Clutch help - BMW Luxury Touring Community
post #1 of 6 Old Nov 4th, 2007, 2:37 pm Thread Starter
grahamw's Avatar
Clutch help
When I started to take my clutch to bits I did not mark it. Now I have all the bits off the bike I cannot even find the factory marks to line it up. Anyone have any clues as to what I should be looking for? or can I just fling it back together?
Also discovered that the clutch actaution rod is broken at the engine end ;-((
Many thanks
Graham Wintersgill
2001 K1200LT
1995 K75RT now deceased
grahamw is offline
post #2 of 6 Old Nov 4th, 2007, 4:04 pm
Many thanks
I think that they are only marked if the parts are enough out of balance to require "indexing" to get the entire assembly in balance. Mine were not marked either. Just put it back together.
post #3 of 6 Old Nov 4th, 2007, 4:23 pm Thread Starter
grahamw's Avatar
Thank you
David
Many thanks for the reply - that is good enough for me. Will replace the main seal while I wait for a new brass bushing.
Regards
Graham Wintersgill
2001 K1200LT
grahamw is offline
post #4 of 6 Old Nov 4th, 2007, 5:49 pm
murray's Avatar
Thumbs up Yellow-White -Blue
David
Regards
Look close and don't use aggressive cleaners on the parts otherwise the factory index markings will be gone. I have done this job way to many times.
The Germans mark all parts.
Good Luck!
Yellow- Clutch housing
White- Thrust Plate
Blue - Clutch Housing Cover
Separate by 120 degree intervals.
Pete Murray
IBA # 359 and
2014 RT
1973 R75/5
2002 LT 171 K Gone
2008 FJR 36 K Gone
Stroudsburg, PA
murray is offline
post #5 of 6 Old Nov 4th, 2007, 6:07 pm
Woolly's Avatar
Hi Graham, does this mean the transmission is now re-built?
  • MB SLK 350 MT
  • 1974 Triumph Bonneville 750
Woolly is offline
post #6 of 6 Old Nov 5th, 2007, 2:39 am Thread Starter
grahamw's Avatar
I wish
No - this means that I have finally finished doing things to the house and I am now allowed to work on my bike. Still have to fit new seals to the 2nd hand gearbox. Plenty of things to keep me busy.
Regards
Graham Wintersgill
2001 K1200LT
grahamw is offline
Clutch failure sonnata K1200LT 12 Aug 14th, 2007 11:19 am
latest clutch analysis cyclecamper K1200LT 17 Feb 27th, 2007 10:00 pm
