Where to get spark plug socket? - BMW Luxury Touring Community
post #1 of 15 Old Oct 23rd, 2007, 6:00 pm Thread Starter
browad's Avatar
Getting everything together for my 24k service which is still 8k off. In going over the parts (which is a very good idea to do beforehand ), found that the Bosch spark plugs are a funky 11/16" size. Haven't been able to find an appropriate socket either locally or on the interweb. I have looked at an 18mm spark plug socket, but that fits fairly loose.
Am I missing something here, or will I need to order a spark plug socket from a BMW dealer? Alternatively, I am amenable to a different brand of spark plugs if that is easier.
Cheers,
Adam
2006 K1200LT 2001 Kawi KLR650
The
wants YOU!
browad is offline
post #2 of 15 Old Oct 23rd, 2007, 7:00 pm
LAF
LAF's Avatar
Not really a "funky" size at all. 5/8", 11/16" pretty common. If you don't have a shallow wall deep 11/16" socket, then Sears got one for ya, and if you just "have to have" it, Sears will have a Spark Plug socket also.
Cheers,
Lee
17.5 R1200 GSW Black Low
ATGATT I am breathing proof.
BMW MOA #135959
LAF is offline
post #3 of 15 Old Oct 23rd, 2007, 7:21 pm Thread Starter
browad's Avatar
Well, Sears doesn't have an 11/16" spark plug socket, and neither does Snap On, Matco, etc. I could go for a deep 11/16" normal socket, just don't want the plug to get damaged using it. I can find the 18mm locally in stock however.
Is there something I'm missing in this equation?
Adam
The
wants YOU!
browad is offline
post #4 of 15 Old Oct 23rd, 2007, 7:31 pm
Chipper's Avatar
Did you check in your tool bag that came with the m/c.????
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
2004 RTP Work Bike(Retired)
2002 LTE Totaled Aug/2011)
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #5 of 15 Old Oct 23rd, 2007, 8:04 pm Thread Starter
browad's Avatar
Yeah, post -03 or so all they include are some spare fuses, fuse puller, multi-screwdriver, and helmet cord lock.
Adam
The
wants YOU!
browad is offline
post #6 of 15 Old Oct 23rd, 2007, 8:12 pm
LAF
LAF's Avatar
Yep you are right for sure. The only 11/16 spark plug socket is like 60 something bucks
I have always used sockets so I learned something.
I do know that just switching brands may get you to the 5/8 common. I think it was Champion and NGK on the Harley changed you over.
No reason you should damage them using a deep socket. Like I said I have really never used a spark plug socket.
I have taped a deep socket onto a long extension, and then used pieces of tape inside to hold the plug in, big loop, sticky side toward the socket sides, and got it done. Every 10,000 on my GT Cruiser. I am about due again.
Haven't had the pleasure on the LT but think you will be fine with a socket.
Lee
BMW MOA #135959
LAF is offline
post #7 of 15 Old Oct 23rd, 2007, 8:24 pm
ironbuttwannabe's Avatar
Would an 18mm spark plug socket work? It is off by 0.6mm you can pick them up cheap.
Neil '00 K1200LT '08 KLR
"Far away, is far away...
Only if you don't go!!!"
ironbuttwannabe is offline
post #8 of 15 Old Oct 23rd, 2007, 8:34 pm
Chipper's Avatar
If you pm me your address, I will send you an 11/16 spark plug socket. You can keep it till your done and then send it back when your done, if that will help... Or I can send you the sparkplug wrench that came in the tool kit, I wont be needing it for awhile, because I installed NGK's.
Bill
Bill (aka Chipper)
Elk Grove Ca.
2014 K1600GTL-E
1978 H-D LowRider
1975 Honda-Goldwing
Chipper is offline
post #9 of 15 Old Oct 23rd, 2007, 8:35 pm Thread Starter
browad's Avatar
The 18mm is very loose, so very last ditch effort. Rounded off spark plugs is not something I like to think about .
Seems like switching brands might be the easier solution.
Cheers,
Adam
The
wants YOU!
browad is offline
post #10 of 15 Old Oct 23rd, 2007, 8:37 pm Thread Starter
browad's Avatar
Chipper-
Thanks, but want one to keep in my toolkit. This isn't a pressing concern, as I'm 8k off, but is something I want to prep for. The BMW plug wrench (part #71112303416) is listed for $10, which is cheap for anything related to an LT . So that is another route.
Thanks though,
Adam
The
wants YOU!
browad is offline
post #11 of 15 Old Oct 24th, 2007, 12:01 am
Any parts store should have it.
Big_E is offline
post #12 of 15 Old Oct 24th, 2007, 6:37 am Thread Starter
browad's Avatar
With regards the 11/16" socket, that has not been my experience.
Adam
The
wants YOU!
browad is offline
post #13 of 15 Old Oct 31st, 2007, 5:27 pm Thread Starter
browad's Avatar
**Update**
Pep boys had an exceptionally deep 11/16" socket that is working perfectly.
Happy Halloween,
Adam
The
wants YOU!
browad is offline
post #14 of 15 Old Oct 31st, 2007, 9:39 pm
mtrevelino's Avatar
**Update**
Pep Boys is where I found the fuel line clamps.
Mike Trevelino
Williamsburg, VA
2008 RT
mtrevelino is offline
post #15 of 15 Old Nov 3rd, 2007, 1:05 pm
Spark Plug Socket
I changed out my plugs on Thursday. I removed the originals (Bosch), using my LT tool kit socket, then I re-installed new NGK using 5/8" deep socket. No problems whatsoever. I noticed that the Bosch use a double electrode vs. NGK single. Both were Eridium.
Fred
WildwoodDreamer is offline
Spark Plug Replacement Question ltandevinct K1200LT 9 Feb 27th, 2012 3:17 pm
05' & Later Spark Plug Question markharms K1200LT 7 Mar 15th, 2007 5:43 pm
XR 6 LDC, Colder Spark Plug for Hot Climates? MattKas K1200LT 1 Aug 10th, 2006 8:24 am
Stock Spark Plug Socket Size - HELP PLEASE! daisy3d K1200LT 5 May 6th, 2006 3:29 pm
Spark plug tsBMWminer K1200LT 0 Feb 17th, 2006 10:53 pm
