2005 Brake fluid change question - BMW Luxury Touring Community
post #1 of 7 Old Jan 8th, 2008, 8:50 pm Thread Starter
fastpapaw's Avatar
After reading the instructions for changing brake fluid on the Integral ABS system, I have 2 questions.
1) My '05 doesn't have a split rear reservoir. Do the front and rear calipers both feed from that single one?
2) While flushing the fluid out through the calipers using the power from the pump, where do you refill - the rear fluid reservoir or the ABS unit?
'05 K1200LT
'17 R1200GSA
fastpapaw is offline
post #2 of 7 Old Jan 9th, 2008, 10:32 am
BeemerRiderBoB's Avatar
1) My '05 doesn't have a split rear reservoir. Do the front and rear calipers both feed from that single one? The rear reservoir on the right side of LT (under the seat) is for Rear Brake Control Circuit only---bleedpoints at modulator unit.
The reservoirs for the Wheel Circuits are on top of the brake modulator itself located on the left side of the LT (under the seat- just forward of modulator bleed points) and yes there are two reservoirs. -Modulator Reservoir Inboard---bleedpoints at front calipers
-Modulator Reservoir Outboard---bleedpoints at rear caliper
Yes the modulator controls the Wheel Circuits so bike has to be on and fluid will move quickly the more the levers are depressed.
BeemerRiderBob
Dallas/Ft. Worth
'82 R100 Sidecar
'91 R100 GS BumbleBee
'93 R100 GS/PD
'02 K1200 LTC- KIA 09/04/07
'03 KTM 450 Exc (living in Colorado)
'08 R1200 GS Adventure (Joy)
Only 41% of the World Left to Visit!
BeemerRiderBoB is offline
post #3 of 7 Old Jan 9th, 2008, 1:36 pm Thread Starter
fastpapaw's Avatar
Thanks Bob.
So does that mean I have to have a way to refill the modulator or will the fluid from the reservoir flow through?
'05 K1200LT
'17 R1200GSA
post #4 of 7 Old Jan 9th, 2008, 1:40 pm
Look here for a start and a link to a nice funnel set up that I am now using.
Link
post #5 of 7 Old Jan 9th, 2008, 2:09 pm
munson's Avatar
Bob, I think we need one of those neat Martini glass funnels that Zeiler is talking about.
Blessings!
munson+
The Rev. John Munson
Vicar,
, Burkburnett, Texas
Vicar,
, Wichita Falls, Texas
2007 R1200RT "REV ZM"
IRON BUTT ASSOC. #37813
See my video:
munson is offline
post #6 of 7 Old Jan 11th, 2008, 12:19 pm
Blind
Yeah...then we'll likely drink the old distilled vintage fluid eh? Uh, oh...no can do. I'm already blind.
BeemerRiderBob
Dallas/Ft. Worth
'82 R100 Sidecar
'93 R100 GS/PD
post #7 of 7 Old Jan 11th, 2008, 12:25 pm
Reservoirs
Thanks Bob.
Fluid does not flow from/thru one reservoir to another in any circumstance. Each reservoir (there are 4) has to be kept filled as you bleed. Jzeiler and others have devised several ways to make it easy or just keep your eye on the reservoirs as you bleed them to make sure the level doesn't get too low. A flashlight pointed at/in the reservoir helps you see better.
BeemerRiderBob
Dallas/Ft. Worth
'82 R100 Sidecar
'93 R100 GS/PD
Rear Brake Rotor and Pad Change Question surfran K1200LT 14 Jan 24th, 2008 9:11 pm
Brake fluid level....none visable at sight glass ltlfeat K1200LT 11 Aug 11th, 2006 12:04 pm
Does Old Brake Fluid Smell? Jerrod Maguire K1200LT 7 Dec 13th, 2005 3:00 pm
Rear brake fluid reservoir Colin1952 K1200LT 7 Nov 21st, 2005 6:40 pm
Brake Bleeding Question JPSpen K1200LT 4 Oct 19th, 2005 10:04 pm
