Sticky Throttle - BMW Luxury Touring Community
post #1 of 2 Old Jan 18th, 2008, 9:11 pm Thread Starter
donscoin's Avatar
Sticky Throttle
I started to lable this "Sticky throttle cable" but then I happened to think it might not be the cable. I don't have a problem when it is 40 degrees or warmer but this evening when I got on her to go home, I noticed that it took a little more effort to open the throttle. When I would turn loose it would not return to idle, it just stayed where I had it. After 5 mile trip home, it was working a little better but still slow to return to idle. Temp outside was 28 degrees. Any ideas? Guess I need to tell you that it is a 2006 k1200lt with 13,00 miles on here. Don
donscoin is offline
post #2 of 2 Old Jan 18th, 2008, 10:12 pm
Axle's Avatar
sounds about right the heat will cause expansion freeing up the inner cable unless there is a kink in the cables, going by the year it probably a warranty issue
Regards Linton
and no koalas are not Bears
2002 K1200LT
2004 Cub Kamparoo Sprint
My Toys
1976 Datsun 260Z
1989 Nissan 300zx TT
Axle is offline
Throttle cable replacement notes johnrehder K1200LT 26 Aug 8th, 2013 8:54 am
Stiff Throttle 02lt K1200LT 19 Sep 17th, 2011 2:37 pm
Question - LT Throttle Cable Service Bulletin? DRM K1200LT 20 Aug 20th, 2008 8:26 pm
Throttle Body Adjustment? lovetomotor K1200LT 2 Apr 10th, 2006 7:29 am
New Zip, sticky throttle, not all cables parishollow K1200LT 1 Mar 29th, 2006 10:16 am
