Ohlins question - BMW Luxury Touring Community
post #1 of 21 Old Oct 15th, 2007, 7:13 pm Thread Starter
CharlieVT's Avatar
Ohlins question
I have about 10K on my Ohlins.
What I have noticed so far: The OEM shocks were removed around 38K miles. They were working fine, but perhaps a little harsh on the bumps, but the ride was solid and the bike tracked great. The Ohlins made the ride smoother, no question. But in corners, especially two up, when hitting a bump there is wallowing and the bike does not track as well as it did with the old OEM shocks.
I have tightened up the hydraulic adjuster of the rear shock with no noticable difference.
I am thinking I need to tighen up the pre-load on the springs, front and rear (but I suspect mostly rear). I am hoping this will reduce the wallowing, but will make the ride a little harsher (which I am willing to accept).
Before I go and crank down those springs I thought I'd ask, have others experienced this, and I am I taking the correct approach in increasing spring pre-load?
Thanks in advance.
CharlieVT is offline
post #2 of 21 Old Oct 15th, 2007, 7:22 pm
BMW Guru
Ted Shred's Avatar
Thanks in advance.
When you bought the Ohlins were they built for you ie your weight and riding style?? If not, out of the box Ohlins are set up for about 160lb rider and are too soft for most people. You should have them set up with the proper springs for you weight and riding style...
__________
2016 R1200GS Adventure
2006 DRZ400E
2007 G650 X Challenge
2006 GT200
2005 R1200GS
Ted Shred is offline
post #3 of 21 Old Oct 15th, 2007, 7:42 pm Thread Starter
CharlieVT's Avatar
Ohlins setup
Yes, when I ordered the Ohlins I gave the vendor my riding style and weight, and the fact that I ride two up some of the time. I think that I have the "standard" spring based on the conversation with the vendor . Which leads to another question: how many different springs does Ohlins offer? From taking with the vendor, I came to understand that there were two springs, standard and heavy. I have read many posts about setting up the Ohlins for weight and riding style but I have never heard a knowledable source state how many different springs there really are.
You are the first I have heard to say the the standard spring is inadequate for riders over 160 lbs. My vendor cited something over 200lbs (220 IIRC) before going to the heavy duty spring.
post #4 of 21 Old Oct 15th, 2007, 8:01 pm
BMW Guru
Ted Shred's Avatar
I don't know how many springs there are, I thought that there were at least three. If you're riding two up on an LT IMHO you need a heavier spring. You show call Dan Kyle at Kyle Racing. He is a vendor on this site and is an Ohlins expert...
__________
2006 DRZ400E
2006 GT200
2005 R1200GS
post #5 of 21 Old Oct 15th, 2007, 9:17 pm
This is interesting. I assumed that Ohlins were bought and setup with some sort of magic spring for the specific weight range... Seems like the spring selection for Ohlins are not quite as customized as I was lead to believe.. Maybe someone will have some real hard information.
As I was trying to do some research on the HyperPro shocks (I expect will be on a group buy soon?) I ran across this Bikepoint website. Under riding tips and bike setup there is a reprint of 6 magazine articles on setting up your shock sag and rebound.
From your description of your problem it seems like you need to make some adjustments. The description of your fault is detailed in the article stream.
Take a read and see what you think.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #6 of 21 Old Oct 15th, 2007, 9:35 pm
kdog's Avatar
Wallowing could be caused by too little rebound damping. That actually sounds more plausible than too little spring would probably cause bottoming out, not wallowing. Rebound damping is a simple adjustment that can be performed without taking anything apart, so you may as well start there anyway.
Here's how. Lie on the ground, and look up at the bottom of the shock body. You'll see a black plastic ridged knob between the bottom of the shock and the mounting stirrup. I forget which way you turn it to increase damping, but no matter. Turn it a few clicks (like maybe two or three), and take it for a ride. It'll either be better or worse. Adjust accordingly.
The entire range is 16 clicks as I recall. So midpoint is around 8 clicks and makes a good starting point. There are positive stops at either end of the range. So you can start by turning the knob either way and counting how many clicks you get before it stops. You'll be surprised at how much of a difference a couple of clicks make.
kdog is offline
post #7 of 21 Old Oct 15th, 2007, 9:48 pm
BMW Guru
Ted Shred's Avatar
That's good advise Joel. Sometimes I over look the obvious
__________
2006 DRZ400E
2006 GT200
2005 R1200GS
post #8 of 21 Old Oct 16th, 2007, 1:51 am
Gino's Avatar
I've been dealing with this myself on my new (1500 miles) shocks and trying to get them set up. The range of "clicks" is around 40 - the setup for the LT from the factory is 16 clicks from "zero" - see here for the settings (page 5).
You may also want to make sure that the spring preload compression (see here) is set as shown, otherwise your pre-load adjuster may not work as advertised. This setting should have come from the factory at 26mm - but easy enough to check - and your shocks should have included the spanner wrench for this purpose.
Gino
Modesto, CA
'02 Silver
For they passed a noble law,
Gino is offline
post #9 of 21 Old Oct 16th, 2007, 7:43 am Thread Starter
CharlieVT's Avatar
Thanks gents
Very helpful posts and suggestions.
Rebound damper sounds like a good place to start experimenting.
(I didn't know, or had forgotten that it was even there).
Sunny, 32 degrees F this AM, trees are starting to lose their leaves of color here in the deep south of Vermont. Looks like a riding day today!
post #10 of 21 Old Oct 16th, 2007, 11:19 am
kdog's Avatar
Very good! Thanks for the clarification, Gino!
Cheers,
-joel
kdog is offline
post #11 of 21 Old Oct 16th, 2007, 12:50 pm
Here are two replies I received from Ohlins a few months ago regarding my question about the different springs available for the LT:
Dear Sirs,
I am considering installing new Ohlins shocks on my 2005 K1200 LT, the model with the hydraulic centre stand.
I note that according to your web site, there are TWO rear shocks available for my bike,
46 DRS part BM 539
and
46 DRS part BM 548
what is the difference between the two, and if there is, which one do you reccomend I install on my bike ?.
Kind regards,
Simon Tow
Dear Simon,
The difference is the springrate only.
BM 539, spring 01099-74, springrate 180N/mm, this is standard.
BM 548, spring 01099-84, springrate 200N/mm.
This is to give customers with a lot of weight on the BMW an optional shock.
Best Regards
Lars Isaksson
Öhlins Racing AB
Marketing & Sales
Office: Instrumentvägen 8-10
Mail: Box 722
S-194 27 Upplands Väsby
Sweden
Lars,
It has just occurred to me that I did not ask you what you meant by "a lot of weight".
I weigh around 75 kgs and my passenger around 50 kgs, and we normally only use the bike for long trips, so we (she) takes a lot of luggage with us.
Would this be a lot of weight in your opinion ?.
Simon "
Simon,
Standard spring will be ok for your weight, the heavier spring is for 200 + kg.
Best Regards / Lars
-----Ursprungligt meddelande-----
Från: Coronet [mailto:[email protected]]
Skickat: den 29 december 2006 20:26
Till: Lars Isaksson
Ämne: Fw: BMW K1200 LT
Hope they help.
simoncharles is offline
post #12 of 21 Old Oct 16th, 2007, 12:57 pm
Very Informative..
I taking this to mean that the 'customized spring rate' for weight with Ohlins 'premium' shocks are basically two choices... ?? I obviously had a different impression. The HyperPro shocks are looking better all the time.
2001 Black LTC
2015 Blue R1200GSA
jackd is offline
post #13 of 21 Old Oct 16th, 2007, 1:58 pm
So did I but when you take into account that the bike weighs 761 lbs dry excluding options and accessories, BEFORE any rider or passenger gets on, the extra bulge around the waist, in the sum of things, won´t make much difference.
post #14 of 21 Old Oct 16th, 2007, 4:51 pm Thread Starter
CharlieVT's Avatar
Isn't this a great site!?
Thanks gents.
Adjusting the rebound damper is easier than adjustion the hydraulic preload adjuster (if you fine lying down on the ground and reaching up for the bottom of the shock easier that opening the sidecase and lifting the seat to get to the preload adjuster.
I added 4 clicks to my rebound damper; haven't done the test ride yet but it makes sense to me that this is the fix I was looking for.
An added benefit from the posts to this thread is the info about Ohlin spring options and the links to the Ohlin site for shock tuning info.
Mucho appreciative in the deep south of Vermont.
post #15 of 21 Old Oct 17th, 2007, 3:17 am
Yes but each adjustment is for entirely different things.
Also I think you are confusing the rebound dampner with the compression one.
The first one is at the bottom of the shock, the second at the top.
Basically the rebound damping is adjusted to the bikes type and weight and only set once.
The compression dampner is adjusted according to the load being carried at any given moment.
This is why it is easlily accesible. A turn more or less on this won´t make much difference to the bikes handling.
Not the same with the rebound dampner, which is more trial and error and can seriously affect the bikes handling and ride comfort.
The standard SHOWA shock doesn´t have this rebound adjustment possibility.
That´s how I understand it anyway.
post #16 of 21 Old Oct 17th, 2007, 6:04 am Thread Starter
CharlieVT's Avatar
Each is adjustment for different things
Thanks for your efforts to clarify, but I am not confused. The links to the articles and Ohlins sites provided by the folks who responded above provided a clear description of the various adjustments on the Ohlins.
Anyone with a set of Ohlins would probably benefit from reading that stuff.
When I installed my Ohlins I basically slapped them in there and forgot them. After riding them for some time I realized they could use improvement; I would have done well to read all that information at the time I installed them.
post #17 of 21 Old Oct 17th, 2007, 7:55 am
Charlie,
I didn´t say you were "confused" but "think you are confusing".
What I meant was that you yourself say:
"Adjusting the rebound damper is easier than adjustion the hydraulic preload adjuster (if you fine lying down on the ground and reaching up for the bottom of the shock easier that opening the sidecase and lifting the seat to get to the preload adjuster"
which to me doesn´t make sense, that´s all, as it implies that you find it easier to adjust the rebound dampner than the preload under the seat.
If it´s clear and easier for you, then fine.
Simon
post #18 of 21 Old Oct 17th, 2007, 6:16 pm Thread Starter
CharlieVT's Avatar
Wink Ohlins digression
[QUOTE=simoncharles]Charlie,
"I didn´t say you were "confused" but "think you are confusing"."
Now there's a distinction without a difference.
I confess to being confused and confusing at the same time. It is a talent, but no great honor.
"What I meant was that you yourself say: "Adjusting the rebound damper is easier than adjustion the hydraulic preload adjuster (if you fine lying down on the ground and reaching up for the bottom of the shock easier that opening the sidecase and lifting the seat to get to the preload adjuster" which to me doesn´t make sense, that´s all, as it implies that you find it easier to adjust the rebound dampner than the preload under the seat."
Well, actually.... that IS what I meant. I can adjust the rebound damper quicker and easier than I can open the sidecase, pull the seat release, tip the BackUp backrest out of the way, lift the seat, raise the hydraulic preload adjuster, make the adjustment, and then put everything back.
To do the rebound damper, I lie down, reach in and adjust the thing, then get back up again. Now.... as getting back up again gets increasingly difficult for me, I may change my mine as to which is easier to do.
BTW... this is mean to be humorous, sometimes that intent really gets lost in this medium, hence all the and
Best to you from the deep south of Vermont.
post #19 of 21 Old Oct 17th, 2007, 9:16 pm
dmatson's Avatar
When I got my Ohlins this last year I was told there were two springs, one set up for a person 15 to 210lbs and if you were more than that or carried more weight then the heavy duty spring was ordered. I weigh 160 and ride 99% one up I also removed the top box close to 40lbs. When I put the shocks on I noticed a much stiffer ride, no bottoming over speed bumps and no wallowing in truns no matter how fast or what I was draggin. I did check the set up on my shocks and they were set in the middle of adjustment. I shanged the stockers out at 17K and they were still good (for stock). I wish the OHlins were smoother on the small stuff like I was lead to believe but they are an amazing difference on aggressive riding. When you are adjusting your shocks make sure you don't just ride the bike adjust then ride some more. You need to ride it over the same course for each adjustment at the same speed and make small adjustments. To get the LT to start to wallow in a turn if the preload is set up correct would probably be the rebound to soft or a loose shock.
14' KTM 1190
03' KTM 450 EXC Dually
72' Honda SL 100
67' Triumph Bonneville
65' Honda CB160
70' Honda CB350
dmatson is offline
post #20 of 21 Old Oct 18th, 2007, 10:43 am
kdog's Avatar
Which spring did you get?
When I got mine, they immediately felt incredibly smooth on rough road with the stock spring. At my first rebuild, I got talked into a stiffer spring. The shock lost smoothness, but still handled great. After two more rebuilds, I finally had the stock spring put back on. I got my smoothness back, and still handles great. People who over spring are fooling themselves.
kdog is offline
post #21 of 21 Old Nov 19th, 2007, 5:02 pm Thread Starter
CharlieVT's Avatar
Final report
Thanks to all who made suggestions in response to my original query.
My complaint was wallowing when riding two-up and encountering bumps in the corners.
I turned the rebound damper at the lower end of the shock two clicks.
I have ridden the new setting for a while now and am happy to report this adjustment resolved my complaint.
Thanks Again.
Thanks in advance.
Help all Ohlins users! q-tip Shocks and Suspension 14 May 12th, 2007 8:15 am
Another Ohlins question sanjaun2 K1200LT 16 Jul 25th, 2006 12:55 pm
Ohlins Question BruceHarrisJr Shocks and Suspension 9 Oct 15th, 2005 7:53 pm
