Clutch - BMW Luxury Touring Community
post #1 of 12 Old Feb 8th, 2008, 6:06 pm Thread Starter
galloway11's Avatar
Clutch
My clutch stated slipping. The bike has less than 13k on the clock. I assumed that the slave cylinder was bad on maybe the rear main. The dealer told me that the clutch was completely burned up. And it is not the way I ride. Almost all the miles are highway miles. When the bike was new, I took it to the dealer complaining of a slipping clutch. The dealer told me "that's the way they run." Now I'm looking at almost 1K in repairs.
Has anyone had a clutch failure like this and if you did how did you handle the situation?
Galloway11
2005 Yellow KLT
galloway11 is offline
post #2 of 12 Old Feb 8th, 2008, 6:11 pm
Who is saying it is not the way you ride, the dealer or you?? If it is the dealer, what is the dealer saying is the cause.
If it is you, how can you justify that statement? Is the dealer saying that the clutch is slipping because of contamination, or has he not taken it apart to know what the cause was??
rglassma is offline
post #3 of 12 Old Feb 8th, 2008, 6:29 pm
cccpastorjack's Avatar
Yep...we need the answers to a few questions. I am sure that due to frustrations, your first post is a bit confusing.
1. Has the bike been disassembled by the shop/someone?
2. Did you get to see the parts? I would demand to see them--at least the clutch plate. You want to see if it is simply dry and worn out or saturated with any type of fluid. Compare it with a new one to see any difference.
3. If you can, get some pics of the parts while you are there and then post them. That'll help us to help you with a few more concrete suggestions.
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #4 of 12 Old Feb 8th, 2008, 6:57 pm Thread Starter
galloway11's Avatar
The dealer took it apart and said the clutch was dry but worn out. I think I will take a look at the parts for myself and i will take some pictures. thanks
Galloway11
2005 Yellow KLT
post #5 of 12 Old Feb 8th, 2008, 7:20 pm
Dealer warrantied mine at around 16000km, worn out....
They DONT run like that, so if you're still under warranty push em a litle harder...
do you have a record of the early complaint from a service statement or anything, that might help
good luck
post #6 of 12 Old Feb 9th, 2008, 9:28 am
Zeke's Avatar
Question
WHAT? Worn out but dry? I and some others are well near 100000 miles with the same clutch. Only ones I have heard about is because of the slave leaking. I think you need a new dealer.
Zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #7 of 12 Old Feb 9th, 2008, 1:07 pm Thread Starter
galloway11's Avatar
I went to the dealer today and looked at the clutch It was dry and worn out. I've been riding for over 35 years and have never prematurely worn a clutch. My 1990 Ford truck has over 165k on the original clutch and counting. My dealer has no explanation. I suspect a bad pressure plate which allowed the clutch to slip imperceptibly under highway speeds.
Thoughts
Galloway11
2005 Yellow KLT
post #8 of 12 Old Feb 9th, 2008, 1:47 pm
Zeke's Avatar
Thoughts
Did it "look" worn out or did they/you measure the thickness?
Zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #9 of 12 Old Feb 9th, 2008, 4:54 pm Thread Starter
galloway11's Avatar
It was worn out, well into the rivets. This is not the first worn clutch I've seen.
Galloway11
2005 Yellow KLT
post #10 of 12 Old Feb 10th, 2008, 8:06 am
Zeke's Avatar
No insult intended. I just dont really trust dealers, cars or bikes. There are too many that just what the almighty dollar.
And I'm a mechanic, go figure.
Peace to all.
Zeke
2002 K1200LT
2016 R1200RT
IBA # 41935
Zeke is offline
post #11 of 12 Old Feb 10th, 2008, 1:54 pm
There are a few of us here who have had clutches "burn up" early. Mine had 15,000 miles when it started slipping. It was out of warranty and no amount of arguing on my part would get BMW to help with the cost of repair. They said it was my "riding style" that caused the problem.
Good luck with yours.
Steve
'04 LT
xenia is offline
post #12 of 12 Old Feb 14th, 2008, 5:39 am
MrG
MrG's Avatar
Clutch Slipping
I experienced clutch slipping after 18k miles on my 2001 LT only last year, BMW wanted £1500 to replace the clutch, plus it was due for a service, which would've been extra . . . it was a crossroads for me, i had, had the LT for 3 years and thought it may be an opportunity to replace it with something different, I had a test ride on a Pan European and an FJR1300, both times I got back on my LT and thought no way, there is just no comparison . . . so I bit the bullet, went to an independent BMW mechanic near Chorley, Lancashire, a guy called Roy Gardner, who I would recommend by the way, he took the clutch apart, diagnosied the slipping as a bent push rod, but seeing as though he had the clutch in bits I had him replace it anyway, and including an 18k service he charged me just a little over £700. Bike still runs like a dream.
MrG is offline
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 11:19 am
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 10:00 pm
