Is it time for a new bearing? - BMW Luxury Touring Community
post #1 of 13 Old Oct 29th, 2007, 7:20 pm Thread Starter
vernvernvern's Avatar
Question Is it time for a new bearing?
Howdy all,
I just got the November issue of BMWON and in it I read the FD article. I got things to watch for,(one being tiny pieces on the drain plug magnet) but not a good indication from the article as to what to do and how soon and how many pieces.
Particles on the FD drain plug magnet are an indication of pieces of the wheel side bearing. Sooooooooooooo, my question is.............do I put in a new bearing when tiny pieces(maybe a 1/2 dozen) first appear on the magnet???
I replaced the FD bearings (19000 under warranty) and have now traveled 23000+ miles on the new bearings.....................I changed the FD oil yesterday and see specs on the magnet.
IS IT TIME TO DO AGAIN?????
I'm changing the oil in the engine and FD every 3000 miles or so. I know that's more often than recommended, but it's not that costly and I like tinkering with my '03 LT.
Gruru input appreciated.
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
post #2 of 13 Old Oct 29th, 2007, 7:35 pm
RealWing's Avatar
My 2 cents are:
Visible metallic particles should not be evident in the oil and are a clear indication of impending failure of some part (most likely the bearing). The bearing balls should roll on a thin oil film as well as the gears and there should be no significant metal-to-metal contact. (There will be some microscopic iron particles from the gears sliding on each other - which is why the oil is very black until the gears bed in)
2015 K1600GTL
1970 Plymouth Superbird 440-6bbl
1969 Plymouth Barracuda Fastback 340-auto
1969 Plymouth Barracuda Convertible, 6.1 L SRT8 Hemi transplant
RealWing is offline
post #3 of 13 Old Oct 29th, 2007, 7:52 pm
Originally Posted by vernvernvern
Howdy all,
Unfortunately it is quite common to have a grey "paste" of very fine particles on the magnet. However, the drive can run a LONG time like that. When you see particles that are of a size to be actually visible to the naked eye, that is likely a precursor to an impending bearing failure. If I were to see these, I would likely replace/repair the drive.
post #4 of 13 Old Oct 29th, 2007, 8:10 pm
Also, keep in mind that the threads on the drain plug are soft. If someone tightens the plug too much, it can possibly break loose thread particles. This can also end up on the magnet of the plug. It happened to me..
rglassma is offline
post #5 of 13 Old Oct 29th, 2007, 10:10 pm Thread Starter
Exclamation Thanks Men
My thought's too but just wanted to get some verification on it.
Now it's to the Clymer and a little wrenching on my own.
Hopefullly I can tell by looking at the bearing that it is in fact the bearing that the particles are coming from. Might be worth the trouble just to open it up and have a look-see!
Just wish I had the dollars to just install a whole new FD.
I think this one is defective elsewhere.
Might give the dealer a jingle to talk to the mechanic that did the work on my FD 23000 miles ago and get his feedback. Maybe he'll be GOOD to me. LOL
Thanks again................your input is very helpful.
Vern
78 years young!
Converted HD rider.
Vern
post #6 of 13 Old Oct 30th, 2007, 7:43 am
jers99lt's Avatar
What I noticed
First symptom that I got was a metallic rubbing sound that increased in frequency with speed (tire rotation). It went away at higher speeds since it will be left behind you. The brake pads rubbing on the rotor was easily ruled out. The rubbing sound, over time, got louder and louder. I would say I put on 1500 miles with this sound before I was fighting a wobbly rear end. SA wrote it off to being an old bike ('99 w/ 38K).
HTH,
Jer
Jerry Palma
85 R80RT 'Lady in Red'
08 535xi Space Gray metallic
09 328i Silver Convertable
17 X3 Glacier Silver metallic
jers99lt is offline
post #7 of 13 Old Oct 30th, 2007, 11:54 am Thread Starter
Exclamation Happened much faster for me
HTH,
Jer
Guess you were lucky as when my FD went out the first time I only went about 25 miles(trying to get home )after hearing the FD noise.
So to avoid the "beside the road" breakdown, maybe I should replace the bearing(if in fact that's where the shiny flecks on the magnet are coming from)as a remedy!
After looking at the Clymer, I don't have the proper tools to do the job right.
78 years young!
Converted HD rider.
Vern
post #8 of 13 Old Oct 30th, 2007, 2:49 pm
NRuest's Avatar
FYI. I saw a 2005 FD with 7K miles on it on eBay. At this time it has no bids and is at $349 bid and a $425 Buy it Now.
NRuest is offline
post #9 of 13 Old Oct 30th, 2007, 3:28 pm
Long story short......a local friend with an 03 and 40k miles just had his FD rebuilt for the 3rd time. Diagnosis occurred at our chapter's rally in September - he recognized the strange vibrations starting, and when we pulled the filler plug and dipped a little finger in, there were flakes visible in the oil. In addition, simply rotating the rear wheel on the centerstand and listening to the rumble was enough to convince me the bearing was going - again.
While it is not definitive, for all of us that regularly use the centerstand, it only takes a few seconds to spin the rear wheel and potentially know if a problem is imminent (not starting, but IMMINENT).
BTW, based on info from this site, I got the service manager in the above case to check with BMW and confirm that it IS important to measure the runout on the bearing, not just drop in a replacement. Unfortunately, the special tool from BMW to do this measurement costs $850.
For myself, I carry a new bearing and seal in a rubbermaid container, AND I have a 3k mile rear drive in my garage (purchased from another friend's bike after it was triked), packed in an appropriate shipping container - one call home can get it on the way to me if I am REALLY in trouble.
joeb83 is offline
post #10 of 13 Old Nov 9th, 2007, 8:40 pm Thread Starter
Thumbs up Well MEN, Here is the good news!
Howdy all,
Today 11/9/07 Engles Motors BMW in Kansas City took a peek at my FD that just 3000 miles ago was showing me steel pieces on the FD drain plug magnet. It was still running smooth but wanted them to check it as I figured something was going on inside the FD. Bob took it apart and determined that indeed a new bearing was in order.
Soooooo, I beleive that if we check the drain magnet often enough we can eliminate the break down on the road. At least it did in my case.
Others have said that a FD breakdown has no telltale signs ahead of the breakdown. I feel that if we pay attention maybe we can.
Just my observation.
Carry on and be safe out there!!!
Oh and yes, a BIG thank you to Bob and the fellows at Engles Motors BMW in Kansas City , MO. A GOOD Dealer in my opinion!
78 years young!
Converted HD rider.
Vern
post #11 of 13 Old Nov 9th, 2007, 9:12 pm
Was it less than two years since the last repair? If so BMW should have picked up the costs of this repair.. ? Thought there was a 24 month warranty for dealer repairs?
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #12 of 13 Old Nov 9th, 2007, 10:12 pm Thread Starter
Thumbs up Didn't cost a penny!
Yes, all was paid for. It had been 13 months since the FD overhaul.
And you're right...........parts were covered for 24 months. I was well under that. I did expect to pay for some of the labor, but the bill was $0.00. What a deal!
78 years young!
Converted HD rider.
Vern
post #13 of 13 Old Nov 10th, 2007, 6:09 am
gdroege's Avatar
Ditto, Bob at Engle is the "Best" in my book!
Gary & Mary Droege
1999 K1200LT
2008 K1200LT
"Life ain't about how fast you run, or how high you climb, but how well you bounce."
gdroege is offline
New Steven Wright avonfloater Humor 18 Dec 1st, 2006 4:42 pm
Rear drive re-engineered maybe?????? hoodoodrum K1200LT 17 Apr 13th, 2006 11:18 am
Crown bearing question scott122262 K1200LT 4 Feb 28th, 2006 9:31 am
Crown Wheel Bearing Photos rjking K1200LT 6 Feb 19th, 2006 3:00 pm
Snowed in? Too cold? Winter project(s) time! messenger13 Chit Chat 17 Jan 2nd, 2006 6:59 am
