Fitting drive shaft question - BMW Luxury Touring Community
post #1 of 5 Old Dec 22nd, 2007, 5:01 pm Thread Starter
c00k1e's Avatar
Putting drive shaft splines in new final drive.
Circlip was a pain to get shaft free of old drive unit, but wont hold on new unit.
Do I use force? Rubber mallet?
c00k1e is offline
post #2 of 5 Old Dec 22nd, 2007, 5:32 pm
rdtebeau's Avatar
Yep, need to give it a little whack with a plastic faced or hard rubber mallet. It'll go in there and it needs to or it could cause some problems down the road.
Randal Tebeau
Blairsville, GA
CMA National Evangelist SE Region
BMWMOA, AMA, ABATE
2006 K1200LT
1996 F650
rdtebeau is offline
post #3 of 5 Old Dec 22nd, 2007, 6:19 pm
sheldan2's Avatar
Smile
you will here the tone change when the shaft is seated correctly
sheldan2 is offline
post #4 of 5 Old Dec 22nd, 2007, 7:09 pm
mtrevelino's Avatar
Make sure that you get it on all the way. When I had my FD replaced the technician did not get it all the way on. After a while, I had a severe vibration in which my BMW dealer thaught that it was the driveshaft. They ordered a new driveshaft but did not have to install it once they found that it was not installed properly.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #5 of 5 Old Dec 22nd, 2007, 7:43 pm Thread Starter
c00k1e's Avatar
Worked like a dream. Thanks guys.
I really didnt want to hit something that cost me so much, without checking!
c00k1e is offline
Another Rear Drive Bites the Dust - Question lad K1200LT 63 Jul 19th, 2013 1:34 pm
1990 Bmw K100lt, New Drive Shaft BREWSTER Bike Talk 4 Jul 2nd, 2007 10:21 pm
drive shaft failure roadcrave K1200LT 4 Mar 28th, 2007 9:55 am
Bad U-Joints??? rdtebeau K1200LT 21 Nov 21st, 2006 9:14 pm
