ok - so how bad did I screw myself? - BMW Luxury Touring Community
post #1 of 9 Old Oct 13th, 2007, 9:29 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Angry ok - so how bad did I screw myself?
So, I did a brake job today. First up on the agenda was changing brake fluid. I had obtained the speedbleeder bag and was confident about doing the job.
First I did the handlebar level circuit followed by the footpedal. Everything went according to plan. The brake fluid needed changing and it was nice to do it myself. Next I did the rear foot pedal circuit and again no problem.
Switched over the front wheel cylinders. I compressed the brake calipers since I was putting new pads in. It took a bit to get the pistons to move but they did go in. And yes, I took some fluid out of the reservoir so it wouldn't overflow. I'm feeling good - front brakes done fluid changed. Life is good.
Finally, I head to the rear. I removed the pads and pushed the caliper cylinders back in. Now I get ready to change the rear wheel caliper fluid. Turn on the ignition and lightly squeeze. My helper reports fluid and I'm looking in the reservoir - it doesn't seem to be going down.
OH CRAP! I was looking in the rear reservoir not the front. I drained the front reservoir and my helper reports air bubbles coming in to the speed bleeder bag. Now I'm thinking what in hell did I do to myself?
Well the only thing to do is to start filling the right reservoir and pump a lot of fluid through to get the air out. Well I did that about 8 times. Helper reports no air coming through.
So what kind of mess did I make? Any advice?
Tom
Tom Becker
Rancho Mirage, CA 92270
2003 Titan Silver LTE "Cantabile"
2001 Black R 1150 GS
BMWMOA
AMA
IBA (SS1000, B2B-36)
KI6CDF
Tom_Becker is offline
post #2 of 9 Old Oct 13th, 2007, 9:58 pm
tbarstow's Avatar
Sounds like you recovered your error properly.
If the front brake lever doesn't feel spongy, you should be fine.
Make sure you change the fluid in the servo unit as well. It isn't hard to do and doesn't require the modified 7mm wrench to get to all of the bleeders.
Tim Barstow
2004 GSA Silver
2007 X Challenge
tbarstow is offline
post #3 of 9 Old Oct 14th, 2007, 4:33 pm
Sounds like yo ugot it, Tom! Ride.. enjoy.. repeat.. if you notice erratic rear brake function then reflush.. riding it a while will allow bubbles to "congregate"..
J.M.J...
Dcn Channing
post #4 of 9 Old Oct 14th, 2007, 9:10 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Red face Test ride today...
Well I put everything back together. This was a major maintenance job. About the only thing I didn't do was flush the clutch line and check the valve clearance.
Anyway, the brakes actually feel better now than before. I did multiple emergency stops to check ABS function. Could not get it to go into typical ABS "chatter" mode but stopped as straight as an arrow. I did not have any fading or sponginess. In fact I had no evidence of any kind to suggest that I had to bleed the brake lines multiple times.
I think your advice about watching it and re-flushing might be the ticket. I'll just have to see how braking action is over the next couple of weeks.
Tom
Tom Becker
BMWMOA
AMA
KI6CDF
post #5 of 9 Old Oct 14th, 2007, 10:02 pm
If you have gone that far without a fault indicated, I would say you were successful. Another tip for recovering from a bad flush (letting air in) is to run the line from the caliper back to the reservoir. Let the pump cycle the fluid until the bubbles are gone.
post #6 of 9 Old Oct 14th, 2007, 11:35 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Talking Great idea...
Thanks for the tip about running the wheel cylinder output back to the reservoir. That's a real good way of clearing the trapped air.
Kind of makes me think of an aquarium pump except without the fish.
Tom Becker
BMWMOA
AMA
KI6CDF
post #7 of 9 Old Oct 15th, 2007, 11:40 am
make sure you run a clean hose...
J.M.J...
Dcn Channing
post #8 of 9 Old Oct 15th, 2007, 2:48 pm Thread Starter
Enthusiast - KI6CDF
Tom_Becker's Avatar
Talking No faults...
I rode about 35 miles through the mountains yesterday. No fault lights came on - nada... ran like its supposed to.
Tom
Tom Becker
BMWMOA
AMA
KI6CDF
post #9 of 9 Old Oct 15th, 2007, 3:16 pm
BeemerRiderBoB's Avatar
I'd say you're good to go.
One last check we do after brake flushes is to hook up a GS-911 to clear the old error faults. If someone nearby has one might be worth a check to verify everything is ok and clear any old faults. Alternatively you can take it to the dealer but there's a growing number of members who have these diagnostic units and are willing to help.
Here's a link to the thread on list of GS-911 owners.
http://www.bmwlt.com/forums/showthread.php?t=24561
BeemerRiderBob
Dallas/Ft. Worth
'82 R100 Sidecar
'91 R100 GS BumbleBee
'93 R100 GS/PD
'02 K1200 LTC- KIA 09/04/07
'03 KTM 450 Exc (living in Colorado)
'08 R1200 GS Adventure (Joy)
Only 41% of the World Left to Visit!
BeemerRiderBoB is offline
Stripped screw on oil filter cover - HELP!! SeaMarshal K1200LT 11 Jul 6th, 2009 8:26 am
2000 LT Grub screw size? Doug_Gentry K1200LT 7 Dec 9th, 2006 1:25 pm
What'd I screw up.... (EBC pads: shot) Zotter K1200LT 10 Jun 27th, 2006 9:13 pm
Screw Garu's. Where does this one fit ? Hilton K1200LT 10 Jun 27th, 2006 2:06 pm
