Heated backrest wire question - BMW Luxury Touring Community
post #1 of 10 Old Oct 27th, 2007, 6:51 pm Thread Starter
Tom1200's Avatar
I am trying to put a switch in so my wife can have the heated seat on but the heated backrest off. What wire would I need to interup. Is the brown the ground wire and if I cut it would this turn off the backrest power. Thanks for the the help
forgot to say there is a gray, black and brown wire.
Tom
Tom Ress
Great White North
Minnesota
Canyon Red 2000
You have to grow up to have a mid-life crisis!!!!!
I could play with women or with cars, I find cars are cheaper and you can write a book about cars a guy would understand.
Tom1200 is offline
post #2 of 10 Old Oct 27th, 2007, 7:04 pm
Retread's Avatar
Is it 2 wires?
I just bought my LT and haven't really looked into the wiring, but it shouldn't be complicated. If 2 wires go to the unit you should be able to interrupt either one and the circuit will be broken.
I assume you're just putting in a simple on off switch. If that's the case it shouldn't make any difference where in the loop it goes.
Seems like basic wiring to me.
*Update* This is also assuming that the backrest and seat are on different loops. If they're not then this won't work. Breaking the circuit anywhere would turn both off. Again, I haven't looked that closely at how the wiring works.
"Don't do anything you'd be embarrassed to explain to the paramedics."
Gary Helmers
Sparks, NV
2002 K1200LT
2003 XR250R
Retread is offline
post #3 of 10 Old Oct 27th, 2007, 7:05 pm Thread Starter
Tom1200's Avatar
has 3 wires because there is a high and low
Tom Ress
Great White North
Minnesota
Canyon Red 2000
Tom1200 is offline
post #4 of 10 Old Oct 28th, 2007, 12:15 pm
was
was's Avatar
Here's the schematic from the Clymer manual. If you want to interrupt just one circuit (high or low), you'll have to experiment to determine which wire goes with which circuit, and then put the switch on that wire. If you want to interrupt both circuits (backrest heater on/off no matter which setting the seat heater is on), then put the switch on the brown wire. If you want to get really fancy you could run both the black and gray wires from the seat to a potentiometer, with only the "high" backrest heat circuit coming out of the potentiometer. Then, no matter whether your passenger had the seat circuit on high or low, she/he could dial in the backrest heat from off to high. I think. Maybe. On second thought, consult someone who knows something about electric circuits and heater elements before doing anything you have read in this post.
Name:	LT Heat Schematic.jpg
Bill
Guilford, CT
'99 Canyon Red K1200 LT - Buddah Bike
was is offline
post #5 of 10 Old Oct 28th, 2007, 1:50 pm Thread Starter
Tom1200's Avatar
Thanks. I thought the brown was ground but the wire diagram I have is in german and I don't read german anymore. I just want to stop the power to on or off. Thank again. Tom
Tom Ress
Great White North
Minnesota
Canyon Red 2000
Tom1200 is offline
post #6 of 10 Old Oct 29th, 2007, 10:36 pm
sparky_k1200lt's Avatar
According to the Clymer schematic posted, there are 3 wires going to the backrest. The way to shut off all power to the seat back would involve a double pole switch, turning off both BLACK and GRAY wires from the seat to the seat back.
There are 2 heating elements in each seat portion. 'High' gives full power (black wire) to one of the elements both seat and back. 'Low' turns both elements on (gray wire), sharing the power, so they are not as hot as in 'High' setting.
A switch to control only 1 wire to the seat back would not completely shut off the seat-back, and may cause the heating elements to become hotter than what the they can handle safely.
...Bob
1978 GL1000
sparky_k1200lt is offline
post #7 of 10 Old Oct 30th, 2007, 9:49 pm
was
was's Avatar
Aha. Ask and ye shall receive. Thanks, Sparky. After I read your post I re-examined the schematic, and I think I understand what you said. However, for the sake of curiosity, if Tom1200 wants both back circuits to be off at the same time, would a single pole switch on the brown ground wire not work?
And what do you think about putting a rheostat or potentiometer somewhere in the circuit? There are times when "High" is too hot but "Low" needs a boost.
Bill
Guilford, CT
was is offline
post #8 of 10 Old Oct 31st, 2007, 2:45 am
RonKMiller's Avatar
Tom
The heated passenger backrest has a thermostat - somewhere - that switches off automatically when it reaches 122F. From what I remember it will stay off until the seat base switch is toggled to off, then to high or low - where it will reheat to 122F, then off again
"Like Butt-ahh!"
RonKMiller is offline
post #9 of 10 Old Oct 31st, 2007, 12:39 pm
A single pole on the brown wire at the seat back will still let one of the 2 heating elements get power (in through the black wire, out through the gray wire) and will increase the heating in one of the seat elements, when the switch is in the 'low' setting. Not sure if the seat's heating elements could take the increased heating for long. My owner's manual says to use the 'high' setting for quickly getting the seat warm, and to set it to 'low' afterwards. Also, switching the brown wire would only disable heat to the back rest when the switch is in the 'high' setting.
A rheostat would have to be a high-power one. The way a rheostat works is to steal some of the power, and get hot itself, so less power gets through. A PWM (Pulse-width-modulation) circuit would be better. This is what is used in 'heat troller' controllers used for heated garments.
...Bob
1978 GL1000
post #10 of 10 Old Oct 31st, 2007, 3:59 pm
Why not just unplug the backrest. It is a removeable item and has a connector. There is also a barrel connector under the rear seat where its wires pass through (it may be shared with some other circuits in the top case though).
Heated passenger seat w/out backrest? juggler K1200LT 2 Feb 3rd, 2007 7:57 pm
Question on Bakup Backrest??? michman Ergonomics & Rider Comfort 10 Dec 7th, 2006 10:21 pm
Wire question Phil_Adams K1200LT 1 May 11th, 2006 9:04 pm
Utopia Backrest Installed wcarter Ergonomics & Rider Comfort 0 Mar 27th, 2006 11:00 pm
