Oil Leaking from Rear Wheel Drive Clamping Strap - BMW Luxury Touring Community
post #1 of 3 Old Oct 22nd, 2007, 5:16 pm Thread Starter
sully2028's Avatar
Just bought a 2001 LT-Icon with just under 42K miles, and have noticed a small oil leak from the rear wheel drive clamping strap. Picture shows oil that accumulated in a day of 250 mile riding - not much but significant. Need a bit of guidance re its repair.
First question, the obvious, would I be able to tighten the clamping strap screw enough to stop the leak?
Second, since I plan to inspect the rear brakes (taking off the caliper) soon, I though it would be a good time to remove the rear wheel drive to get at the oil leak. Does that make sense? Should I plan to remove the flexible gaiter and re-coat with a sealant (Staburags NBU 30 PTM according to the LT Repair Manual pg 33-21)?
Would appreciate your thoughts.
Dan
PS - I have tried to insert two pictures in this, hope they come thru. If not will try again.
[IMG]Pictures showing source of oil leak[/IMG][IMG][/IMG]
Name:	rear end leak 002.jpg
ID:	14901   Click image for larger version
Name:	rear end leak 004 edited.JPG
sully2028 is offline
post #2 of 3 Old Oct 22nd, 2007, 5:23 pm
That is a not uncommon leaking pinion seal in the final drive. It is not something that is an indicator of a probable failure, and can be pretty much ignored except for the external oil on your bike and garage floor. If you want it stopped, the dealer can replace that seal. Proably 3-4 hours labor. Part is not expensive.
Tightening the boot clamp will not do anything, and it is better to have the oil leak out than build up in the boot and get beat around by the universal joint in there.
If you ever see the crown gear seal leaking though (right behind the wheel), that is reason to stop riding right then and there and get the final drive repaired/replaced.
post #3 of 3 Old Oct 22nd, 2007, 6:03 pm
vernvernvern's Avatar
Lightbulb one of two seal leaking, I suspect.
Dan
Dan,
Not seriuos right now.
Don't tighten the strap. That isn't your problem. There should be no oil in there.
You either have a rear seal in your tranny leaking or the forward one in your FD unit. Not serious enough to stop riding, but at your next service( dealer) have them investigate to see which seal is leaking.
My .02 worth. Some expert may have another opinion!
Vern
78 years young!
Converted HD rider.
Vern
vernvernvern is offline
Rear Wheel Drive Good Arthur K1200LT 7 Nov 1st, 2013 12:44 pm
Another Rear Drive Bites the Dust - Question lad K1200LT 63 Jul 19th, 2013 1:34 pm
Another Rear Drive Failure WildBill K1200LT 4 Jul 18th, 2007 5:50 pm
rear drive oil leak? louatlvc K1200LT 4 Jun 11th, 2006 8:17 pm
Rear Wheel Drive Issue longtmrdr K1200LT 8 Apr 24th, 2006 10:55 pm
