For electronics enthusiasts - BMW Luxury Touring Community
post #1 of 6 Old Oct 21st, 2007, 2:51 pm Thread Starter
Ajlelectronics's Avatar
This rear fog light business...
There is an unused 21W filament in the back light assembly, but I haven't found an easy way to wire it. So I have given some thought to a way to use it without running cables. I came up with an idea about using a small control module. The signals available in the tail light are indicators, brake and tail, so how to make use of them?
It needs some combination that would not generally be used on the road that will latch the fog light on. So how about hazards running, tail light on and flick the brake light on? That could be sensed by a 4 input AND gate and fed to a thyristor relay driver. To turn it off again, switch off the tail light (that is supplying the rail voltage to the module. )
Very low cost. CMOS 4082, little thyristor, cheap relay and some wire.
Comments?
Just pussin' through.
Ajlelectronics is offline
post #2 of 6 Old Oct 21st, 2007, 3:06 pm
pozo_izquierdo's Avatar
Comments?
Sorry, I'm not that much of an electrician... I simply pulled one extra wire via one of my extra switches and I use it as rear fog light.
Regards
Hyvinkää, Finland
pozo_izquierdo is offline
post #3 of 6 Old Oct 21st, 2007, 3:10 pm Thread Starter
Regards
That was my original intention, but can't work out the loom route from the tail light housing. How did you get the cable to the front?
post #4 of 6 Old Oct 22nd, 2007, 2:37 pm
Remove the trunk and the lower plastic cover. Push the wire through the grommet or drill a separate hole for the wire. Run the wire under the gas tank. I suggest that if you want to do it properly, run a set of cables under the gas tank at the same time. Then you don't need to do it the hard way every time.
Regards
Hyvinkää, Finland
post #5 of 6 Old Oct 22nd, 2007, 3:19 pm Thread Starter
I pushed it through the grommet, but the problem is, I can't see where it appears the other side to thread it further.
post #6 of 6 Old Oct 23rd, 2007, 5:38 am
Then you'd better open the rear panel as well. You know...take out the licence plate holder, and open all the torx screws plus the two with large washers under the trunk and pull it out enough to see where the wire hides.
Regards
Hyvinkää, Finland
For all you firearms enthusiasts! Dick Chit Chat 12 Feb 16th, 2006 8:58 pm
Ham Radio Enthusiasts Tom_Becker Intercom, CB, & 2-Way Radios 9 Jan 9th, 2006 7:06 pm
Any R90S enthusiasts? CharlieVT Other R-Bike Discussion 4 Dec 7th, 2005 7:08 pm
