Battery Removal - BMW Luxury Touring Community
LinkBack Thread Tools
Old Dec 10th, 2005, 8:11 am Thread Starter
Question Battery Removal
Ok guys and gals, have Kermit in the storage building for the winter and they have no electricity. I want to remove the battery and put it on a trickle charger here at the house. I've learned to check in here first before I tackle any project on this bike, it's been known to save me time and heartaches. Any tricks or tips for removing the battery? Thanks in advance.
txsub is offline
Old Dec 10th, 2005, 9:45 am
Lift the seat, remove the two screws in the hold down plate, remove the negative battery terminal, THEN the positive one, lift out the battery. Install in reverse (positive terminal installed before the negative). That's it.
Old Dec 10th, 2005, 10:34 am
Exclamation
And once reinstalled, before starting your LT...
  1. Turn igntion to ON (again, without starting the bike)
  2. Open throttle all the way, close all the way, then open all the way, then close
  3. Turn OFF igntion
Now you're ready to ride your LT, and rediscover what you've been missing all winter. The delusion I tell to myself over & over again while existing in this frozed HELL called the "Great NorthCoast".
Old Dec 10th, 2005, 4:52 pm
Steve_R's Avatar
  3. Turn OFF igntion
Joe, You're allowed to say "HELL"?
On His Ride,
Steve
KA5MTE
'00 Unigo - Dragon's Egg
Have you
bmwlt.com lately????
Steve_R is offline
Old Dec 10th, 2005, 6:47 pm
grifscoots's Avatar
Be careful not to bang your ratchet against the frame when removing the positive terminal
-=grif=-
Grok
grifscoots is offline
Old Dec 10th, 2005, 7:17 pm
munson's Avatar
That, mi amigo, is exactly why you remove the neg. cable first! Take it from Sparky!
Blessings!
munson+
The Rev. John Munson
Vicar,
, Burkburnett, Texas
Vicar,
, Wichita Falls, Texas
2007 R1200RT "REV ZM"
IRON BUTT ASSOC. #37813
See my video:
munson is offline
Old Dec 10th, 2005, 7:20 pm
Terminal continuity
Griff: Knocking the wrench against the frame; does it matter???
If the negative battery terminal is removed (lifted) from the battery post first, then there should be no (negative) continuity to the frame when removing the positive terminal; what am I missing?
Chuck J
02 K1200LT (Black Beauty)
New friends make it all worthwhile!!! Smile, its catching.
ksailor is offline
Old Dec 10th, 2005, 7:45 pm
Zotter's Avatar
Exclamation
You're not missing anything.
Removing the neg cable from the battery should be the first step in most any repair/project. Re-connecting the neg cable to the battery should be the very last step before saying "Tiz Done!". This is the smart way to avoid Mr. Sparky's accidental arrival to any party where tools are involved.
Tate
02 Mauve - my 'Light Truck'
Zotter is offline
Old Dec 10th, 2005, 8:11 pm
Steve_R's Avatar
This sounds like
This sounds like Grif saying "DAMHIK!!"
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
Old Dec 10th, 2005, 8:16 pm
  3. Turn OFF igntion
Joe, does that sequence do something special? (it's probably in the manual... right?)
Also: are any of the LT's settings (clock, radio stations, etc.) dependent upon the battery being in place, and if not there, won't they be lost?
Old Dec 10th, 2005, 8:18 pm
Steve_R's Avatar
If I remember correctly, what Joe is talking about resets the Motronic for the full throttle range. And yes, you will loose all you radio presets when you pull the battery.
Cheers.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
Old Dec 10th, 2005, 8:21 pm
Originally Posted by Steve_R
If I remember correctly, what Joe is talking about resets the Motronic for the full throttle range. And yes, you will lose all your radio presets when you pull the battery.
Got it.
So... what happens when you reinstall the battery and don't do that?
Old Dec 10th, 2005, 8:28 pm
Steve_R's Avatar
Mr Neblett, Mr Dragon, Mr Grif, Anyone???? I ferget perzactly what it does, but one of the big techie types will. I just know I pull the fuse to the Motronic once a month and go through this procedure. Seems to me it lets me retrain bike to how I ride. Also seems to bring the gas mileage back up.
We'll get a good explanation soon.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
Old Dec 10th, 2005, 9:09 pm
The radio presets do not go away when you pull the battery! I had my bike apart for quite some time when I had the piston problem, and when I put everything back together the presets were still there.
Same with my BMW cars, presets seem to be held in non-volatile memory.
The throttle position resetting is specified, but not really necessary. The motronic will re-train itself while riding anyway. The re-setting procedure just hastens it a little.
Old Dec 10th, 2005, 9:24 pm
Steve_R's Avatar
Thanks for correcting me Dave. I hate giving out bad info.
On His Ride,
Steve
KA5MTE
Have you
Steve_R is offline
Old Dec 10th, 2005, 11:46 pm
grifscoots's Avatar
You're missing the
-=grif=-
Grok
Old Dec 11th, 2005, 10:40 am
robowis's Avatar
Is there a vent tube on the battery? All my other bikes had a tube to the batttery, but those were acid type batteries, I now have the gel battery,does that require a tube.
Rob Steffens
2002 LTC Black
"Do We Stop Playing because we grow Old
Or do We Grow Old because We Stop Playing."
robowis is offline
Old Dec 11th, 2005, 1:11 pm
JATownsend's Avatar
Smile No tubes...
Gel cells and AGMs are Sealed Batteries.
Therefore, no drain tubes used or needed.
J. Averill Townsend
Bloomfield Hills, MI
IBA# 24374
2002 K1200LTC - Silver
JATownsend is offline
Old Dec 13th, 2005, 10:29 am
robowis's Avatar
Gracias, Mr. Townsend.
Rob Steffens
2002 LTC Black
robowis is offline
Battery Concern please advise Hulkster Batteries, Chargers, & Electrical 8 Feb 6th, 2006 1:41 am
Battery Charger bugged Batteries, Chargers, & Electrical 4 Dec 11th, 2005 10:55 am
How NOT to treat your battery.... Zotter Batteries, Chargers, & Electrical 8 Nov 22nd, 2005 2:51 pm
Battery Cable - I got lucky! ytk K1200LT 1 Nov 18th, 2005 5:02 pm
