Tach & Speedo Surge - BMW Luxury Touring Community
post #1 of 7 Old Oct 25th, 2007, 11:36 am Thread Starter
GeezerBeemer66's Avatar
Tach & Speedo Surge
Anyone experienced this? My '05 LT tach will, from an idle, surge to about 3K RPM and drop right back to idle. The speedo will surge also, but not as pronounced... more like just a blip upward and back. The tach does not jump up near as far when motoring down the road, but at a steady speed, I will see an occasional blip upward. Myabe it was happening before, but I didn't notice this until I had installed the following electrical farkles (all installed within a few days of each other):
Caliper mount Motolights
Autoswitch to control Motolights from turn signal cancel button
DICE converter for iPod in place of 6-disc CD changer
Trailer wiring with Dauntless hitch
Is this surge a real problem or more of an annoyance?
R.I.P. George Wood 6-24-07
R.I.P. Harry Woolf 5-18-09
"Ride In Peace"
'07 R1200GSA - 27000 miles "Mad Max"
'06 FLHTCUI - 36K "Geezr"
'03 FLHT - 35K "Junior"
'05 K1200LT - 19K "Lumbering Rhinoceros" Sold
"We're reaching critical mass!"
GeezerBeemer66 is offline
post #2 of 7 Old Oct 25th, 2007, 10:26 pm
It is not normal and I would strive to correct it. It could just be a loose connector on the back of the instrument cluster (there are two). If that is not it then I would start with undoing each of the farkles one at a time to see when the surge goes away. When you find the one that is affecting it then look further as to why.
post #3 of 7 Old Oct 26th, 2007, 7:36 am Thread Starter
Thanks. I'll start removing them one by one and see if that corrects it.
"Ride In Peace"
post #4 of 7 Old Oct 26th, 2007, 1:00 pm
tach & speedo
What is the condition of your battery? These bikes do a lot of wierd things if the battery is now up to par. My tach & speedo needles would both jump from peg to peg when i used the brake. that was just before my battery let me down.
danbrown is offline
post #5 of 7 Old Oct 27th, 2007, 1:30 pm Thread Starter
Did replacing your battery solve the problem? I'm not sure if this battery is the original from June 2005. I do know that it's a gel battery, which may mean the original was replaced.
"Ride In Peace"
post #6 of 7 Old Oct 28th, 2007, 4:01 pm
I am not sure when BMW started using the gel batt. from the factory. my bike is an 03. I got 3 yrs out of orignal. when replaced it cured my prob. good luck.
danbrown is offline
post #7 of 7 Old Jul 21st, 2008, 11:09 pm
AlanLT's Avatar
Re: Tach & Speedo Surge
Did you find the source of this problem? I'm having the exact same symptoms on my '07 ever since they did the 24k service.
Alan
Garden Grove, CA
'07 K1200LT Biaritz Blue (97k miles)
'08 K1200LT Biaritz Blue (76k miles and climbing)
"Good judgment comes from experience, and experience - well - that comes from poor judgment." -A.A. Milne
AlanLT is offline
Speedo Fix ndmunro K1200LT 1 Aug 4th, 2007 8:00 pm
Speedometer Question BUGKILLER K1200LT 15 Jun 22nd, 2007 5:13 pm
Speedo failure 1st bustedknuckles K1200LT 6 Feb 15th, 2007 9:17 pm
Speedo inop 02' k1200 bustedknuckles K1200LT 2 Jan 21st, 2007 1:19 pm
speedo correction for older RT retiredjj RT Series 0 Sep 13th, 2006 10:18 pm
