Intermittent Cruise Control - BMW Luxury Touring Community
post #1 of 3 Old Oct 22nd, 2007, 1:25 pm Thread Starter
I need help in adjusting my clutch lever side cruise control switch. Now the system in shutting off by itself after being engaged for a few minutes. It went from working fine to darn right annoying.
I've heard these can be adjusted (instead of replaced), mine was replaced just over a year ago. Sounds like to me that it need adjusting again. Anyone done this before???
woodysLT is offline
post #2 of 3 Old Oct 22nd, 2007, 1:43 pm
Buchnerb's Avatar
Check your rear speed sensor. On my 07 the bolt was loose and caused those symptoms. I understand that some times the wire gets crimped and causes the same problems. Have you noticed any speedometer fluctuations? That would be another sign of sensor problems.
Bruce
Bruce Buchner
2017 R1200RT Platinum Bronze Metallic
2012 R1200RT Fluid Grey Metallic (Little Girl) Traded on the 2017 RT
2007 K1200LT Storm Grey Metallic (Big Girl) Traded on the 2017 RT
2001 325XI 4dr Sold
1967 2000CS Coupe (Left it in Germany)
Buchnerb is offline
post #3 of 3 Old Oct 22nd, 2007, 2:35 pm
My '02's needed adjustment and the mechanic did it at a service. Didn't look too hard, just fiddly. The clue that it needed adjusting was the sound of the micro switch clicking, or not clicking. Check it with the bike off and you can hear the click as you work the lever.
Motor On ,/'
jkersh1 is offline
Cruise control diagnosis = what is this telling me? coug66 K1200LT 9 Feb 5th, 2012 10:06 am
Cruise Control OD with new cables. airborneod K1200LT 24 Jun 14th, 2011 7:42 am
MCCruise.com electronic cruise control installed Randy GS Series 16 Jun 22nd, 2007 10:04 am
Section speed trap in The Netherlands vvk Europe 4 Apr 18th, 2006 4:40 am
Speed traps in The Netherlands vvk Chit Chat 0 Oct 24th, 2005 10:38 am
