Should I be worried? - BMW Luxury Touring Community
post #1 of 6 Old Oct 22nd, 2007, 10:22 pm Thread Starter
BCVBeck's Avatar
Question Should I be worried?
Greetings All,
Tonight, while cleaning the rear wheel of my LT, I noticed a build up of oil/road grime around the FD drain plug. I do not rawhide my LT, but I do ride the Seirra Nevada whenever I get the chance. No visible oil on the wheel or rim. The slightest film around the fill plug. No oil of any kind on the tire. I gripped the rear tire at 12:00 & 6:00 and checked for play, but did not feel any. Tried the same at 9:00 and 3:00 an got the slightest bit of movement. No abnormal indications yesterday on a two-up ride through King's Canyon. I cleaned everything up REALLY well and will keep an eye on this area. Anything else I should be checking? Thanks.
p.s. I've got a little over 14k on the clock and all maintenance, including a 12K service, was done by my dealer.
Bruce
BMW MOA# 130127
IBA# 49203
MSF RiderCoach
USN (Retired)
'13 R1200GSA (Magma Red)
"Life, Liberty, and the Pursuit of All Who Threaten It."
BCVBeck is offline
post #2 of 6 Old Oct 22nd, 2007, 10:59 pm
A little seepage around the drain and fill is normal. The crush washers don't always get a perfect seal, especially if they have been re-used.
post #3 of 6 Old Oct 22nd, 2007, 11:07 pm
info's Avatar
Drain and refill if worried.
See what it looks like.
Hello 07 R1200S
Bye2006 LT
1982 R65
Buy More Warranty!
info is offline
post #4 of 6 Old Oct 22nd, 2007, 11:55 pm Thread Starter
BCVBeck's Avatar
Thanks All,
Kind of what I figured. Not REAL worried, but thought I should consult the oracle of all LT Knowledge for peace of mind. I'll just keep an eye on it for now. Cheers!
Bruce
BMW MOA# 130127
IBA# 49203
MSF RiderCoach
USN (Retired)
BCVBeck is offline
post #5 of 6 Old Oct 23rd, 2007, 12:37 pm
Newf's Avatar
Sound normal. Most of the drive shaft bikes I have rode will do that.
Manny
Where is the nearest Tims?
Need to stay awake
Newf is offline
post #6 of 6 Old Oct 23rd, 2007, 3:34 pm
Check the level of the gear oil by removing the fill plug and checking to make sure that fluid is at the base of the threads.
The crush washer is designed to hold the fluid in. The threads of the drain plug are aluminum and hence rather soft. If they have been tighted way beyond what they should be, it could crush the washer beyond its capacity to hold the fluid and potentially damage the threads on the FD for the drain plug.
If a dealer has done all the service, they should have replaced the crush washer when the fluid was changed. If not, that is not following standard BMW maintenance procedure. My first inclination would be to check with the dealer to see if there is a record of whether the crush washer was replaced or reused.
If you replace the crush washer and refill the FD oil, it may resolve the weeping. If so, you are home free. If not, the responsibility should be on the dealer.
rglassma is offline
Worried royal K1200LT 39 Jun 18th, 2007 8:39 am
I'm a little worried rkdrmr1 K1200LT 20 Apr 27th, 2007 12:40 pm
Stabil avonfloater K1200LT 13 Nov 18th, 2006 5:12 pm
BT020 Rear Tire Bulge? Tom_Becker Tires 34 Oct 23rd, 2006 11:51 pm
And Andy was worried about getting asked about his SSN! eljeffe Chit Chat 28 Mar 24th, 2006 1:13 pm
