Rough running when cold - BMW Luxury Touring Community
post #1 of 8 Old Oct 26th, 2007, 4:02 pm Thread Starter
nobunaga's Avatar
Question Rough running when cold
Hey fellas!
Now that it's getting cold out in the mornings, my LT runs like crap when i first start it up. So much so that it will die on me a couple of times before it's warm enough to run. If i give it any gas it's dead for sure.
In one of my earlier posts we talked about wether to let the LT warm up before riding off. Most everyone said that it's to be started and rode off. That's definitely not going to happen like this.
What is necessary to correct this situation? Is it something simple that even I could do (no, i'm not a super-duper mechanic ) or is this something the dealer has to adjust?
BMWMOA #132765
2007 K1200LT Storm Gray Metallic
2003 F650GS Dakar
"Yoroshiku onegai shimasu"
nobunaga is offline
post #2 of 8 Old Oct 26th, 2007, 10:05 pm
wilbar00c's Avatar
Dennis, try this, after it starts, run the RPM up to 1500-2000 a few times, in the first 5-10 seconds. Put it in gear, then with 1500 rpm, slip the clutch to ride off. If you happen to ride down hill in the first 1000 feet, to a stop sign. Pull the clutch in to keep the rpm above 1500 rpm, or the engine will go sub-idle and stall in the first 30 seconds. It should act like a warm engine after 30 to 60 seconds.
If it takes more time then the above, with your 2007, give us more details. Did you have the 07 last winter? B.B.
wilbar00c is offline
post #3 of 8 Old Oct 26th, 2007, 10:38 pm
zippy_gg's Avatar
Have you tried resetting the TPS? This might help.
Turn ignition ON but do NOT start the engine.
Open the throttle fully and realease.
Open the throttle fully one more time and release.
Turn ignition OFF.
Then you are ready to get back on the road. Just start the bike as you normally would and ride...
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #4 of 8 Old Oct 26th, 2007, 10:50 pm
bustedknuckles's Avatar
Disconnect battery for a short while before this procedure. I recommend the negative cable(less chance of shorting the wrenches)for this.
Turn ignition OFF.
Only a biker knows why a dog sticks his head out of the car window
Stephen Moore
02 K1200LTC Silver
02 Uni-go (skittles reborn)
1975 R75/6 Black Still running strong
BMWMOA# 122791
AMA# 711312
CCR 02,03,04,05,07,08,
bustedknuckles is offline
post #5 of 8 Old Oct 28th, 2007, 11:44 am
was
was's Avatar
There is no way that this should happen. One or both of the above suggestions might work, but I'd take it to a dealer and have him/her hook it up to the MoDeTec. It's under warrantee, so this should cost you nothing but time. There are at least two temperature sensors (air and coolant), either or both of which may be involved, as well as a host of other digital dohickies (that's the technical term) that send info to the computer, which adjusts the air/fuel mixture for the operating conditions. Sounds to me that you are running too lean on start up, but that's just a guess. Only the MoDeTec can tell you if the sensors and computer are working correctly.
Bill
Guilford, CT
'99 Canyon Red K1200 LT - Buddah Bike
was is offline
post #6 of 8 Old Oct 29th, 2007, 2:49 pm
kriach's Avatar
Hi Dennis,
I do not have any problems with my 07 not idleing when cold. I usually only let it run for 30 sec before I take off (this is at 5 celcius). I would definately take it back to the dealership to have the problem fixed. The LT should idle fine down to below freezing temps without stalling.
Ken Riach
2007 K1200LT
kriach is offline
post #7 of 8 Old Nov 1st, 2007, 10:13 am Thread Starter
nobunaga's Avatar
Thumbs up Sorry it took so long...
He guys, sorry it took so long to respond to your posts.
Thanks for everyone's suggestions.
I guess it would be best to make the 1.5 hour trip and get it checked out.
Being under warranty and all.
I didn't think this seemed right. It's not like it's really been THAT cold so far either (low 40s).
Thanks again!
BMWMOA #132765
2003 F650GS Dakar
nobunaga is offline
post #8 of 8 Old Nov 1st, 2007, 11:59 am
info's Avatar
I had an 04 GT with cold start issues and had the ECU replaced.
Solved the problem, though in that case I think it was a widespread
problem with more than just a few bikes.
Hello 07 R1200S
Bye2006 LT
1982 R65
Buy More Warranty!
info is offline
Rough Running LT Adventure170 K1200LT 12 Jul 27th, 2011 9:50 pm
Rough running problem bmwrider79 RT Series 1 Jul 23rd, 2007 12:16 pm
New motor in bike, running rough kbikeusr K1200LT 20 May 20th, 2007 11:24 pm
ABS & cold weather. rando K1200LT 8 Nov 21st, 2006 8:29 am
