
johnbaker15 likes this.
CharlieVT is offline
post #10 of 19 Old Dec 11th, 2005, 9:59 pm
mneblett's Avatar
I did *precisely* this today in my garage (in likely hopeless hope that if I am pointed straight out, I can get across the ice in front of my garage Monday morning ). Like most things with the LT, it doesn't require brute strength, it's all technique. It also doesn't require any rearward pressure to keep the stand locked.
The key is to apply a small amount of pressure on the bike toward your body, so that some of the weight of the bike is lifted off the far leg of the centerstand, and then rotate the bike. I put one hand on the left hand grip and the other on the luggage rack to lightly pull the weight off the far leg, and also to balance the bike so that neither tire is dragging sideways on the floor. Swing the rear end of the bike toward you so that you're not pulling the bike forward off the stand. [edit] actooly, you can swing in either direction -- I realized after posting this that I pulled the front around the last time I did this [/edit]
Mark Neblett
Fairfax, VA
mneblett is offline
post #11 of 19 Old Dec 12th, 2005, 3:29 pm
charlieg's Avatar
180 spin
Well, I just went out to my garage and tried the no turntable LT spin. I held onto the topcase luggage rack applied slight downward and rearward pressure then pushed sideways. Sure enough very little effort is needed to spin the bike 180. BTW my garage floor is flat smooth concrete.
charlieg is offline
post #12 of 19 Old Dec 12th, 2005, 7:13 pm
Thumbs up 180 spin
Works especially good if you have just changed your tranny fluid !!
Jon Bush
' 09 RT
"SAPHIRE"
bushj1 is offline
post #13 of 19 Old Nov 15th, 2015, 4:04 pm
Re: 180 spin
How about checking this product out at TurnCycle. $185.00 with a lifetime guarantee. Heavy duty turntable to spin the motorcycle around with a center stand. Holds 1,000 lbs and is only 1/2" high. Comes with two rubber levelling mats to help reduce the lifting effort required to lift the bike up another 1/2".
Beemerbob69 is offline
post #14 of 19 Old Nov 15th, 2015, 6:28 pm
Smile Re: motorcycle turntable mat
The "Turncycle Centre Stand disc" is designed and built in Canada and has 100% North American content. A newer 20" disc is coming out soon, for larger touring motorcycles and BMW F800GS and KTM motorcycles with wider swept back centre stands.
Visit the website at TurnCycle or check the video's out on YouTube at "Turncycle TV".
post #15 of 19 Old Nov 16th, 2015, 5:32 am
CharlieVT's Avatar
So, Hi Beemerbob.
Your only two posts on this site are to resurrect a thread that is 10 years old, to post about a product, a product which website is also listed as your home page. It's your product, huh?
How about a little unabashed advertising?
deputy5211, Axle and biometrics like this.
post #16 of 19 Old Nov 16th, 2015, 4:48 pm
GaryEm's Avatar
Your not going to get any thing past Charlie He got U there Rob (Btz) left a few letters out of the last FOR YA
Gary
2003 K1200LT
GaryEm is offline
post #17 of 19 Old Nov 21st, 2015, 4:36 pm
Didn't want to offend anyone here. Just saw the post and thought about mentioning the site. Have ridden BMW's for over 30 years. I am not just the owner/designer, but a fellow rider and enthusiast as well. Turn-A-Bike, the only American producer of a lazy susan disc went out of business this year and there website is down. Have advertised in the BMWMOA magazine and other magazines in Canada as well.
post #18 of 19 Old Nov 24th, 2015, 12:22 pm
deanwoolsey's Avatar
For those who like to spin their bikes on the center stand: I stopped doing it after I repaired the cracks in my center stand. I realize part of the issue is inherent with the design of the stand as it twists every time it goes up. However, spinning the bike torques the center stand in the exact fashion that would cause a crack. No more for me.
deanwoolsey is offline
post #19 of 19 Old Nov 24th, 2015, 9:06 pm
Dropping your motorcycle trying to back out of a parking spot would be a lot more costly than a turntable disc or trying to spin it around on the center stand. That's alright for the younger members, but as the last post said, cracked center stand would cause as much damage if the bike fell over also, or collapsed while performing the maneuver.
Again you would need to elevate the motorcycle to the same height as the disc to allow the same lifting effort required to do this on a level surface. That is why the rubber mats are included with the Turncycle disc kit.
Atlanta Motorcycle School giarcg Chit Chat 2 Dec 9th, 2005 10:02 pm
Interesting Motorcycle Crash Data Dochatley Chit Chat 0 Nov 29th, 2005 11:38 am
Milan Motorcycle Show Malki Chit Chat 1 Oct 23rd, 2005 12:51 am
Harvest Classic European & Vintage Motorcycle Rally - 10/21 - 10/23 eljeffe South Central 0 Oct 11th, 2005 9:57 am
Aussie Motorcycle Grand Prix...anyone going? onions Australia, New Zealand, and AsiaPac 5 Oct 10th, 2005 8:37 pm
