Brake and Warning lights flashing ..sometimes - BMW Luxury Touring Community
post #1 of 8 Old Oct 16th, 2007, 12:02 am Thread Starter
About a week ago, the brake and warning flashers starting randomly coming on ( alternating, about 1/sec ) in flight. After turning the ignition off then back on at a stop, it usually stops. I don't think the fluids have been serviced in about 6k miles. It seems to only happen in the morning or when the bike is first running. It never comes on during the start but rather after the bike has been riding a while after a few brake applications. I read the HOW, which suggestd both lights on indicated a trip to the dealer. Any other suggestions, before I take this expensive route..
maxthrottle is offline
post #2 of 8 Old Oct 16th, 2007, 12:05 am
BMW Guru
Ted Shred's Avatar
This is usually caused by low fluid in the rear brake master cylinder resevoir.
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #3 of 8 Old Oct 16th, 2007, 10:50 am
Reid's Avatar
Yep...most likely low fluid in reservoir(s). If the fluid is near minimum and you make some turns the sensor trips saying you're low. Yes, check both reservoirs...there're two attached together under the seat (rear seat on my '03). You may need to loosen the tupperware to access the one furthest to the front...no need to remove the tupperware tho, just three or four torx screws removed will suffice for providing access to remove the reservoir caps. A syringe or marinade injector (my favorite) works very well for getting the fluid into the reservoirs.
Reido
K1600GTL...Blue Metallic
USMC 1971-1975
Ham Radio Call: W0FVR
"The right to be heard does not automatically include the right to be taken seriously."
--H.H. Humphrey
Reid is offline
post #4 of 8 Old Oct 16th, 2007, 11:20 am
It usually happens to me when the weather starts to cool off. The reservoir will look like it is full but needs to be filled up to the maximum line.
Alan Stuber
2003 K1200 LTC Titan Silver
Austin, Texas
astuber is offline
post #5 of 8 Old Oct 18th, 2007, 4:35 pm
You might want to check your pads also. The brake fluid can be low from excessive brake pad wear.
brucester is offline
post #6 of 8 Old Oct 18th, 2007, 9:00 pm
I had that problem last year about this time. The first cool night and they started blinking.
I added a couple spoonfulls of brake fluid to the rear reservoir and it stopped and has never come back.
CajunBass is offline
post #7 of 8 Old Oct 19th, 2007, 8:03 am
I had the same thing happen and the fix was to replace the pads. How many miles do you have on the brakes?
brianf70 is offline
post #8 of 8 Old Oct 19th, 2007, 8:10 am
Just try to remember not to use that marinade injector on the Thanksgiving bird later..... :-)
Beautify America - Get a Tattoo!
2002 K1200LT (going, going, GONE)
Tat_n_Telle is offline
Brake failure lights keep flashing djbroughton K1200LT 13 Sep 17th, 2015 8:04 pm
abs warning lights back on. dodk64 K1200LT 3 Aug 23rd, 2007 12:22 pm
Brake Failure Lights When Hot Buchnerb K1200LT 12 Aug 18th, 2007 1:21 pm
More ABS headache... pozo_izquierdo K1200LT 9 Jun 26th, 2007 11:20 am
brake warning light bikesnumbnuts K1200LT 0 Sep 26th, 2006 4:23 pm
