k1200lt speakers - BMW Luxury Touring Community
post #1 of 16 Old Jan 27th, 2008, 12:00 am Thread Starter
charlesgartman's Avatar
k1200lt speakers
I have an '03 LT. My right side, front and rear speakers are not working. I recently installed a communications system and coincidentally, the right side helmet speakers are not working either. Does anyone know what the problem might be?
charlesgartman is offline
post #2 of 16 Old Jan 27th, 2008, 9:21 am
RVB1019's Avatar
Hate to tell you, it could be the radio unit itself. My 03 crapped out the same way.
Before panicing, did you try to reset the unit? To reset, disconnect the battery (some say an hour, some say overnight) and then try it.
I burnt my unit playing with the powerlet plugs. Shorted something out and whamo!- no radio.
New- a radio unit w/CD is $700-750. The good news, you can pick up a used tape deck unit for under $250. It will fit with no problem. If you want to replace it with another CD unit- over $300.
Good luck!
Rob V.B.
2015 Triumph Explorer 1200
2007 BMW GT (SOLD)
2003 BMW LT (SOLD)
RVB1019 is offline
post #3 of 16 Old Jan 27th, 2008, 12:01 pm Thread Starter
I'll disconnect the battery for a few hours and see what happens.
Thanks for the info.
post #4 of 16 Old Jan 28th, 2008, 5:33 pm Thread Starter
Well that didn't work. Does anybody else have any suggestions before I try to locate a cd/radio unit?
post #5 of 16 Old Jan 28th, 2008, 6:03 pm
It may be a "reach", but here goes... did you try reseating all the connectors? Are the connectors all clean? Did you put some electrical grease on the connectors?
J.M.J...
Dcn Channing
post #6 of 16 Old Jan 28th, 2008, 8:50 pm Thread Starter
I've traced all the wiring and made sure that all connectors were seated. Although, I didn't use any electrical grease. I guess I'll take everything apart again and apply electrical grease.
Thanks.
post #7 of 16 Old Jan 29th, 2008, 8:08 am
murray's Avatar
Thanks.
FYI Note if using Dielectric grease this product is a insulator not a conductor. I have seen many people develop electric problems after this application. The trick is to apply to the plug behind the connection.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #8 of 16 Old Jan 29th, 2008, 8:44 am
hip001's Avatar
grease?
electrical grease? does it work for better connections or to prevent corrosion?
1985 K100RT 90k
1981 R100RT 56k miles Sold
2000 K1200LT 48k miles Sold
2003 Victory Vegas-12k miles Sold
1982 Suzuki GS550L only 299 miles Sold
1997 Yamaha Vmax-15k miles Sold
1996 Suzuki DR650-17k miles Sold
1996 R1100RT-27k miles Sold
1995 K1100LT-85k miles Sold
1982 Honda CB900F-33k mikes Sold
BMWMOA 138762[/I]
hip001 is offline
post #9 of 16 Old Jan 29th, 2008, 12:47 pm
Prevents corrosion when applied correctly.
May prevent connection, when used incorrectly.
steamboatjohn is offline
post #10 of 16 Old Jan 30th, 2008, 11:28 pm Thread Starter
I certainly appreciate all of the replies. Unfortunately, nothing has worked thus far. I guess I need another radio/cd unit.
post #11 of 16 Old Jan 31st, 2008, 9:52 am
beemer100's Avatar
Question Speaker problems
Not trying to hijack the thread, but is their a wrong way and right way to use dielectric grease. When I used it last, I simply applied some grease onto the pins and attached the connecting plug to it.
James Hart
2002 LTE Titan Silver
1992 Yamaha Virago 750 (given to friend)
River Oaks, TX
beemer100 is offline
post #12 of 16 Old Jan 31st, 2008, 10:18 am
Here are some discussions on the how/why/where of using di-electric grease.
post #13 of 16 Old Jan 31st, 2008, 10:40 am
beemer100's Avatar
dielectric grease
Thanks Dick. I'll check that out.
James
James Hart
River Oaks, TX
post #14 of 16 Old May 27th, 2011, 8:18 am
Re: k1200lt speakers
2009 K1200LT Same issue. Left Side(F/B) speakers work, Right side does not. I'm trying find out if Warranty covers it since it is only year out the door of Morton's BMW in Va. Who I have not been impressed with reply to emails.
highnoon is offline
post #15 of 16 Old Jun 30th, 2011, 3:21 pm
Prime_Mover's Avatar
Has anyone attepted to have an old unit repaired at a radio repair shop?
My problem is the rear speakers quit. For a while my rear speakers would play, then quit. It was like the circuit protection was tripping on the amp portion of the radio. Now the rear speakers are out completely.
Cheers
Jeff
Prime_Mover is offline
post #16 of 16 Old Jul 1st, 2011, 8:42 am
I think several people have attempted to have it fixed, but with no luck. From what I have heard it is cheaper to buy a new one.
My opinion is that the radioCD overheats in the small compartment. When and if I replace mine, I am going to cut/drill several ventilation holes in the radio compartment to allow cooling air to flow through it.
simoncharles is offline
Replacement Speakers For '01 K1200lt??? cccpastorjack K1200LT 14 Apr 22nd, 2013 1:27 am
Molded ear plug speakers questions mos Bike Talk 8 Dec 9th, 2007 5:22 pm
K1200LT Speakers bmwbob1 K1200LT 3 Oct 18th, 2007 11:36 am
