Stereo Radio suffering from CRS! - BMW Luxury Touring Community
post #1 of 21 Old Dec 6th, 2005, 5:49 pm Thread Starter
Question Stereo Radio suffering from CRS!
Well I guess if it (CRS) can happen to me it can happen to a radio. Loose it's memory that is. I have diligently read the instructions in the BMW Radio manual about setting a particular radio station into memory. The reason for doing so is to allow the XM receiver to communicate with the FM band/station, etc. All is good for about 1.5 to 2 hours of riding and without warning or other issues the stereo will go to another channel/station and of course I loose my XM channel at the same time. Can anyone help or point me in the right direction as to how to trouble shoot this problem? LT is an '05 w/J&M CommSys. and XM SkyFi2 receiver.
Thank you very much in advance for your help and/or advice.
bharrisjr is offline
post #2 of 21 Old Dec 7th, 2005, 10:26 am
Question
I'm having a little problem understanding the exact problem. Is you LT's FM radio losing ALL of it's radio station memory locations. Or is it just jumping or scanning to the next programmed radio station after about 1.5 to 2 hours of riding?
post #3 of 21 Old Dec 7th, 2005, 11:09 am
If you are riding out about 2 hours, more than likely you are losing the reception from the FM station that you have programmed to receive the XM signal. Once you lose the FM reception, you have to tune to another FM station and reset the XM to receive on the new channel.
Road Warrior is offline
post #4 of 21 Old Dec 7th, 2005, 11:24 am
Beemerider's Avatar
Well on the '05's the radio normally shuts off after 2 hours so I'm wondering if your's has this anomaly instead of just shutting off?
Ride On!
Goodyear, AZ
"Yeah but its a warm heat!"
'13 SILVA K1600GTL
Beemerider is offline
post #5 of 21 Old Dec 7th, 2005, 11:37 am
Question
Originally Posted by Beemerider
Well on the '05's the radio normally shuts off after 2 hours...
I know that no matter what year the LT, they are all supposed to shut off after 2 hours when the bike is NOT running. A few have reported that their radios turned off after 2 hours while riding, and this was found to be a malfunction. Are you certain that this is a new "feature" of the '05 and newer radios?
post #6 of 21 Old Dec 7th, 2005, 11:58 am
mongo's Avatar
This may sound backwards, but is the XM shutting off after 2 hours? Then the
underlying unmodulated signal can come thru? XM has on its menu a turn off
time which also can be inactivated. Just a thought.
mongo is offline
post #7 of 21 Old Dec 7th, 2005, 2:16 pm
Beemerider's Avatar
Wasn't aware it was a few. I was under the assumption (05 LT's) "they all do that!" And...do we know of a fix?
Never meant to imply it was a "feature". I know mine (and Shirley many others...) does it and it's a PITA!!!
Ride On!
Goodyear, AZ
'13 SILVA K1600GTL
post #8 of 21 Old Dec 7th, 2005, 2:31 pm Thread Starter
Smile
No, the XM is not shutting off; the stereo FM looses it's signal/station (88.7 for example) and goes to the next strongest station. When this happens the XM stops playing (power still on etc.) because of the inability to receive/communicate with the former stereo station (88.7 or whatever station was previously programmed and placed into memory).
I did not know about the turn off timer. How does one deactive this timer? Thank you for your comments!
post #9 of 21 Old Dec 7th, 2005, 2:33 pm
In THIS THREAD in the old forum, at least two '05 owners (STEBS and Wmi) say that there '05s do NOT perform in this manner.
post #10 of 21 Old Dec 7th, 2005, 2:50 pm Thread Starter
Joe, the stereo will go to the next strongest signal after about 1.5-2.0 hours or so. The XM stays on and appears to be just fine. I never had this problem with my '00 LT and roady2.
post #11 of 21 Old Dec 7th, 2005, 3:10 pm
Question
At that point, are your programmed channels still there, or do you have to reprogram?
post #12 of 21 Old Dec 7th, 2005, 3:32 pm
pozo_izquierdo's Avatar
Question
Well, here is one more oddball who's radio has the auto-shut-off "feature" after 2 hrs regardless riding or not.
My bike is one of the first '05s. (Manufactured in January '04)
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #13 of 21 Old Dec 7th, 2005, 4:05 pm
Unless I completely do not understand the XM radio I have, I thought you TOOK your FM broadcast station with you - from the Roady itself. Did I miss something?
Lee Nowell
Black 01, LTC
BMWRA & MOA, AMA, IBA
lnowell is offline
post #14 of 21 Old Dec 7th, 2005, 4:23 pm Thread Starter
Smile
Me thanks you again Sir Joe! Next time I ride for more than two hours or so I'll try to turn the radio on right away. If that is all there is to it I can live with it. Strange though, why it turns off while going down the road. I can certainly understand and applaud BMW's efforts to shut it down with the engine not running to prevent battery drainage. Oh well, we'll see and report my findings in a few days. Thank you again for pointing me in the right direction.
Say, come on down to Stockton, Alabama for a big ole RTE on December 30th. Nothing but a bunch of Iron Butt types and wannabe's hanging out and such...
Your friend,
post #15 of 21 Old Dec 7th, 2005, 4:42 pm
munson's Avatar
Bruce, look in your radio manual and see if there is a new auto seek feature for 2005.
Blessings!
munson+
The Rev. John Munson
Vicar,
, Burkburnett, Texas
Vicar,
, Wichita Falls, Texas
2007 R1200RT "REV ZM"
IRON BUTT ASSOC. #37813
See my video:
munson is offline
post #16 of 21 Old Dec 7th, 2005, 5:47 pm
mneblett's Avatar
I just came across this thread -- Bruce, are you using the same FM transmitter with both units? Just guessing, but it sounds like the problem isn't the radio, but the FM unit stopping its transmission (at which point the radio, having lost its signal, shifts to a near-by stronger signal).
Where's the FM unit mounted? Any chance it's overheating, or that it's power is being interrupted? Have you tried a different FM unit, so that you can rule out yours being defective?
Just thought-generatin' here -- I'll ponder a bit more.
Mark Neblett
Fairfax, VA
mneblett is offline
post #17 of 21 Old Dec 7th, 2005, 6:38 pm
Ranger6's Avatar
Another approach...has this happened on multiple rides or on just one? Or put another way, did you happen to have a duffel strapped to the pillion seat at the time by any chance? I'll reveal my naivete here, but I was having the same problem a few weeks ago, until I realized the bag I had strapped down back there was changing channels while coming in contact with the passenger control buttons...oops.
ps...sorry I missed you guys on the way out, but I had to go. Next time, brother. Want me to PM you about what we talked about in the parking lot?
Al Hennigan
'03 Anthracite LTE
'09 GS Adventure
Middle Tennessee
Ranger6 is offline
post #18 of 21 Old Dec 7th, 2005, 7:37 pm
Okay John, I'll check into it tomorrow morning and report back.
Bruce Harris, Jr.
Burlington, NC USA
1995 Harley-Davidson FLHTCUI Anniversary Edition
2005 Bushtec Turbo +2
BruceHarrisJr is offline
post #19 of 21 Old Dec 7th, 2005, 7:44 pm
Mark, I cannot answer your first question because I did not do the installation of the XM-Charlotte BMW did. On your second question (where's the FM mounted?) I'm not clear on what you mean. Is the FM power modulator/cord what you are referring to? If so, my answer is still the same as I did not do the installation. Finally, no; I haven't tried a different FM unit thus far.
Thank you very much for your response. I will try over the weekend to do some additional troubleshooting and report my findings.
Bruce Harris, Jr.
Burlington, NC USA
post #20 of 21 Old Dec 7th, 2005, 7:44 pm
Smile
Yes Sir, fire at will!
Bruce Harris, Jr.
Burlington, NC USA
post #21 of 21 Old Dec 7th, 2005, 10:39 pm
Beemerider's Avatar
Originally Posted by a damn fine color bike ridin' bharrisjr
"Say, come on down to Stockton, Alabama for a big ole RTE on December 30th. Nothing but a bunch of Iron Butt types and wannabe's hanging out and such..."
Bruce, when you get to Stockton give ole Ray (Fagan) a bad time...go up to him and ask him why he refers to the color of your bike as "stucco"!
Then tell him Harry sent ya'!
Ride On!
Goodyear, AZ
'13 SILVA K1600GTL
Help, radio flashing "no Radio" docwagner K1200LT 10 Jan 30th, 2020 4:04 pm
BMW Replaced My Radio! wardenross K1200LT 22 Feb 6th, 2013 6:40 pm
Radio/CD Problem JohnR K1200LT 22 Jun 28th, 2009 9:43 pm
Radio static fixed (or "Curses, foiled again.") wcarter K1200LT 8 Dec 31st, 2008 8:37 pm
