What did I do? - BMW Luxury Touring Community
post #1 of 7 Old Nov 28th, 2005, 7:35 pm Thread Starter
Unhappy What did I do?
Help! I was working in my garage over the weekend and put my K12 outside (it was about 45 degrees and dry) About 9PM I went to start it and drive it back in the garage and the engine started but the headlight didn't come on. I shut it off using the key and tried to restart it. The engine didn't start, the headlight didn't come on and the starter motor would not stop cranking the engine. I turned it off, pulled the key tried to push the start button incase it was stuck but the starter kept running till the battery was dead. I pushed it inside, disconnected the battery and recharged it over night. As soon as I touch the negative battery lead to the battery post it starts cranking the engine again! Any ideas what this could be?
Tom
Thomas0826 is offline
post #2 of 7 Old Nov 28th, 2005, 7:43 pm
Senior Member (ret.)
RaffyK's Avatar
Hit the starter button as soon as you touch the negative cable to the battery. It might free up the starter and stop trying to start.. You welded the starter relay because of low voltage. Known issue on the older bikes. There is an upgrade for this from BMW.
Raffy
RaffyK is offline
post #3 of 7 Old Nov 28th, 2005, 7:44 pm
Super Moderator
DavidTaylor's Avatar
This is the infamous starter relay problem on older model LTs. IIRC, if the battery voltage gets low enough the bike will attempt to start but what happens is the starter relay welds itself together, which then causes the starter to run until the battery is flat or you pull the battery connection. They updated the relay a few years back to currect this problem, and it may be covered under a service bulletin. If so the dealer may replace it for free, otherwise you'll need to either pay him to replace it or do it yourself.
David Taylor
San Jose, CA
2010 R1200RT Polar Metallic
AMA, BMWMOA
Booze Brother #4
DavidTaylor is offline
post #4 of 7 Old Nov 28th, 2005, 7:54 pm Thread Starter
Thanks, any idea what a starter relay costs or where its located?
post #5 of 7 Old Nov 28th, 2005, 7:55 pm Thread Starter
Thanks David as I asked RaffyK above, any idea what a starter relay costs or where its located?
post #6 of 7 Old Nov 28th, 2005, 7:58 pm
RaffyK's Avatar
Located on the right side of the bike- electronics box. If I remember correctly, I believe I read $150 (this maybe installed?).
Raffy
RaffyK is offline
post #7 of 7 Old Nov 28th, 2005, 8:04 pm
Thomas - check this post out; the procedure has worked in the past. Good luck.
click here
