No response from Starter - BMW Luxury Touring Community
post #1 of 10 Old Oct 22nd, 2007, 3:56 pm Thread Starter
Hi Everyone,
I've got a 2003 Lt. Battery was low and while out on a run, stopped briefly and found bike wouldn't start. Replaced battery with a new Odyssey and it still won't start! I've push started the bike and engaged the reverser - works fine - so I'm assuming the starter button and starter motor is OK. I've read about the low voltage circuitry in the post 2002 bikes which I assume is stopping the starter relay working. Does it need resetting? I have a feeling the relay has died but I thought I'd ask before stripping it down.
Any info would be great!
Best Wishes,
Dave003 is offline
post #2 of 10 Old Oct 22nd, 2007, 4:19 pm Thread Starter
more info
Just thought I'd mention - checked battery wiring, side stand switch - fuel pump makes noise so kill switch OK - no load voltage is about 12.7 volts, ignition on is about 12.5v. Its on charge at the moment. - thanks
Dave003 is offline
post #3 of 10 Old Oct 22nd, 2007, 4:24 pm
zippy_gg's Avatar
Just checking, bid you by any chance leave the bike in reverse?
Gilles & Kathy
BMWMOA# 154719
IBA# 71594
2011 Ostra Gray RT
zippy_gg is offline
post #4 of 10 Old Oct 22nd, 2007, 4:30 pm Thread Starter
reverse
Hi - no I've checked the reverse switch - switched it back and forth a few times - I don't use it very often anyway - but I'll check it again - thanks
Dave003 is offline
post #5 of 10 Old Oct 22nd, 2007, 5:15 pm
Ole Toad is a '99 model, so we don't have an alarm - butt if you have one, could that thang figger into the problem?? Wouldn't think so, if you can push start it - butt dunno.
post #6 of 10 Old Oct 22nd, 2007, 7:19 pm
Newf's Avatar
May be time to dig out the volt meter and start checking to see if power is getting to the relay and the starter.
Manny
Where is the nearest Tims?
Need to stay awake
Newf is offline
post #7 of 10 Old Oct 22nd, 2007, 7:53 pm
Daman858's Avatar
What Manny said...starter relay!
Monkton, MD
and Pawleys Island, SC
2002 K1200LTC
Daman858 is offline
post #8 of 10 Old Oct 22nd, 2007, 8:16 pm Thread Starter
thanks everyone - looks like its off with the plastic
Dave003 is offline
post #9 of 10 Old Oct 22nd, 2007, 10:01 pm
Patric's Avatar
Smile make shure
You put ALL the wires back on the new battery . If you miss one , it might not work ...I can't remember just what it was . But I have had to scraich my head , and try to find out what I did wrong . I miss one of the ground wires , and what ever it was , it no workie ...patric ...
Patric Blackman
2002 K1200LT/Hannigan2+2
AMA Charter Lifemember
Patric is offline
post #10 of 10 Old Oct 23rd, 2007, 10:32 am
zuchero's Avatar
Hi Dave,
I have the same problem but only from time to time. For no reason, the bike just would not start. I had placed a post in here some time ago and the suggestions were the same: check the starter relay, battery, circuit and so on.
I checked them and everything seems fine. I haven't found the cause but I've found the solution: roll the bike forward just a couple of inches while on first gear. Put it back in neutral and try the starter button. I starts every time for me this way. Worth giving it a try before undressing her
Regards,
Zuchero
zuchero is offline
Starter relay upgrade Justtp K1200LT 1 Mar 30th, 2007 9:52 am
Starter Relay - Puzzled by dealer response Tim_in_NJ K1200LT 4 Sep 22nd, 2006 4:56 pm
starter stuck ?? MLHAYES K1200LT 4 Sep 9th, 2006 8:35 pm
Starter problems Yiet K1200LT 5 Aug 14th, 2006 2:32 pm
Starter Sprag Clutch TimVipond K1200LT 3 Nov 17th, 2005 3:33 pm
