Teardown progress - main seal removal - BMW Luxury Touring Community
post #1 of 4 Old Feb 17th, 2008, 10:11 am Thread Starter
BDC
Today I decided to remove the main seal. My replacement seal is on order so I couldn't go much further.
The photos show how I drilled the old seal surface and then screwed a self tapping screw into the hole. The screw was attached to a slide hammer. On the second hammer attempt the seal popped out.
Photos also show my cleaned up tranny with new input shaft seals fitted. One on the clutch side and the other on the same shaft but on the slave cylinder side.
I will replace the main seal by pressing it into place by re-fitting the clutch housing and screwing on the nut.
In case this does not push the seal level with the surface I have made a white plastic spacer. I will press the seal in almost fully then remove the housing and fit my spacer. A further screw down will use the spacer to press the seal home (upper seal-surface level with seal-housing upper surface as per old seal)
FWIW the old seal lip had very little flexibility and felt quite hard unlike the lips of the new seals which I placed in the tranny.
The replacement tranny seals appeared to be different to those replaced. The new ones were brown in colour and the clutch-side seal had a felt upper surface which was not on the leaking original. Hopefully this represents an improvement on the originals.
Name:	seal drill.jpg
ID:	16663   Click image for larger version
Name:	slide hammer.jpg
ID:	16664   Click image for larger version
Name:	screw in seal.jpg
ID:	16665   Click image for larger version
BDC is offline
post #2 of 4 Old Feb 17th, 2008, 10:25 am Thread Starter
BDC
Re: Teardown progress - main seal removal
Remaining photos here
ID:	16667   Click image for larger version
Name:	clean tranny.jpg
ID:	16668   Click image for larger version
ID:	16669   Click image for larger version
ID:	16670   Click image for larger version
Name:	spacer in place.jpg
BDC is offline
post #3 of 4 Old Feb 17th, 2008, 10:39 am
Looks like you're having all the fun!
Was the seal leaking or is this something you're doing while addressing another problem?
Good luck with it.
Rodney
2000 Canyon Red LT [I]
2005 Sportster XLCH 1200C
2006 Mongoose XR250
Make sure your Life Assurance is prayed up. Don't leave home without it.
rodneyinmaypearltx is offline
post #4 of 4 Old Feb 17th, 2008, 11:11 am Thread Starter
BDC
Hi Rod
The seal had been leaking for the last 18 months but I deliberately kept the engine oil on the low side which seemed to stop it progressing. There were minimal signs of recent leaking when I removed the clutch housing.
However, when I started to remove the transmission there was the unmistakeable smell of tranny fluid which was leaking from the input shaft. I was lucky that this had not contaminated the clutch.
It seems that an engine oil leak from the main engine seal is more of a nuisance than an immediate threat and it is unusual for this to contaminate the clutch because of its position behind the clutch housing. The item that does cause engine oil to contaminate the clutch is the failure of a small rubber O ring between the engine and the clutch. If this fails it allows oil to run right into the heart of the clutch. Not good as these are meant to be dry clutches unlike many used on Jap bikes.
Regards
BDC is offline
Oil seal removal from gearbox in front of slave cylinder K12Rick K1200LT 4 Sep 6th, 2012 8:51 pm
Main Seal Leak? Bob204bc K1200LT 3 Feb 23rd, 2008 12:00 pm
Main seal - progress BDC K1200LT 1 Feb 9th, 2008 1:44 pm
Main seal musts BDC K1200LT 7 Feb 5th, 2008 9:13 am
Shaft seal pulling made easy Schweintechnik K1200LT 4 Aug 6th, 2007 7:21 pm
