Seal Failure Question - BMW Luxury Touring Community
post #1 of 7 Old Oct 28th, 2007, 10:33 pm Thread Starter
GWBMW's Avatar
I've read a ton of posts regarding synthetic oil, pros & cons, etc, and a few inferred that seal failures may be related (caused by) synthetic oils. Is there any basis for concern? Do the various synthetic oils have different additives that impact seals differently? How may seal failures are attributed to synthetic oil?
I'm looking for a less expensive oil than the BMW 15w50 Synthetic, but concerned that a change may cause seal problems.
Glen
Winfield, PA
'99 K1200LT Champagne
GWBMW is offline
post #2 of 7 Old Oct 28th, 2007, 10:50 pm
I have heard the same thing and have myself experienced several seal failures about 10K after changing to synthetic oil. But I also suspect lack of use for two years prior to my purchase of the bike. Plus seal failures on the LT is relatively common.
If I had it to do over again, I am not sure I would switch to synthetic. My recommendation is to evalutation why you actually want to switch..
I am really not sure there are real tangible benefits since BMW has an oil change interval of 6K on the LT. If you change oil more frequently, you may be just throwing money away if you switch.
rglassma is offline
post #3 of 7 Old Oct 29th, 2007, 2:05 am
Most "seal failures" (in cars) after switching to synthetics is attributed to the detergents used in them. The seal leaks were already there but the sludge /paraffin build up from regular dino oil has sealed them up. Along comes the synthetics and cleans that all out and now the leak can be found. Switching from one synthetic to another brand should pose no problems at all.
The "reason" for switching to synthetic is a simple matter of reduced friction and greater durability they offer.
Morley is offline
post #4 of 7 Old Oct 29th, 2007, 5:41 am
I can see this being true on seals that have many, many miles on them. But, in my case, I switched at 19K and within 10K I had leaks. It was recommended to me that I switch at 18K or beyond. At short oil change intervals (roughly 3K with dyno oil), I doubt there would be very much build up at all with such a low mileage count.
These engines are designed to last for multiple hundreds of thousands of miles.
I doubt that switching between different "TRUE" synthetic oils would make much difference though.
rglassma is offline
post #5 of 7 Old Oct 29th, 2007, 6:37 am
UltraLT's Avatar
Seal Failure
FWIW, I changed to Amsoil synthetics at about 18000 miles. No seal failures so far at 29000.
Ultra LT
UltraLT is offline
post #6 of 7 Old Oct 29th, 2007, 9:26 am
Ultra LT
Good... Glad to hear it. I suspect my contributing factor was the bike had sat for almost 2 years by the previous owner that should never had purchased the bike in the first place.
My main seal, input/output shaft seals were toast at 28K.. That 28K went on in 2 years. I am concerned that other seals will be failing. But, I can only take it day by day.
rglassma is offline
post #7 of 7 Old Oct 30th, 2007, 9:05 am Thread Starter
GWBMW's Avatar
Thank you all for your replies. One can never have too much info. Thanks again.
Glen
Winfield, PA
GWBMW is offline
dumb question i know. reasr transmission seal?? jgrenga K1200LT 2 Oct 24th, 2007 10:32 pm
Seal leak and clutch question mpillis K1200LT 7 Sep 17th, 2007 1:54 pm
Shaft seal pulling made easy Schweintechnik K1200LT 4 Aug 6th, 2007 7:21 pm
brake hose failure, question on replacing the clutch line lavamanz K1200LT 3 Jun 1st, 2007 10:46 am
Tranny output shaft seal failure. Gene_Chapman K1200LT 15 May 21st, 2006 3:09 am
