The windshield motor on my '00LT only works in the down direction. My mechanic says I need a new motor for $500+ plus installation. My thought is that if the motor works in one direction it is still OK, and the problem is in a switch or relay. Not knowing much about electrical circuits, I could very well be wrong. Any help from the experts out there in LT land?
Does it work going up if you're not moving? If it does turn out you need a new one, and you're mechanically minded, you can get a used motor for a lot less, and do it yourself.
There are some used parts guys that sponsor the site, and they could hook you up.
Stop! There are 2 grey relays under the cover on top of the dash. Remove the windshield, 4 screws. Remove 6 visable screws on the top and one behind the dash light. Reverse the relays if it goes in the direction it didn't before, get another relay. Could save hundreds!
Make sure the arm joints are well lubricated too. ALL of them. Mine need to be re-lubed from time to time. I make it part of the fluid change routine, every 6,000 miles. That's not your problem, but still needs to be part of the maintenance cycle.
BTW.. if you can hear the relay 'activate', then try rapping it with the handle of a screwdriver.... just to "shock" it... not break it... if the motor tries to run, you're on to the problem.
I can almost guarantee that it is a relay do a search for one of my post for the after market relay part numbers and where to buy. These OEM relays are a know to be a POS.
As suggested, the problem was with the relay. Switched them from left to right and the problem went away. Thanks for the help. It is much appreciated.
Bob Schrader
Wentzville, Mo.
Related Threads
BMW Luxury Touring Community
894.3K posts
44.9K members
Since 2005
