Air box sensor - BMW Luxury Touring Community
post #1 of 5 Old Jan 18th, 2008, 9:05 pm Thread Starter
ChiefMn's Avatar
Air box sensor
Today I was taking the LT apart to replace the throttle cables,when I went to remove the air box,the wiring to the sensor had been unplugged and wrapped in electrical tape.Can anyone tell me a reason someone would do this?Should I reconnect it when I reassemble?Leave it off?I am a bit mystified why it was removed. Thanks for any help on this mystery. Jeff
Jeff Bokusky
Shoreview ,Mn.
2001 K1200LT ---
1973 Harley FLH 96 c.i.
1948 Harley EL 88 c.i.
1985 kawasaki KX250
1993 honda XR 200--
1978 Triumph Bonneville
ChiefMn is offline
post #2 of 5 Old Jan 18th, 2008, 9:16 pm
Here is a good thread on the benefits of pulling the air box temp sensor, Jeff. Worked great on ole Toad, a '99 LT.
post #3 of 5 Old Jan 19th, 2008, 9:12 am Thread Starter
ChiefMn's Avatar
Thanks Dick,You are a fountain of knowledge.
Jeff Bokusky
Shoreview ,Mn.
2001 K1200LT ---
1985 kawasaki KX250
1993 honda XR 200--
ChiefMn is offline
post #4 of 5 Old Jan 19th, 2008, 9:41 am
You're welcome, Jeff. Thang is, I can't take the credit - it ain't me!!! Somebody else did the hard work and I just come along and point it out now and then.
There prolly isn't anythang regarding the LT that hasn't been covered; talked about; solved; improved upon; suggested; shown; kicked around; some optimistic - some pessimistic --- all can be found somewhere in the HoW pages or on the old yahoo archived site and in somebody's thread/post. There's the fountain of knowledge!!
post #5 of 5 Old Jan 19th, 2008, 9:55 am
mtrevelino's Avatar
Some people have installed a on/off switch for the sensor. For you, ten months out of the year you can get by with the sensor plugged in (or switched on). Most people had problems with hesitation (below 2,000 rpm) when the temperatures go over 80 degrees. I was one of the lucky ones and had a new computer installed under warranty.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
Help, O2 sensor cables mixed! pozo_izquierdo K1200LT 4 Oct 20th, 2015 11:24 pm
Toilets, gas mileage and oxygen sensor!! bulletbill K1200LT 4 Nov 16th, 2007 11:52 pm
Wasn't the O2 sensor. Gene_Chapman K1200LT 2 Oct 9th, 2006 2:49 am
O2 Sensor Replacement STYLNLT K1200LT 3 Sep 27th, 2006 12:02 pm
Rear Drive Speed Sensor dgl57 K1200LT 12 Jan 13th, 2006 6:08 am
