ABS Brake Pump Failure - BMW Luxury Touring Community
post #1 of 19 Old Oct 29th, 2007, 7:18 pm Thread Starter
I took my LT in for it's 18K service and asked the service tech to tell me why my "Brake Failure" light was on. After 3hrs he finally figured out that my ABS Brake Pump was bad. The bike had 2 weeks of warranty left so I didn't feel soooooo bad. Has anyone else had this happen? I'm told that the ABS pump rairly fails.
bgudmest is offline
post #2 of 19 Old Oct 29th, 2007, 11:36 pm
HornHonker's Avatar
No failure to report on my 05.
2011 BMW 1600GTL
2000 BMW R1100R
2008 Burgman 650EX
HornHonker is offline
post #3 of 19 Old Oct 30th, 2007, 12:03 am
BMW Guru
Ted Shred's Avatar
It does happen occasionally. Be glad you're in warranty. It's about two grand parts and labor
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #4 of 19 Old Oct 30th, 2007, 2:40 am
Tbird's Avatar
I say BULLHOCKEY on "rairly fails". I'm sure it's not real often. But according to posts on this lists it happens much more frequently than the rear drive failure (RDF) we all worry so much about. What I've always found strange is that given this is a more costly fix than the RDF why don't more folks on this board go apesh!t over this BIG issue. Maybe because you can ride away from a n ABS pump failure. I'll bet if you were out of warranty like I was when mine went bad you'd "feel SOOOOO bad"!
I had my brake fluid changed at the service spec intervals...but still only got 29K out of my pump. I was out of warranty on time but low mileage...BMW wouldn't work with me...what's new.
Tbird is offline
post #5 of 19 Old Oct 30th, 2007, 11:30 am
Tom,
You have a different "pump" that has been shown to be more failure prone than the newer Integrated units. But give them time and they too will fail.
post #6 of 19 Old Oct 30th, 2007, 11:32 am
Mine went out at 6K miles...
PhantomK12LT is offline
post #7 of 19 Old Oct 30th, 2007, 1:43 pm
BMW Guru
Ted Shred's Avatar
It doesn't get as much noise here because it doesn't happen nearly as often as FD failures. Sucks that yours was out of warranty
__________
2006 DRZ400E
2006 GT200
2005 R1200GS
post #8 of 19 Old Nov 7th, 2007, 9:27 pm
Exclamation ABS pump out
My 2005 K1200LT with 38,800 miles has had the ABS piston fail two months out of warranty (two days ago). Quoted $2000 parts and about four or five hundred labor. "not happy". Have a two hour drive to nearest dealer and spend thousands a year to ride. Thought the "German Engineering" would make this a fairly trouble free ride. Lots of fun goodies on this bike but I have to defend this purchase to myself to often. First and last bmw. I can't believe BMW doesn't even have a factory service manual for their bike! Going to look for used pump and dig in myself. Yuck Any help out there will be appreciated.
hudsonrt is offline
post #9 of 19 Old Nov 7th, 2007, 10:00 pm
dmatson's Avatar
When I got my extended warranty a week ago I paid $120 extra for the ABS coverage, glad i did.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #10 of 19 Old Nov 8th, 2007, 12:59 am
Chipper's Avatar
Mine went out on me with about 6300 miles....
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
2004 RTP Work Bike(Retired)
2002 LTE Totaled Aug/2011)
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #11 of 19 Old Nov 8th, 2007, 9:08 am
My 2005 "went out" when I was doing a significant traffic maneuver. ABS on, ABS off, ABS on...sorta... ABS off....
Drop #1.
Took 6 weeks to get a new one.. then it was bad... 2 more weeks and things are working great.
Oh.. that was around 6k miles.
J.M.J...
Dcn Channing
post #12 of 19 Old Dec 13th, 2007, 10:58 am
SteveHill's Avatar
ABS Failure
Mine went out by 16,000 miles.
2000 LTC
Pacific Blue
SteveHill is offline
post #13 of 19 Old Aug 31st, 2010, 11:34 am
mikeanderson611's Avatar
Re: ABS Brake Pump Failure
My '05 1200 LT had 26k mi./5+ yrs. and both abs lights came on. Happened right after pads replaced, so I figured sensor fault. Took it back to wrench and he said he bled system but rear abs failure, ft. wheel has abs, and don't ride it as is. I am waiting on the good fairy for $3K to fix. Dealer never bled fluids for first 4 years, and my wrench said yearly bleeding is recommended. Dealer sucks as usual. I would have gladly paid to bleed yearly since birth.
mikeanderson611 is offline
post #14 of 19 Old Aug 31st, 2010, 12:08 pm
PM sent...
Worse case, why not see if you can fix it yourself? Set a $ amount and then take apart.. if they want the "core" you can put back together..
J.M.J...
Dcn Channing
post #15 of 19 Old Aug 31st, 2010, 7:34 pm
mine is an'01 with 530000 miles i am in the process right now getting it fixed. i sent it to auto and truck electronics in tennessee. put it in put everything back together, didnt get out of the driveway, flashing lights again. i sent it back to the company and they are going to test it again. we shall see what becomes of this, right now i'm a little p.o.
edmann is offline
post #16 of 19 Old Sep 1st, 2010, 7:03 pm
bjedruszczak's Avatar
Is it really half a million miles? or it's a typo - 53K.
BJ
2015 R Nine T
2007 LT Storm Grey
2005 LT Gold (traded in for '07)
2007 G 650 Xchallenge
bjedruszczak is offline
post #17 of 19 Old Sep 1st, 2010, 9:08 pm
oops, i meant 53000 miles.
edmann is offline
post #18 of 19 Old Sep 1st, 2010, 9:49 pm
Are you sure it isn't the seat that makes it feel like half million miles?
J.M.J...
Dcn Channing
post #19 of 19 Old Sep 2nd, 2010, 7:30 am
mine failed on a highway going in a straight line, I had total brake loss no residual whatso ever, when I slowed to a halt using the gears the even below 10 mph the brakes would still not stop the bike my boots did. When I took it to a BMW owened dealer not a franchise I was told impossible for them to fail completely. Oh right I said so can the workshop manager drive my bike down the ramp into the workshop. He then comes up and says you were right they failed completly ! however he has to tell me from BMW it is impossible for them to fail ! I aproached BMW and they said do one looser what are you going to do about it !
He was very helpfull in trying to fix them. I stripped the pump and changing the fluid is not critical to it working as unless you have chunks of rubber over 2mm then there is nothing to blockup. There are pressure switches and my fault code was saying too much pressure in front circuit. everything mechanical was working fine. I tried like hell but could not get the pressure switch from anywhere ! the origonal manufacture ect.
itsallpoo is offline
ABS vs. Rear End Failure Tbird Surveys and Polls 11 Jan 22nd, 2007 9:12 pm
Brake Failure Warning Light rglassma K1200LT 10 Feb 7th, 2006 10:13 am
ABS Failure on 2000LT iowalt K1200LT 5 Jan 10th, 2006 11:20 pm
