2 questions - BMW Luxury Touring Community
post #1 of 7 Old Jan 30th, 2008, 8:15 am Thread Starter
378
2 questions
My brake failure light says on when I first start the bike. Then after it warms up it goes out.
Also having trouble shifting in the cold. Will not shift to first. Once it engages all works fine.
Any suggestions.
378 is offline
post #2 of 7 Old Jan 30th, 2008, 8:37 am
c00k1e's Avatar
I used to have that problem with the gears. I think I just slightly twist the throttle the very first time I go into 1st, while putting slight weight on the actuator. 2nd nature now
c00k1e is offline
post #3 of 7 Old Jan 30th, 2008, 9:58 am
zippy_gg's Avatar
When you start the bike the ABS system is waiting for you to start going, hence spinning the wheels, so it can test itself. Then the ABS failure light goes away (assuming all is well with your braking system). Same thing on some cars. Now if your ABS light stays on while driving you will need to look into it. Many threads on that subject, and more often than none the resolution is to add brake fluid in the rear reservoir, or your battery may have a low charge.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #4 of 7 Old Jan 30th, 2008, 10:17 am Thread Starter
378
Thanks, that makes me feel better. I was a bit concerned.
378 is offline
post #5 of 7 Old Jan 30th, 2008, 3:27 pm
Chick's Avatar
Let the clutch out a little bit and the bike will go into first easier.
Chick
Saved by Grace -- Ephesians 2:8-9
2005 Graphite LT
BMWMOA #118809
NRA Life Member
Chick is offline
post #6 of 7 Old Jan 30th, 2008, 4:09 pm
motorman587's Avatar
Any suggestions.
Check the brake fluid. Mine did that once in the cold, and the rear brake thingy was low.
Florida
2004 BMW R1150R Black
motorman587 is offline
post #7 of 7 Old Jan 30th, 2008, 5:06 pm
jdunique's Avatar
Two things to check
Contributors to the inability to shift into first gear can be that that transmission oil is a heavy viscosity (140) and the temperature is cold but probably the most likely one occurs if you have had the peg lowering kit installed and the shift linkage has been adjusted to lower the shift pedal. If this is the case a couple of threads shorter on the shift linkage will cause it to shift normally.
jdunique is offline
Questions, questions and more questions! cloydg K1200LT 11 Jun 4th, 2007 10:19 pm
Major GPS questions! harrowbmw GPS 4 Aug 30th, 2006 7:53 am
Preparing for STC -- Last-Minute Questions hschisler K1200LT 11 Apr 20th, 2006 6:31 am
Kids Questions On The Bible mconlogue Humor 4 Apr 3rd, 2006 12:58 pm
Some service questions from a Newbie bigbear K1200LT 6 Mar 23rd, 2006 7:49 am
