Looking to use MP3 palyer on my LT - BMW Luxury Touring Community
post #1 of 22 Old Oct 28th, 2007, 11:46 pm Thread Starter
OU812's Avatar
I looked at the owners manual,02 LT, and it states that the AUX plug only goes to the headsets. Any way to get it to run through the speakers?
OU812 is offline
post #2 of 22 Old Oct 29th, 2007, 12:07 am
bflemingor's Avatar
Don't know what type of intercom you have on your scoot, but my stock unit on my '06 has an AUX plug that I use for my iPod. Works great for both speakers & headsets (which I never use).
bflemingor is offline
post #3 of 22 Old Oct 29th, 2007, 12:55 am
Gold Supporter
roadcrave's Avatar
Go ((FM modulator)) that your MP3 plugs into,no need for a CD...matthew
roadcrave is offline
post #4 of 22 Old Oct 29th, 2007, 1:59 am
If your 02 has the tape player like mine, you can use the cassette adaptor. I use it on mine and it woeks fine. I keep the player in the oddiments box.
Morley is offline
post #5 of 22 Old Oct 29th, 2007, 8:41 am
BrianD's Avatar
I have both an FM transmitter to plug the ipod into, and a cassette adapter.
Either will only cost $20 - $30.
Orange, NSW
'99 K1200LT - Basalt Grey (traded in for)
2007 GL1800 - Dark Orange Metallic
Ulysses Member 32701
BrianD is offline
post #6 of 22 Old Oct 29th, 2007, 9:12 am Thread Starter
OU812's Avatar
I only have the CD changer and CD player up front. I guess the FM modulator will have to work. Is that installed in line with the antenna?
OU812 is offline
post #7 of 22 Old Oct 29th, 2007, 9:59 am
sparky_k1200lt's Avatar
FM Modulator: one end plugs into your MP3 player. The other end: there isn't one. This thing is a mini FM transmitter, and you just need to tune your FM radio to the right frequency.
...Bob
2001 K1200LT der LadungsTršger
1978 GL1000
sparky_k1200lt is offline
post #8 of 22 Old Oct 29th, 2007, 12:03 pm
Old Dawg
scottydawg's Avatar
You could install a BlitzSafe in place of the CD changer, that worked really well for me on my '02.
Scott
Sacramento CA
HDDC Posse
''03 Ducati ST4S with ABS - '12 KTM 500EXC - '19 BMW GS/A
(Jessica Focker's) '15 BMW S1000RR - '17 KTM 350EXC-F - '09 Yamaha XT250
Some of the most asinine things people do are typically preceded by the two words "Watch this."
scottydawg is offline
post #9 of 22 Old Oct 29th, 2007, 6:59 pm Thread Starter
OU812's Avatar
Where can I find one?
OU812 is offline
post #10 of 22 Old Oct 29th, 2007, 8:15 pm
Old Dawg
scottydawg's Avatar
Now that I'm thinking about it, I have the one I took off my '02 and would be willing to sell it or I'm sure you can find one online if you look around. It worked very well.
Scott
Sacramento CA
HDDC Posse
post #11 of 22 Old Oct 29th, 2007, 11:08 pm
BrianD's Avatar
Here is what I use. It just sits in the oddments compartment.
Check out your local electronics shop ?radio shack? or where ever they sell iPods should have them too.
Orange, NSW
BrianD is offline
post #12 of 22 Old Oct 30th, 2007, 2:14 am
There was a thread on here and I believe an article in the HOW, about adding an aux input to the CD head units for plugging in an MP3.
Morley is offline
post #13 of 22 Old Oct 31st, 2007, 1:16 pm
FM Modulator
Quick question guys, I bought a really cheap FM Modulator to use with my LT, it worked, however the quality of the sound, especially deep noises distorted a lot. Do any of you guys have a good quality Modulator that doesnt do this? If so, what brand, i want one!
MneShim is offline
post #14 of 22 Old Oct 31st, 2007, 7:45 pm
Old Dawg
scottydawg's Avatar
I have never heard an FM modulator that did great quality sound. Direct wire would be the best way to go.
Scott
Sacramento CA
HDDC Posse
post #15 of 22 Old Oct 31st, 2007, 9:46 pm
dmatson's Avatar
Just add direct wired input to the rear of your radio you can get it from BMW for about $35. I put mine in the compartment next to the radio. Here is where it plugs in, lower set of pins on the right.
This is where i put the port and the ipod
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #16 of 22 Old Nov 1st, 2007, 6:06 am
Flattop's Avatar
DMATSON!
if I understand you correct, all you have done is to buy a Direct-connect-plug from your BMW-dealer and used this one to connect your Ipod to the Bike's stereo?
When you do it in this way, i suppose that you cannot get the Ipod to be controlled by the 'stereo pad' on the left handle? Neither can you get information to be displayed in the radiodisplay?
Is this correct?
(First post Btw so I send ou greetings from the North Pole aka Norway)
Flattop is offline
post #17 of 22 Old Nov 1st, 2007, 9:15 am
BrianD's Avatar
Quality is just as good as FM radio and no different to having the headphone pluged straight into the ipod.
Orange, NSW
BrianD is offline
post #18 of 22 Old Nov 1st, 2007, 11:43 pm
dmatson's Avatar
The only control that works with the direct plug-in is the handlebar volume control. What i use is a remote to change the ipod which is attached to my tank bag. When I listen to the ipod on a trip I usually just put the songs on shuffle then i can fast forward, or repeat, stop and turn off the ipod with the remote. I do have a Dice unit that replaced my cd changer that I can use with the handlebar controls also or i can plug into the Autocom.
14' KTM 1190
72' Honda SL 100
65' Honda CB160
70' Honda CB350
dmatson is offline
post #19 of 22 Old Nov 2nd, 2007, 3:43 am
Flattop's Avatar
So if i understand correctly this is it:
With the Ipod connected with the dircect wire, the only thing you control from the bike is the volum and the mute. Thas OK for starters.
With the DICE accessorybox :
will you then be able to control the songs too from the handlebar?
Or is this item from Neo Car Audio able to allow me to control the songs form the handlebar:
Had to use link and not a photo
Flattop is offline
post #20 of 22 Old Nov 2nd, 2007, 9:43 am
Montycs's Avatar
The Dice works great. You can see the song title and artist and you can control your iPod from the handlebar controls. I have never had any trouble with the Dice or the iPod
2002 R1150R rip
1996 R1100RT
Montycs is offline
post #21 of 22 Old Nov 2nd, 2007, 11:42 am
Flattop's Avatar
Then it looks like i am in the market for a DICE-box.
Thank God the dollar is not so strong these days.. Sometimes it isnt too bad to be a foreigner
Flattop is offline
post #22 of 22 Old Nov 2nd, 2007, 8:32 pm
wacolt's Avatar
Thanks for the tip; ebay steal for $0.99 plus shipping. Beats the WalMart price.
Rider of Stahlross
1999 Basalt Grey LT
2001 Classic Red Ducati 748
wacolt is offline
XM Radio to MP3 Software Needed jpalamaro iPod/MP3 1 Jul 30th, 2007 9:49 am
iTunes music to Garmin MP3 player wcarter GPS 3 Jan 10th, 2007 11:37 pm
Solo rider looking for bike to bike and mp3 mwnahas Intercom, CB, & 2-Way Radios 6 Dec 27th, 2006 12:53 pm
Any help where to buy a horn that... mp3 file attached buffalo K1200LT 8 Nov 2nd, 2005 5:54 pm
mp3 Player - Flash Memory Based ytk iPod/MP3 2 Oct 5th, 2005 9:57 pm
