battery problem? - BMW Luxury Touring Community
post #1 of 8 Old Oct 30th, 2007, 8:01 pm Thread Starter
battery problem?
It was 30 degrees this morning and as I was going to work I noticed my ABS lights had started flashing .. I shut the bike down and restarted to let the ABS do the diag.. poof the batt. didnt turn the starter.. I waited a few and restarted the bike and got to work...
This afternoon I started the bike and headed home but the ABS lights are still flashing...
Could if be coinkidink or could the batt cause the diag to fail???
What is a good batt these days??
Jerry,
2002 LT -[MidLife]
gaghai is offline
post #2 of 8 Old Oct 30th, 2007, 8:06 pm
zippy_gg's Avatar
Looks like the battery is your culprit. The electronics on the LT are very sensitive to voltage drops.
Batteries run from $70 and up. But still cheaper than a true ABS failure.
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #3 of 8 Old Oct 30th, 2007, 8:18 pm
ez_rdr55's Avatar
same
Same thing happened to me yesterday. I ordered the Panasonic.
EZ-RDR55
The opinions expressed herein are mine, and do not represent that of any other humanoid past, present or future on this or any other planet.
'95 H-D FXDWG
'06 Honda CRF250X
'04 KTM 450EXC
'97 Honda XR-600R
'04 K1200LT (Sold)
'07 K1200GT (Sold)
'09 Wee-Strom DL-650ABS
ez_rdr55 is offline
post #4 of 8 Old Oct 30th, 2007, 8:21 pm
Enthusiast - KI6CDF
Tom_Becker's Avatar
Exclamation Could be low on brake fluid
I've found that the onset of cold weather brings out marginal levels of brake fluid in the rear reservoir. It easily could be that. It comes and goes with the temperature. Be sure to take a look at the levels in both the front and rear of the reservoir.
Tom
Tom Becker
Rancho Mirage, CA 92270
2003 Titan Silver LTE "Cantabile"
2001 Black R 1150 GS
BMWMOA
AMA
IBA (SS1000, B2B-36)
KI6CDF
Tom_Becker is offline
post #5 of 8 Old Oct 30th, 2007, 8:37 pm
I too would check the brake fluid level. I usually see the ABS lights flashing whenever the weather turns cooler. Adding a little brake fluid makes the problem go away. May not fix the problem but is low cost compared to a battery.
I have had issues with not restarting after turning off and right back on. For some reason opening the throttle a little and then cranking seems to work for me.
ďRes ipsa loquitur, sed quid in infernos dicet?Ē
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #6 of 8 Old Oct 31st, 2007, 5:40 am
BecketMa's Avatar
When the battery is low, the Battery Tender will bring it up to snuff to start in the AM.
Reminds me to listen carefully when starting my bike. A couple of years ago, I had to replace my batt in Dec or Jan. Bout time to replace it again?
BecketMa is offline
post #7 of 8 Old Oct 31st, 2007, 7:23 am
JimH's Avatar
Originally Posted by Tom_Becker
I've found that the onset of cold weather brings out marginal levels of brake fluid in the rear reservoir...
Me too! Last month (first day with significantly cooler temps) I got the red wig-wag after the 1st start. I had normal braking, so I rode a bit. Stopped and restarted, problem went away.
Next day, same routine.
Problem went away after service on bike which included flush/refill of brake fluid. Since the volume liquid decreases with decreasing temperatures, it all adds up.
JimH is offline
post #8 of 8 Old Nov 4th, 2007, 12:48 am Thread Starter
Batt. replaced
Well I replaced the battery with an odyssey pc680..
wow .....the bike start with the touch of the starter button as apposed to the 2 try I have done since purchasing the bike..
The ABS lights are not flashing anymore ..will be pulling the tuppaware off to check the fluid level in the morning..
Jerry,
2002 LT -[MidLife]
gaghai is offline
A New Radio Problem? RVB1019 K1200LT 7 Sep 3rd, 2007 7:55 pm
Need Help Diagnosing -- Battery Problem? hschisler K1200LT 20 Aug 24th, 2007 12:34 am
'05 Lt Battery And Recharging With An Electronic Low Amps Tender ajs K1200LT 2 Apr 9th, 2007 11:11 am
Battery problem on Buddy's bike myk_edwards Chit Chat 9 Aug 24th, 2006 7:27 pm
Battery problem or what else johnkeyes K1200LT 2 Feb 13th, 2006 8:14 pm
