Front Wheel Bearings - BMW Luxury Touring Community
post #1 of 11 Old Feb 11th, 2008, 12:27 pm Thread Starter
DanMartin's Avatar
This weekend as I was changing a front tire,I noticed the bearings were unable to move. Inserting a wooden handle allowed me to turn the bearings but both were hard and notchy. Is there any reason to stick with the dealer supplied bearings versus a reputable bearing supplier?
DanMartin
Houston, Tx
DanMartin is offline
post #2 of 11 Old Feb 11th, 2008, 12:36 pm
mtrevelino's Avatar
As long as you match bearings, any reputable supplier should do.
How many miles is on your LT? I am wondering if the bearings should be replaced say at 100K as preventative maintenance?
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #3 of 11 Old Feb 11th, 2008, 12:41 pm Thread Starter
DanMartin's Avatar
Thanks,my LT has 61k miles,but these are on a second front wheel that I bought used a few years ago with no clue as to mileage.
dan
post #4 of 11 Old Feb 11th, 2008, 2:29 pm
Too much maintenance
Dan, you're working on the LT too much. Quit looking at stuff! (Ha!)
Once I get mine all back together (if ever) I'm just going to ride it until it turns to dust or bursts into flames!
I usually check my front bearings too when I change tires and they feel OK so far at almost 50K. San Jose BMW's site recommends changing at 40k but i think I'll go until I notice some change like you have.
Joe
EncoreJoe
"Ride, boldly ride, ... If you seek for Eldorado!"
'10 Triumph Tiger 1050
EncoreJoe is offline
post #5 of 11 Old Feb 11th, 2008, 6:35 pm
I went 137,000 miles on the original bearings on my 2000 K1200LT before I sold it. Sounds like something is wrong. The only bearings I replaced were those on the fork slider bridge at around 90,000 miles, mostly because the bearing boot was torn and I replaced the front shock.
TimVipond is offline
post #6 of 11 Old Feb 11th, 2008, 6:42 pm Thread Starter
DanMartin's Avatar
For all I know this wheel may have had 100k on it. I purchased it on ebay a few years ago.
dan
post #7 of 11 Old Feb 11th, 2008, 6:53 pm
grifscoots's Avatar
They are a bear to change out. I sweated my ass off, while watching Hank at Rhinewest do it. I even heard Hank say a cuss word!!!
-=grif=-
Grok
grifscoots is offline
post #8 of 11 Old Feb 11th, 2008, 8:32 pm
bigbear's Avatar
Sure glad you were watching and not working
As far as changing them:
On my old K you need to heat the hub up to around 200 - 250 degrees to remove the bearing. I am lucky that we have an industrial oven at work that I could throw the whole rim in. At the above mentioned temperature I was able to carefully drive the old bearings out with a long drift punch. There is not much of a lip for access so the heat is critical.
To install, freeze the bearings and keep the rim hot, they drop right in. I had to hold them until the rim cooled so they wouldn't fall out.
Without an oven they would be a challenge.
Roy
Roy Gregersen
85 K100RT sold
02 LTC DOA 9/21/14
12 R1200RT
bigbear is offline
post #9 of 11 Old Feb 13th, 2008, 4:31 pm
munson's Avatar
dan
They could have been hit with a power washer for all you know. That'll kill bearings pretty quickly.
Blessings!
munson+
The Rev. John Munson
Vicar,
, Burkburnett, Texas
Vicar,
, Wichita Falls, Texas
2007 R1200RT "REV ZM"
IRON BUTT ASSOC. #37813
See my video:
munson is offline
post #10 of 11 Old Feb 13th, 2008, 5:07 pm
motorhead's Avatar
An ample dose of dry heat to the rims bearing support areas from a "HEAT GUN" will make getting them out a LOT easier.
As previously stated ... A Pressure washer cleaning around the seals will KILL the bearings very quickly !!
Our "semi" quiet riot
*** Trailer Too ***
T
wisties Required
motorhead is offline
post #11 of 11 Old Feb 13th, 2008, 5:08 pm Thread Starter
DanMartin's Avatar
I bought a heat gun to help repair my final drive a while back. I will be using that as soon as the bearings come in.
dan
K1200LT Low speed front wheel wobble ironhorsenc K1200LT 18 Jun 29th, 2015 8:10 pm
Front wheel removal eibacher K1200LT 20 Dec 13th, 2012 10:56 pm
tires, Front wheel stand,tire changer for 06KGT HowardRichman K1200/1300GT (The Next Generation) 12 Jul 24th, 2011 4:01 pm
front wheel removal HowardRichman Tires 1 Jul 29th, 2007 8:29 am
20007 Front Wheel Dampner VernRuth K1200LT 4 Jul 21st, 2007 5:30 pm
