rear shock replacement - BMW Luxury Touring Community
post #1 of 3 Old Oct 23rd, 2007, 8:22 pm Thread Starter
sheldan2's Avatar
Smile rear shock replacement
For those of you who have replaced your rear shock, did you have to take off the tank as the manual suggests or were you able to get a wrench under it to loosen the top bolt? thanks
sheldan2 is offline
post #2 of 3 Old Oct 23rd, 2007, 8:24 pm
Jabrown's Avatar
don't remove the tank unless you have bear paws for hands. I was able to get under it. Just make sure you get on the right bolt under the tank. there are two of them there, and I spent a lot of time on the wrong one. Learn as you go I suppose.
Jeremy
1999 Champagne
Bike #70151
Jabrown is offline
post #3 of 3 Old Oct 23rd, 2007, 8:39 pm
RonKMiller's Avatar
Take off several of the right fairing attachments, and loosen several more. Take a tennis ball and slide it under the plastic to gently bend the fairing away from the frame while you work.
You'll need to take the battery out and do a little gymnastics to get the nut on the top mounting bolt - it's really pretty easy.
"Like Butt-ahh!"
RonKMiller is offline
2004Rt Rear Shock Beemeroly Other R-Bike Discussion 0 Jul 3rd, 2007 11:09 pm
rear shock problem? pinero K1200LT 4 Dec 11th, 2006 2:08 am
Rear Shock Question Cycle_guy K1200LT 4 Jun 30th, 2006 8:04 pm
changing rear shock, step by step PhillWard Europe 1 Jan 24th, 2006 2:50 am
Replacement of rear shock suspension unit PhillWard Australia, New Zealand, and AsiaPac 3 Jan 17th, 2006 6:01 pm
