Newbie 2008 LT Bluetooth Phone issues - BMW Luxury Touring Community
post #1 of 7 Old Nov 2nd, 2007, 8:54 pm Thread Starter
j7mikae7's Avatar
Have a question...just bought new headsets for my new LT. These were installed by the dealer and are hard wired to the communcation system. I also have the Motorrad III nav and it seems to link up with my bluetooth phone. The problem is I can hear when I'm receiving a call but I can't pickup (the answer key is grayed out)?? Does the Nav only work with bluetooth headsets? Thanks for the help!!
MRod
j7mikae7 is offline
post #2 of 7 Old Nov 5th, 2007, 1:09 pm Thread Starter
j7mikae7's Avatar
Answering my own thread!!!
The answer is yes, only with Bluetooth headsets...has anyone figured out a workaround? This is really bugging me!!
J7
j7mikae7 is offline
post #3 of 7 Old Nov 5th, 2007, 1:37 pm
DaleB's Avatar
Well, my Navigator III lets me answer the call and I can hear the caller, but they can't hear me. So, I'm not sure the headset is required, but it still doesn't quite work as advertised.
Cheers,
DaleB
2007 K1200LT
DaleB is offline
post #4 of 7 Old Nov 6th, 2007, 10:48 am Thread Starter
j7mikae7's Avatar
Nav Issues
Understood, these are the details the dealer chose not to share with us about the Nav... So close, yet so far...Oh well, maybe sometime in the future this'll be resolved. Probably in a NavIV rollout
MRod
j7mikae7 is offline
post #5 of 7 Old Nov 6th, 2007, 12:41 pm
Yes You Need A Mic
If the phone is setup to link then it should connect to the nav when it is turned on. I have a Garmin zumo and my LG phone works well but my Motorola phone will not stay connected. You may need to try several phones to find one that works well.
ferggie is offline
post #6 of 7 Old Nov 7th, 2007, 6:24 am
Powerman's Avatar
The problem is more with the NAV III GPS unit. The GPS is not designed to run the voice to the COMM unit. You can bluetooth you phone to the GPS and it will work in the sense when your phone gets an incoming call it lets you know on the GPS screen. However the software and circuitry within the GPS unit does not allow for voice output communications from the the headset thru the COMM to the GPS to the phone. This information was provided to me by Garmin. You must have a bluetooth device to connect the GPS to the COMM unit. An automotive hands free device like the Motorola HF-820 will work. You connect it via cable to the input of your COMM unit and bluetooth link it to the GPS. Then bluetooth your GPS to your Cell phone and all will work pretty good. When you receive an incoming call the caller ID will come up on your GPS unit. If you want to make a phone call you can even call up your call list from your phone on the screen of your GPS. However if your phone DOES NOT ring thru the headset in normal operations it will not ring or give an indication other than the GPS screen when you get an incoming call. If you have it all hooks up and working and your music stops... wait about 5 seconds and say "Hello!"
I use a Motorola Razor phone with a Motorola HF-820 hands free and bluetooth link both to the Motorrad NAV III GPS. When i see an incoming call on the GPS I just press answer call on the GPS screen or you can send it to voicemail...(best option lol)
06 K1200 LT
01 Corvette Conv (RED)
BMWMOA # 128948
IBA #19196
Powerman is offline
post #7 of 7 Old Nov 8th, 2007, 8:14 am Thread Starter
j7mikae7's Avatar
Bluetooth Issues
Thanks for the info Mike, I had a question though...does it matter what input I use on the comm. system? phone, CB input or does it matter? I'm using the aux for my IPOD. I'm definitely going to try this!!
Thanks Again!!
MRod
j7mikae7 is offline
VOICE II GPS and BlueTooth Phone Ettore Intercom, CB, & 2-Way Radios 2 Apr 13th, 2010 8:38 am
NAV III and Bluetooth Phone question novkids GPS 16 Jul 20th, 2009 2:07 pm
Zumo & Bluetooth Phone to Autocom on the cheap wcarter GPS 1 Sep 2nd, 2007 3:24 pm
Garmin 2820, Baehr K1200LT and Bluetooth Phone stashvillepete GPS 13 Feb 27th, 2007 2:06 pm
What is the cell phone / bluetooth / Baehr status pozo_izquierdo Intercom, CB, & 2-Way Radios 5 Nov 15th, 2005 2:05 pm
