'06 LT Rear Brake Rotor - BMW Luxury Touring Community
post #1 of 20 Old Dec 10th, 2005, 6:15 pm Thread Starter
Hi, Guys and Gals -
I certainly qualify as the least-informed member here, on LT-related issues, just having bought my first BMW in my life, an '06 LT.
Would someone knowledgable please help me with an answer? My bike still has less than 1,000 miles on it. Today, before going for a ride, I noticed that the rear brake rotor has a small amount of lateral play, all the way around it. I can shake it side to side, and it moves, maybe .025". Is that right? I've never seen a brake rotor installation where the rotor is designed to float.
I also get some brake squeal, which I've noted here as somewhat characteristic, but what about the rotor movement. Do I have a problem?
CriticalMass is offline
post #2 of 20 Old Dec 10th, 2005, 7:08 pm
Nope, it's designed to float. If you look closely, you'll see that the calipers are mounted solid, so the rotor needs some play to work well. The front rotors float as well, but usually not as much as the rear.
The squealing is annoying, but well documented. Don't baby the rear brake, but use it firmly when needed.
meese is online now
post #3 of 20 Old Dec 10th, 2005, 7:14 pm
Thumbs down
Really disappointing to hear that this problem, which has now been present for at least 6 model years has not been taken care of by BMW.
You should have a lateral play in the rotor, but no squeal. My dealer also informed me that the rotors usually start to rattle at or around 6'K miles, which is in line with what mine does too.
The dealer also replace it and pads promptly under warranty when it does.
Annoying for me, expensive for BMW and I hope it is annoying for them too
Stefan
stefan is offline
post #4 of 20 Old Dec 10th, 2005, 8:00 pm Thread Starter
Thanks very much for the advice, Ken. It's reassuring to know I'm not faced with a safety issue. I can't get any movement in the front rotors at all. I did check them. I'll use the rear brakes as required.
You should have a lateral play in the rotor, but no squeal. My dealer also informed me that the rotors usually start to rattle at or around 6'K miles, which is in line with what mine does too. The dealer also replace it and pads promptly under warranty when it does. Annoying for me, expensive for BMW and I hope it is annoying for them too
Stefan, thanks for the info, although not what I'd rather hear. I'll be keeping a close eye on things, and will bring anything that seems suspect to the attention of my dealer. Thanks again for the input.
post #5 of 20 Old Dec 10th, 2005, 8:34 pm
murray's Avatar
Do not be concerned until you here the rotor rattle. Replace it if the sound bothers you.
Pete
murray is offline
post #6 of 20 Old Dec 10th, 2005, 11:18 pm
CM, as all have said you have no problem, some rattle a little more than others, no big deal.....
What dealer are you using?? where are you at??..........Regards Pete
petepeterson is offline
post #7 of 20 Old Dec 11th, 2005, 12:48 am
Exclamation And what pads do we use?!
Repeat after me, "EBC pads in the rear, OEMs up front.".
...and repeat:
...and repeat:
...and repeat:
...and repeat:
...and repeat:
...and repeat:
You'll thank me later.
post #8 of 20 Old Dec 11th, 2005, 2:00 am Thread Starter
I'm near San Antonio, Pete. Dealing with Alamo BMW. Open to alternate suggestions far as who does good work around here, although I'm gonna' need to stay with someone authorized to do warranty-level stuff a while.
Dave P
post #9 of 20 Old Dec 11th, 2005, 7:56 am
pkpr1998's Avatar
Joe, was that EBC on the front or rear? LOL
Dave, the floating rotor is normal (supposed to be floating), the noise shouldn't be, but is! Like Joe said...........................
Brett
2003 K1200LTC SOLD
2013 K1600GTL SOLD
2018 K1600GA SOLD
2019 K1600GA Blue
North Georgia
2005 CCR-Tetons
2006 CCR-Braselton
2008 CCR-Midway
2009 CCR-Rapid City
2011 CCR-Boise
2012 CCR-Duluth
2014 CCR-Chattanooga
2015 CCR-Coeur d 'Alene
pkpr1998 is offline
post #10 of 20 Old Dec 11th, 2005, 8:20 am
I believe it was ABC pads on the rear, and DEF pads on the front. Yeah, that's it.
meese is online now
post #11 of 20 Old Dec 11th, 2005, 10:59 am
Ok Joe, WHICH EBC pads ?:
simoncharles is offline
post #12 of 20 Old Dec 11th, 2005, 1:38 pm
Exclamation EBC rear pad part number! FA304HH
The EBC pads for the rear are part number: FA304HH
(I found that part number by clicking on the "Technical" link above, then "Accessories", then "Service Items". Scroll down to the "Tires, Suspension, & Brakes" section. A very handy tool!)
post #13 of 20 Old Dec 11th, 2005, 6:35 pm Thread Starter
Are these the ones that have to have the "a la Sayegh" corners ground off, or are they something that fits without alteration?
post #14 of 20 Old Dec 11th, 2005, 7:04 pm
mneblett's Avatar
The Ducati pads that you grind the corners off are FA244HH.
Mark Neblett
Fairfax, VA
mneblett is offline
post #15 of 20 Old Dec 12th, 2005, 5:26 am
Thanks.
I was a bit confused about the Ducati pads as well.
post #16 of 20 Old Dec 12th, 2005, 7:26 am
Don't be confused . . . just don't buy them.
post #17 of 20 Old Dec 12th, 2005, 7:33 am
mneblett's Avatar
Why not? If FA304HH's aren't available, a couple quick hits on the corners with a grinder turn the 244's into 304's -- perfectly useful.
Mark Neblett
Fairfax, VA
mneblett is offline
post #18 of 20 Old Dec 12th, 2005, 7:45 am
Cool We don't need no stinkin' part numbers!
Yea...I guess my comment is directed to those who actually think ahead and order their pads in advance. But for those who replace their pads on a monent's notice and then find that the "correct" pads aren't available . . . at that point, any port in the storm. Sorry. I should've specified to whom I was speaking.
I guess just about any part would work on any bike if you're willing to 'put the dremel to it' to make it fit.
post #19 of 20 Old Dec 12th, 2005, 7:50 am
mneblett's Avatar
Plan head?? -- hey! that's *way* too rational
Just making sure it was clear that the 244's were not an absolute no-go.
Mark Neblett
Fairfax, VA
mneblett is offline
post #20 of 20 Old Dec 12th, 2005, 8:38 am
Besides, you only have to grind the corners on one of the 244 pads. I usually just keep a spare set of pads in the garage, because invariably I'll be heading out on a long trip and think "maybe I better check the brake pads, oops."
meese is online now
Rear brake issues kamike K1200LT 29 Sep 16th, 2014 9:26 pm
rear brake disk problems k1200lt giokas K1200LT 1 Jul 18th, 2008 2:10 pm
Loose rear rotor Billmer K1200LT 14 Jun 1st, 2007 11:53 pm
Rear brake fluid reservoir Colin1952 K1200LT 7 Nov 21st, 2005 6:40 pm
Help! 04 Rear Brake Fluid Reservoir mikec826 K1200LT 2 Nov 4th, 2005 10:15 am
