No Rear Brakes !!!!! - BMW Luxury Touring Community
post #1 of 21 Old Feb 3rd, 2008, 3:51 pm Thread Starter
Old Slow Guy in A Fast Car
katnapinn's Avatar
Last Sunday I went for a lil ride, along the way I noticed that my rear brakes started to feel soft. After a few miles I had NO REAR BRAKES !! It was not that big of a deal at the time as I mainly use the front brakes. When I got home I checked and the rear master cylinder tank was EMPTY. As in bone dry !!! I never got an ABS light to worn me or anything .As I tore everything apart I saw a hole in the brake line just above the master cylinder and the master cyl. had a bad seal. After getting the replacement parts from Tony www.LTParts.com I put it all back together. Bleed the system ,then tested it .The replacement hose blew up in my face in the same spot. What went wrong?? Is there a stronger replacement hose? This hose feeds the line to the rear brake caliper. Here are 2 pics , the screwdriver is in the hole where the line blew. This is a 2000 K1200LT if that makes a difference.
ID:	16426   Click image for larger version
Stevie Shreeve
katnapinn is offline
post #2 of 21 Old Feb 3rd, 2008, 4:50 pm
motorman587's Avatar
There was not drippings or fluid on the side of the motorcycle???
Florida
2004 BMW R1150R Black
motorman587 is offline
post #3 of 21 Old Feb 3rd, 2008, 5:01 pm
cccpastorjack's Avatar
I would suggest that it was a weak hose. Your brakes are not servo-assisted and that looks like a natural place for the hose to weaken over time. I would simply replace the hose with a new one. Never been much of one for "used" brake lines. Other parts are OK, but not on brake lines.
Jack Homesley
Cornelius, NC USA
Too many others to list...
cccpastorjack is offline
post #4 of 21 Old Feb 3rd, 2008, 5:33 pm
Steve,
I have to agree with Jack, no point in using "used" brake hoses. Always replace with new. The early brake systems only monitor the wheel sensors and the ABS unit itself. No brake levels are monitored. That was the same area Steve Rowe had a blow out on his 99 after they put a new MC on. Good rule of thumb is replace all rubber brake hoses at 5 year intervals. Even better is to go to teflon and braided stainless lines.
post #5 of 21 Old Feb 3rd, 2008, 5:40 pm
Originally Posted by jzeiler
Steve,
+1 on the braided lines. Me and Grif did it (Hank did mine, and I guess Grif did his own) and I'll swear, the finger pull and foot pressures felt more 'solid' afterwards - to me at least. YMMV, tho.
post #6 of 21 Old Feb 3rd, 2008, 6:50 pm
Wolfgang's Avatar
Were do you get the braided lines? I am about to replace pads and change the fluid, this would be a good time to replace and upgrade the hoses.
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
post #7 of 21 Old Feb 3rd, 2008, 7:03 pm
grifscoots's Avatar
Here ya go. I actually sent mine to them so they could duplicate them. http://www.spieglerusa.com/cfm/brakelines.cfm
-=grif=-
Grok
grifscoots is offline
post #8 of 21 Old Feb 4th, 2008, 7:16 am Thread Starter
katnapinn's Avatar
John there may have been but.... it was a wet and muddy ride that day so the bike was covered in dirt when i got home.
Has anyone replaced the entire rear brake line (both flex and the steel tubing) with one stainless steel line? Seams like a better solution with less connection that can fail.
Stevie Shreeve
post #9 of 21 Old Feb 4th, 2008, 8:20 am
Once you go braided ... you never go back.
post #10 of 21 Old Feb 4th, 2008, 11:25 am Thread Starter
katnapinn's Avatar
I just found a place here in Austin that makes custom braided brake lines. Just bring your old lines in to match up the fittings.
Priced from $38.00 to $80.00 per line.
Hydraulic House 512-385-7100
Stevie Shreeve
post #11 of 21 Old Feb 4th, 2008, 12:43 pm
Gold Supporter
Lonewuff's Avatar
I don't know Stevie, maybe it's just me, but I would think sticking a screwdriver in a brake line like that is just asking for trouble later down the road. But hey...what do I know?
Maybe have them make several sets of those brake lines and let your brethren know you got em.
Jerry
2008 FLHTCU White Pearl
Lonewuff is offline
post #12 of 21 Old Feb 4th, 2008, 1:26 pm
Wolfgang's Avatar
Thanks Grif!
They actually list the K1200LT now. Not cheap...
Wolfgang
R1100RT 1997 Blue
Mark Twain
Wolfgang is offline
post #13 of 21 Old Feb 4th, 2008, 1:35 pm
Tom1200's Avatar
The brake line from the front handle bar to the coupling under the fairing is $85 from BMW alone. So 235 isn't bad for the hole set of rubber I assume.
Tom Ress
Great White North
Minnesota
Canyon Red 2000
You have to grow up to have a mid-life crisis!!!!!
I could play with women or with cars, I find cars are cheaper and you can write a book about cars a guy would understand.
Tom1200 is offline
post #14 of 21 Old Feb 4th, 2008, 1:48 pm Thread Starter
katnapinn's Avatar
Yea and the little 12 inch long one from the rear master cyl to the juction box is $50.00
Stevie Shreeve
post #15 of 21 Old Feb 4th, 2008, 1:49 pm Thread Starter
katnapinn's Avatar
One problem with that is your 2006 is different then my 2000
Stevie Shreeve
post #16 of 21 Old Feb 4th, 2008, 1:52 pm
Gold Supporter
Lonewuff's Avatar
Yeah...no screwdrivers stuck in hoses for one thing.
Jerry
Lonewuff is offline
post #17 of 21 Old Feb 4th, 2008, 2:04 pm
zippy_gg's Avatar
I agree, especially since there are 6 braided lines in the kit!
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #18 of 21 Old Feb 4th, 2008, 2:52 pm
Wolfgang's Avatar
You right, if you add the OEM prices up this is almost a bargain . But it's not meant to be a bargain bike anyway.
Wolfgang
R1100RT 1997 Blue
Mark Twain
Wolfgang is offline
post #19 of 21 Old Feb 4th, 2008, 3:40 pm Thread Starter
katnapinn's Avatar
Steve,
John funny thing is I just talked with Tony and the master cyl. DID come off Steve's bike . So a lil piece of Red Rover WILL be on the road still
Stevie Shreeve
post #20 of 21 Old Feb 4th, 2008, 4:13 pm
That's good at least you have a brand new (very slightly used) MC.
post #21 of 21 Old Feb 4th, 2008, 5:26 pm
NRuest's Avatar
When one of my front brake lines sprung a leak, I asked these same questions. Everyone recommended the Spiegler lines. The dealer wanted $80 for the one (of six) lines that I needed and the set of six from Spiegler was about $235. A bargin. The local Cycle Gear shop got them in for me at the same price as the Spiegler site. I did the front at that time and just recently changed out my rears. Not a bad job and did seem to give me a better "peddle".
Next I am changing out the scored rear rotor and new pads with EBC from Cycle Brakes.
< - - - Norm Ruest - - - >
South Florida
2000 K1200 LTC Canyon Red
MOA# 145086
“Its unexplained, because they haven’t explained it. Maybe they could explain it, but they've tried and they can't, because it's unexplainable.” - Ruest
NRuest is offline
Yet another rear end mystery! gdroege K1200LT 10 Oct 28th, 2007 1:59 pm
Rear brakes, skreeeeeeach, metal on metal BecketMa K1200LT 11 Feb 6th, 2007 5:59 pm
Rear END????? kip K1200LT 13 May 24th, 2006 9:32 am
Rear brake squeal linked to front brakes? Vince_nj1 K1200LT 19 Apr 2nd, 2006 11:37 am
Rear Brakes Sticking mjordans2000 K1200LT 6 Feb 26th, 2006 4:49 pm
