Center stand mounting hardware - BMW Luxury Touring Community
post #1 of 1 Old Oct 11th, 2007, 4:21 pm Thread Starter
Schweintechnik's Avatar
Question Center stand mounting hardware
I had some help disassembling my bike a month or two ago to do a clutch job, and now that I'm putting it together again, I've run into a place where I'm not sure how things go together. One of the "hazards" of having lots of help: there's lots of stuff going on at once and it's hard to keep up with photos & bagging/tagging.
The bracket that mounts directly to the transmission, onto which are mounted both the side stand and the center stand (the FM calls this the "pivot bracket") is held in place with four screws. The side stand switch wire is strapped to a bracket that gets sandwiched between the pivot bracket and the left two mounting points on the transmission. I can't tell if there is supposed to be some kind of washer or spacer to compensate on the right two joints for this additional stack height on the left side. The FM doesn't picture anything and none of the parts fiche pages even picture the small bracket for the side stand switch wire.
Also, the FM shows a washer between the head of the screw and the pivot bracket on all four joints, but the parts fiche shows only the screw.
Lastly, the use of Loctite 242 or 243 isn't mentioned at all for these screws, only the hardware that holds the stands to the pivot bracket. But there is some blue threadlocker residue showing on mine. Anyone know what the general practice is for these screws - dry or Loctite?
This is for the non-hydraulic 2003 variety of center stand. Not sure if the hydraulic version would be assembled the same or differently.
'03 K1200LT-C Dark Graphite
Schweintechnik is offline
REPORT: Retrofit '01 with a Power Center Stand midwilshire K1200LT 55 May 10th, 2016 11:51 am
2002 k1200ltc center stand retrofit? rogerK K1200LT 14 Nov 26th, 2008 12:07 am
2002 Model Center Stand Broke MattKas K1200LT 7 Nov 6th, 2006 1:37 pm
Center Stand Lubrication for Pre 2005 MattKas K1200LT 9 Oct 19th, 2006 1:16 pm
