02 LT Cruise Diagnostic failure - BMW Luxury Touring Community
post #1 of 4 Old Oct 31st, 2007, 9:07 am Thread Starter
My CC on my 02 LT never worked since I got the bike a few months back. The previous keeps telling me it did. I finally got around to go through the CC diagnostic and in step 5 (Rotate the throttle against the throttle stop (LIGHT)) My light does not come on.
Any ideas what to look for?
HP
hpschaaf is offline
post #2 of 4 Old Oct 31st, 2007, 9:37 am
Check all fuse's and check the light to make sure it's not burned out. Simple minded responce, but I'm just trying to help you out.
PhantomK12LT is offline
post #3 of 4 Old Oct 31st, 2007, 9:45 am
Does the cruise light come on in the switch? My 02 had a problem with bad contacts in the switch itself. If it was turned on, 90% of the time the light would not come on, and the CC didn't work. If I flicked the on-off switch several times, the light would come on and all was well. I just leave it in the ON position. The CC cancels normally, so why not? Better than changing out the left switch assembly ($$).
Beautify America - Get a Tattoo!
2002 K1200LT (going, going, GONE)
Tat_n_Telle is offline
post #4 of 4 Old Oct 31st, 2007, 12:53 pm Thread Starter
The light in the CC switch (red LED) comes on and turns off. Step 1 to 4 work well in the diagnostic.
hpschaaf is offline
Cruise Control OD with new cables. airborneod K1200LT 24 Jun 14th, 2011 7:42 am
Final Drive Failures at 4% rate? hallzee K1200LT 27 Nov 24th, 2007 4:49 pm
MCCruise.com electronic cruise control installed Randy GS Series 16 Jun 22nd, 2007 10:04 am
Cruise control failure final report BobShirley K1200LT 1 Oct 13th, 2006 10:08 pm
Cruise Control Failure BobShirley K1200LT 5 Sep 16th, 2006 11:50 am
