6000 Mile Service - what oil(s)? - BMW Luxury Touring Community
post #1 of 26 Old Jan 31st, 2008, 4:41 pm Thread Starter
I am scheduled for the 6000 mile service this weekend and have read numerous opinions about synthetics and when to start. So "for fun" I am looking for a semi-collective opinion about which fluids to change and what to use for the 6000 mile. Fire away and thanks in advance.
Duane
Mag Black 2006 LT
Three loves - motorcycles, good wine, and contrabassoon...none of which mix. Engineer by day to pay for them all.
Duane_in_Florida is offline
post #2 of 26 Old Jan 31st, 2008, 5:08 pm
grifscoots's Avatar
"For fun", I'd use Wesson Oil. That way if you ever wreck out in the boonies, you can deep fry the rabbit you catch in a snare.
-=grif=-
Grok
grifscoots is offline
post #3 of 26 Old Jan 31st, 2008, 6:11 pm
bghubr's Avatar
All depends upon the break in.
If you are not using any oil I'd go for the synthetic (This means the rings are seated well). If you are using a little oil stick with the Dino until the rings seat themselves. JMOO
Brian Hubbard
2005 RT Dark Grey
Carpe Diem
bghubr is offline
post #4 of 26 Old Jan 31st, 2008, 6:31 pm
I agree with Brian.
TimVipond is offline
post #5 of 26 Old Jan 31st, 2008, 8:10 pm
wacolt's Avatar
Next oil change, I'm going with Amsoil 20w50 engine oil; the previous owner gave me a case of BMW dino and didn't want to waste it. Trans and FD are already Amsoil.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
post #6 of 26 Old Jan 31st, 2008, 8:47 pm
LAF
LAF's Avatar
If you are in warranty ask your servicing shop, and don't argue with them.
Mine knows I want to use Synth and told me we will look at it at the 12,000.
I trust them so I will go along with them as I have said before, in a warranty situation, they are your ONLY advocate with BMW. I am don't want to be hanging out for anything by not following my Service Managers advice.
I ran Nikasil barrels (sp) on my Harley and at 2000 miles I had Synth in it. I also heat cycled the motor and seated the rings pretty aggressively. At 2000 miles compression was right where it should be for the cam, heads, and deck height. Leak down was within 2 of each jug.
So Brian is correct that as soon as rings are seated you can run Synth.
Now flavors of Synth will just cause everyones PMS to flair but I like Amsoil, or Mobil 1. I have used Royal Purple, Red Line also.
I was using a Synth 75-90 in the FD, but I will go to 80-90 after reading a bit more on it, but have huge doubts that it matters one bit between the two.
In the trany I use 90-140 Synth.
after the 600 I changed at 3000, and will change it at 9000 also. I used good old Castrol GTX 10-40 because it was Fall here in PA. I am due for my 6000 and will get BMW oil from my shop. At 9000 I will do it again and use 20-50 Castrol GTX as it will be summer. Good Dino oil is cheap and 3000 miles on it is enough by my opinion.
The cool thing is my shop don't care if I carry my own oil in because of what I prefer. So I take a quart of each Synth for the FD and tranny and they don't mind a bit. When he says I can go Synth I will carry four quarts of that also.
He gets labor, I buy the filter and crush washers for my in between changes from him, and usually find something else I want, or need to buy to support him.
Just the way I look at maintenance, and my shop.
Sorry so long
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #7 of 26 Old Jan 31st, 2008, 9:53 pm
Smile
Consider Shell Rotella 5W40 Synthetic. Available at most WalMart's in a one gallon container for 'bout $18 bones.
Bruce Harris, Jr.
Burlington, NC USA
1995 Harley-Davidson FLHTCUI Anniversary Edition
2005 Bushtec Turbo +2
BruceHarrisJr is offline
post #8 of 26 Old Jan 31st, 2008, 10:18 pm
Go to Wally World or Autozone and get a good oil that meets all of the specs in your manual. That goes for oil, lube, coolant..........the whole works.
rkimmel2 is offline
post #9 of 26 Old Jan 31st, 2008, 10:36 pm
BMW Guru
Ted Shred's Avatar
I would wait until at least 12k to switch to synthetic.
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #10 of 26 Old Jan 31st, 2008, 10:50 pm
I use Lucas oils exclusively in the LT, the Ram and the Buick. They cost a little more and can be hard to find, but I've yet to have a lube related problem in twenty years. Saw a demonstration in a truck stop many years ago which really impressed me and have had several million mile diesels since.
Check them out, I don't work there or own any stock.
http://www.lucasoil.com/index.sd
Hackercraft
03 LTE
72 75/5 Gone to a new home
03 R1200CLC Hannigan Classic ordered
BMWOA # 134205
Never argue with idiots, they'll bring you down to their level and beat you with experience.
Hackercraft792 is offline
post #11 of 26 Old Feb 1st, 2008, 7:15 am
Old Slow Guy in A Fast Car
katnapinn's Avatar
My BMW dealer here LoneStar BMW said not to switch to Synthetic oil till 18,000 mile This allows for proper beak in
Stevie Shreeve
katnapinn is offline
post #12 of 26 Old Feb 1st, 2008, 7:47 am
BMW North America told me I could switch to synthetic after 6,000 miles.
Amsoil told me I could switch to synthetic immediately.
I switched to BMW or Mobil 1 synthetic motorcycle oils on my 2000 K1200LT at 6,000 miles and enjoyed that bike for 137,000 miles.
I switched to Amsoil synthetic motorcycle oils on my 2006 K1200LT at 600 miles. I currently have 27,000 miles.
Neither consume oil. Both run better on synthetic than conventional oils. No problems.
No reason to wait. I'm glad I didn't.
post #13 of 26 Old Feb 1st, 2008, 4:51 pm
Oil
That is not the correct viscosity for the LT motor. Nowhere in the manual does it recommend 5-40.
HarvRead is offline
post #14 of 26 Old Feb 1st, 2008, 5:52 pm
Smile
Steve,
We all keep hearing this. I wonder why they can ship Corvettes, Porsches, and I believe some of the new Bimmers with synthetic as the factory fill.
It think it's a throw back to "old" break-in ideas ("use non-detergent oils to achieve proper break-in your airplane engine", etc.)
FWIW I jumped the gun and switched both my RT and current LT to synthetic at the 6,000 mile mark. Never added to either bike between changes.
Good luck,
Bruce
beartooth is offline
post #15 of 26 Old Feb 1st, 2008, 5:58 pm
hallzee's Avatar
Man... I LOVE these "Oil Advice Threads"!
Seriously... Should I go synthetic? Oh yeah, I did at 18k.
Brian
CCR-R: 2018, Russellville
'13 K1600 GTL-P - "Eva"
IBA #31242 (SSx2, BB, BBG)
MOA #136148
hallzee is offline
post #16 of 26 Old Feb 1st, 2008, 6:07 pm
Originally Posted by beartooth
Steve,
Good luck,
Bruce
Be interesting to know if those 'other' cages have Nikasil lined cylinders. From what I've read and heard, that is the primary reason for running the break-in period on the LT - Nikasil takes several extended mileage runs of various speed/heat/cool/pressure changes to seat the piston rings properly against the Nikasil surfaces. I'm no engineer, butt on plenty of occasions, I've listened to those who are; to mechanics with ample experience; and read several white papers on the subject - I'm figgerin' they're smarter in that aspect of wrenching than I am, so that's (wuz) good enough for me and ole Toad. We took that advice and waited until the 18K service to change to synth. YMMV.
post #17 of 26 Old Feb 1st, 2008, 6:23 pm
This engine uses Nikasil - Chevrolet LT5 engine, designed by Lotus and used exclusively in the Corvette ZR-1 (Uses synthetic Mobil 1 right from the factory).
Amsoil1 is offline
post #18 of 26 Old Feb 1st, 2008, 6:34 pm
LAF
LAF's Avatar
Great point on the cylinder type.
My Nikasil Harley heat cycled 6 times, working up to 15 minuet run time, cooling between each one until totally cold, before it ever saw a mile.
I do think it is the safety margin because of the Nikasil. I don't think one can say rings are seated at any specific time without compression tests. So I think Dealers play it safe. Personally I think my rings are seated as I have rode a lot of slab and I have played in the upper RPM a bunch, and no oil use.
I hear the 12 and 18,000 mentioned the most on this Forum as dealer recommendation.
Lee
BMW MOA #135959
LAF is offline
post #19 of 26 Old Feb 1st, 2008, 8:24 pm
Both local dealers here in Denver recommended not to switch to Syn until 18K. I followed their advice. I don't see what the rush is. Dino oil is cheap and BMW gives you 6K change intervals.
Now I use amsoil..
rglassma is offline
post #20 of 26 Old Feb 1st, 2008, 8:59 pm
Smile
Could be, but a www.CAT.com oil analysis report performed on a regular basis will show you nothing but good results. It's all I've used on, lemme see; 1998 R1100RT, 2000 K1200LT, 2001 R1150GS, 2002 R1150RT, 2005 K1200LT, 2006 Honda GL-1800A, and currently my 1995 Harley-Davidson FLHTCUI. Happy motorin'!
Bruce Harris, Jr.
Burlington, NC USA
post #21 of 26 Old Feb 1st, 2008, 9:25 pm
Could you post the report?
post #22 of 26 Old Feb 1st, 2008, 10:24 pm
Hi Dick,
I don't have the factory print out papers at home but you'd be amazed at the factory break-in on a Continental engine for a Cessna in 1985(it had Nikasil cylinders). My recall is about 10 minutes of increasing RPM to warm up and when oil temps stabilized they firewalled it (all of 2650 rpm) in a test cell for the next 15 min. and watched the temps climb. I was surprised at the "abuse" but it was a great engine that never used oil. Total test cell was 30 minutes with cylinder head temps pushing the high 300's. I know we have some aviation mechanics on here who know a bunch more than me. Maybe rings like to be seated in a hurry.
Ride safe,
Bruce
post #23 of 26 Old Feb 1st, 2008, 10:54 pm
Wolfgang's Avatar
Another AMSOIL thread... If this site only had an ignore function
Andy, can you do this, for a donation of course...
Wolfgang
K1200LT 1999 Champaign SOLD
R1100RS 1994 Teal SOLD
R1150RT 2003 Blue (Sold)
R1100RT 1997 Blue
Pest, Budapest Hungary
Mark Twain
Wolfgang is offline
post #24 of 26 Old Feb 1st, 2008, 11:56 pm
Hi, Harv - yeppir, it do. My Service and Technical Manual for ole Toad sez, on page 80, it's ok to use SAE 5 W-X (X>40) at outside temp range of -20F to +85F. Sez it's available at the BMW dealer. Calls it 'Special Oil'.
post #25 of 26 Old Feb 2nd, 2008, 12:50 pm
Beamerdude's Avatar
I used Amsoil from the beginning, Never a problem.
Please Visit My Website
Beamerdude is offline
post #26 of 26 Old Feb 6th, 2008, 11:26 am
browad's Avatar
As a side note, if you're getting the service done at Daytona/Orlando, they won't put synthetic in a bike with less than 12k.
Adam
2006 K1200LT 2001 Kawi KLR650
The
wants YOU!
browad is offline
24,000 mile service, how much does it cost? motorroy K1200LT 16 Jul 24th, 2008 8:21 pm
What's involved in 600 mile service? Effjay RT Series 12 Aug 10th, 2007 10:35 pm
18,000 mile service costs; ouch! Dewman K1200LT 22 Apr 20th, 2007 3:13 am
24,000 mile service mark_sat K1200LT 11 Feb 26th, 2007 10:30 am
6,000 mile service smity K1200LT 6 Feb 26th, 2007 10:18 am
